Old 8th November 2020, 05:53   #101  |  Link
Originally Posted by VoodooFX View Post
but how in the hell top/right corner mask is red, feathered and "12" visible when it goes through Greyscale.Levels(127,1,128,0,255)...
Dont see why it should make it red, however should for YUV use
Greyscale.Levels(127,1,128,0,255,coring=false)...
Old 8th November 2020, 18:50   #102  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
It's random/non-reproducible bugs, when using Prefetch(4). Masking and Levels(127,1,128,0,255) happens in RGB32.
Originally Posted by poisondeathray View Post
WriteFileIf with a runtime function expression like lumadifference . But there was some bugs in avs+ 3.x with this. It works in 2.6 classic. There was some discussion about this somewhere IIRC. Not sure what changed or what the exact syntax change was
Something like this works in avs+ 2.6 classic
Subtract(clip1,clip2)
WriteFileIf (last,  "log.log",  "LumaDifference(clip1, clip2)>0", "current_frame", """ ":" """, "AverageLuma")
Thanks mate, that works perfectly. I edited it a bit so I can copy/paste log to SelectEvery:
WriteFileIf (last,  "log.log",  "LumaDifference(clip1, clip2)>0", "current_frame", """ ", \" """)
AvS 2.60(2.6.0.6) & AvS+ 3.5 (r3106) produced identical logs, AvS+ was 20% faster.
I run comparison on stacked output with 4 steps (like in screenshot in the previous page), so, Prefetch(4) vs no Prefetch:
Detected discrepancies in 157 frames from 134237 frames, almost all of them in the top/right mask, in 18 frames those mask are ok but discrepancies are in the final step(bottom/left, but no visible differences).
Here is some examples of the bugged masks (it should be B/W with white numbers, last two digits shouldn't be visible), stacked original clip & one mask:
Now I need to run more tests to isolate the problem.
VoodooFX is offline   Reply With Quote
Old 8th November 2020, 20:20   #103  |  Link
poisondeathray
What format was source video ? Did you try threads=1 for LSmash ? Or other source filters to rule out some issue upstream ?
To be clear, was the issue only with Prefetch(4) ? Is no prefetch ok ? Or other values ?
I recall some discussion about source filter threads and seeking accuracy issues vs. host CPU threads , but I think that was for ffms2
Old 9th November 2020, 13:28   #104  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Like I suspected it's something with Overlay, tested and same on AvS+ 3.4, 3.5.1, 3.6.0, 3.6.1.
Here is minimized and ready to run test scripts (extract to C:\) or preview included test results https://anonfiles.com/F7E0hdo2p0 or https://we.tl/t-J95N1CsfUz (7 days)
Isn't "threads=1" parameter for ffms2!? No-Prefetch is ok. I dunno working alternatives for LSMASH, and whatever source filter outputs it shouldn't bypass binarization of the frames.
Old 11th November 2020, 19:03   #105  |  Link
pinterf
"Bad gateway", expired perhaps?
pinterf is offline   Reply With Quote
Old 11th November 2020, 19:10   #106  |  Link
Same here, 502 Bad gateway. nginx.
Maybe that nginx thing is the block on your location for download, (cant remember what its called).
Can anybody launch successful download ?
EDIT: The Bad Gateway page is showing as Sweden in FlagFox. [dont know if relevant]
Old 11th November 2020, 19:48   #107  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Still works on my side. Here is another link: https://we.tl/t-J95N1CsfUz
Old 11th November 2020, 20:08   #108  |  Link
poisondeathray
LSmash has threads=blah parameter too. But non frame accurate runs will account for differences between repeated tests, when prefetch is used
I repeated test with x64 version - I think the problem is lsmash threads=auto vs. threads=1 for x64. I think it' s similar to the aforementioned ffms2 threads bug with prefetch
EDIT - multiple consec runs can result in different results, even with source filter threads=1 . One run can show PSNR inf, but another something lower. Something else is going on...
It even occurs when source is encoded to I-frame UTVideo, and using AVISource instead; multiple runs can show different results when prefetch is used. So not source filter related
Old 11th November 2020, 20:46   #109  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
I tested threads=1 like you did, only with 32bit and got one frame bugged, so bug is there with threads=1 too. It makes less chance for bug to occur, 5mins is too short test for this condition.
Looking at those bugged masks I think it's something with buffer/memory, just a guess, I'm not into lower level programming.
Old 11th November 2020, 20:48   #110  |  Link
poisondeathray
Yes, it's almost "random", see my edits above . One run can be perfect, but the next a few frames off, the next perfect again. It's not source filter related
Old 11th November 2020, 21:05   #111  |  Link
poisondeathray
If you change the script to use mt_merge (and full range YUV masks , PC matrix if converting from RGB), 10/10 runs are the same with prefetch=4. So that suggests it is something with overlay and prefetch
Old 11th November 2020, 21:51   #112  |  Link
pinterf
Here is my minimalized script.
