Old 17th May 2006, 17:05   #41  |  Link
juerginst
Great!!!
juerginst is offline   Reply With Quote
Old 9th September 2006, 07:16   #42  |  Link
IndieRockSteve
Originally Posted by Sharktooth
1500kbps is a good starting point for sources with good compressibility at 1280x720 @ 23.976fps.
Higher bitrates are needed if noise or grain is present or if compressibility is lower (action movies for example).
Obviosly that's subjective... but artifacts on HD stuff are much less visible.
Use a quality preset (like HQ-Slower for MeGUI) or if encoding time is a problem just rise the bitrate and use a faster preset.
Interesting. I want to do 1080i->1080p encodes of my HDTV captures, I'm less concerned with file size than I am with quality though. Whats a good bitrate to start at for this? Which of the matrices in your sig should I try with my encodes?
thanks! (and thanks for all your posts on this forum, lots of good reading!)
IndieRockSteve is offline   Reply With Quote
Old 9th September 2006, 07:27   #43  |  Link
Manao
If you're not concerned by the filesize, use a one pass crf encoding. Try value from 18 to 26, and choose the biggest value whose quality you still find acceptable. Then stick to that crf for all your encoding.
Manao is offline   Reply With Quote
Old 28th September 2006, 08:55   #44  |  Link
Romeo_by
Video encoding amateur
Does anybody can advice a source info about creating custom matrices or may be explain basicly how to do it?
Romeo_by is offline   Reply With Quote
Old 28th September 2006, 09:25   #45  |  Link
Audionut
Second result from a custom search.
http://forum.doom9.org/showthread.ph...ghlight=matrix
Old 23rd April 2008, 14:56   #46  |  Link
RickA
I know this is an old thread and I do not mean to resurrect it. I just wanted to thank you for this matrix Sharktooth. Tried to PM you this instead but it said your message box was full up.
What a great matrix you have created here. It really helped clear up the 'blockiness' I was getting in dark scenes of low detail. Such as the intro to Alien as they are spelling out the letters and panning across the planet. Even with Constant Quality of 17 and a sufficiently high bitrate I still had ugly blocky artifacts before using this matrix. I realize h264 has a tendency to go blocky in low detail and low lit areas, but EQM AVC-HR really cleared those up for me.
Since this matrix works so well on darkly lit low detail movies I take it that it is also fine to use on well lit low detail movies... as a precautionary measure? I'm new to h264, been playing with MeGUI and AutoMKV for a few weeks. My goal is to put my dvds on the computer hard disk for playback via tv and home sound system - a video jukebox if you will. A file size reduction of @30% and near source quality is what I am aiming for.
Once again, sorry for posting in an old thread. I debated whether to start a new thread just to say 'Thankyou' for the work you have done.
Cheers,
Rick
RickA is offline   Reply With Quote
Old 23rd April 2008, 15:06   #47  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
thanks for your kind words.
as the description says, EQM AVC-HR requires high bitrate and tends to force the codec to assign more bits in certain areas.
this behaviour has been discussed with the x264 devs and is not optimal, but indeed it helps a lot to avoid blocking.
yes, it works good even on "lit" details and if you feel confortable with how it looks, then feel free to use it but remember it needs more bits, that means if you encode in CRF or CQ it will take more disk space than normal.
Old 24th April 2008, 15:26   #48  |  Link
RickA
Greetings Sharktooth,
Thanks for responding to my EQM AVC-HR post. I am not fully sure on what you mean when you said 'if you feel comfortable with how it looks' would you please expand more on that? My newbie eyes have only detected a reduced blockiness of h264 in dark, low detailed areas. I have just started testing with your matrix. Is there something else I am missing with using your matrix and should be aware of? You also mention the matrix behavior and h264 as not being optimal. Are you referring to compressing the file size, or picture quality?
As far as the increased file size by using your matrix that is not as much of a concern for me as keeping video quality as close to source as possible. I am basically making a movie jukebox by putting my dvd's onto computer for playback via tv and home sound system. If I get near 30% file size reduction I am happy.
Thanks again.
Cheers,
Rick
Old 13th May 2008, 16:38   #49  |  Link
mpiper
Sharktooth,
I just downloaded your custom matrices, but being new to x264, I don't want to randomly use them with no idea of their purpose.
Can you possibly provide us with a simple description of suggested uses? Something like min/max bitrate, anime/clean/grainy source, fastmotion w/ high detail, details vs. banding, etc.
Thank you in advance!
Mike
mpiper is offline   Reply With Quote
Old 13th May 2008, 17:05   #50  |  Link
ToS_Maverick
x264 Tester
read two posts above yours:
for even more information, start at the beginning of this thread.
and there's another thread about matrices, if you're eager to read:
http://forum.doom9.org/showthread.php?t=117041
ToS_Maverick is offline   Reply With Quote
Old 17th July 2008, 10:57   #51  |  Link
henryho_hk
Do we have a "compressibility test" for MPEG4-AVC?
henryho_hk is offline   Reply With Quote
Old 17th July 2008, 11:28   #52  |  Link
Selur
Selur's Avatar
would it make sense?
Old 17th July 2008, 13:14   #53  |  Link
henryho_hk
Somehow, unless we have some general rules describing terms like "high bitrate", "difficult materials", etc. for MPEG4-AVC (say, with respect to x.264). I am asking myself questions like "how would this movie look like if I encode it into xxxMB using x.264?" I think something like a compressibility test would help.
Old 17th July 2008, 17:29   #54  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
compressibility test is like for xvid. except you have to use CRF 18 istead of CQ2.
also the avc matrices are really becoming obsolete and useless (at least for x264) since VAQ and Psy-RDO,
Old 18th July 2008, 00:26   #55  |  Link
henryho_hk
If we are doing a sampled compressibility test, do we need to discard the frames of "artificial" scene changes?
Old 18th July 2008, 16:32   #56  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
as a rule of thumb it would be better to discard them but the theoretical right way is just rising the patial comp.test compression value/percent by e few points to compensate the difference of partial encode scenechanges number vs the final encode scenechanges effective or approximated number.
Old 5th April 2009, 06:56   #57  |  Link
xxthink
Would you like to give some idear or papers about how to train a custom quantization matrix?
xxthink is offline   Reply With Quote
Old 5th April 2009, 14:02   #58  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
http://en.wikipedia.org/wiki/Quantiz...ge_compression
how to "train" depends on what you want to obtain once you got "how" quantization matrices work.