# Load VirtualDub, Press F2, go to frame 2-3-4 and back, refresh, step between frames left and right
# suddenly a garbage is seen
DynamicMask = BlankClip(1000, 128, 128, pixel_type="RGB32")
WhiteClip   = BlankClip(DynamicMask,color=$FFFFFF)
BlackClip   = BlankClip(DynamicMask,color=$000000)
BlackClip.Overlay(WhiteClip, Mask=BlackClip)
Prefetch(4)
Thank you for giving me the opportunity to work on it
Old 12th November 2020, 11:09   #113  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Yep, Vdub2 reveals this bug on the first frames. Have fun with it.
Old 12th November 2020, 12:24   #114  |  Link
pinterf
Please check a (hopefully) fixed Avisynth build
Old 26th November 2020, 18:43   #115  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
There is some bug with high resolutions like 1920x1080 and AvsInpaint, if a mask is close to the left/right side then AvsInpaint hangs at start (no error).
Here is the bug simulator:
x=BlankClip(length=1000, width=1920, height=1080, color=$000000, pixel_type="YV12")
mask = BlankClip(x, length=1).Subtitle("Sample", text_color=$FFFFFF, x=8).Levels(180,1,181,0,255, coring=false)
# mask = BlankClip(x, length=1).Subtitle("Sample", text_color=$FFFFFF, x=519).Levels(180,1,181,0,255, coring=false) # Working position, moving the mask 1px to left("x=518") - hangs.
# x.InpaintLogo(mask, PreBlurSize=0.9, PostBlurSize=0.9)  # Droping the blur kernels to 0.9 - no hangs.
x.InpaintLogo(mask)
EDIT:
Bug should be fixed in AvsInpaint v1.3
Old 28th November 2020, 18:05   #116  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
New version released (updated the first post):
# Version 1.11 : 2019/08/31.  First public release.
# Version 1.12 : 2019/09/06.  Various tweaks. New parameters. "Inflate" and "Deep" changed.
# Version 1.13 : 2019/12/08.  Allow -ve LogoX,LogoY, and +ve LogoW,LogoH in Loc string (by StainlessS).
# Version 1.14 : [non public] "Fr1"/"Fr2" are renamed to "FrB"/"FrW". "GrainPP" is off by default.
# Version 1.15 : [non public] New mode for "InterpM", (-1) takes mask from new "iTune" parameter.
# Version 1.16 : [non public] New "diPP" & "diPPm" parameters.
# Version 1.17 : [non public] New "iTinflate" & "oTinflate" parameters. Interp/iTune mask to "mShow".
# Version 1.18 : [non public] New "EdgePP", "EdgePos" & "EdgeWide" parameters. EdgeMask to "mShow".
# Version 1.19 : [non public] New "IntSpd" parameter for "Interp" & the slow modes for "EdgePP".
# Version 1.20 : [non public] "Turbo" presets moved from soft to hard. iTune & Edge masks to "Show".
# Version 1.21 : [non public] Added support for the mask clips and a dynamic mask.
#                             Added basic auto generation of a dynamic mask (aka "DynMask=2").
#                             New parameters: "DynMask", "DynInflate", "DynTune", "KillNoise", "maskPatch".
# Version 1.22 : [non public] Optimized speed for a dynamic mask, MaskTools2 required.
# Version 1.23 : [non public] Added auto generation of a dynamic mask with ClipBlend (aka "DynMask=3").
#                             New parameters: "Dyn3Seq", "ClpBlend", "DynPostTune", "Dyn3buffer".
# Version 1.24 : 2020/11/28.  Various tweaks. "Show" 3 & 4. Updated the manual with the new stuff.
One example of the dynamic logo/delogo is in the thread there -> Detect Position of Watermark in movie and remove with logo inpaint
Originally Posted by real.finder View Post
maybe your script will help if it work with mask clip
Check if it helps anything.
Old 28th November 2020, 18:34   #117  |  Link
real.finder
thanks! but it's still in "Attachments Pending Approval", can you upload it else where?
See My Avisynth Stuff
Old 28th November 2020, 19:53   #118  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Here are screens for another dynamic logo removal:
12s GIF sample (stacked: original, dynamic mask, delogo output):
Old 28th November 2020, 22:11   #119  |  Link
manono
It's approved now. As I don't read every post in every forum, if you have something needing approval, you can PM me if you like.
Old 29th November 2020, 01:47   #120  |  Link
In your [@ VoodooFX] post #118 attachment [12s GIF sample], I earlier saw a white flash in bottom image part, it is now gone.
[maybe at end of repeated loop]
EDIT: attachment update, ? EDIT: your shit, is "The Shit" (well good man)
delogo, hardsubs, ocr, remove, watermark
