3rd February 2005, 11:08 | #521 | Link |
No suggestion as to what it could be
Anyways, the self terminating installation left some files installed. When I try to uninstall it behaves in the same way and reboots all of a sudden.
I love CLI up to a point ... which is usually located somewhere below thirty character lines. |
3rd February 2005, 14:53 | #522 | Link | |
Mr. Sandman
If it still doesnt work just contact ahead and tell them to replace your serials coz one of them isnt working!
4th February 2005, 18:06 | #523 | Link |
I bought a retail version of Nero 6 - Ultra Edition (Office Max) Did a movie with Nero Digital and played it back with Nero Showtime. Then there was an update which I downloaded and installed and now Showtime will not play the Digital any longer. Says "cannot load, files missing" so I removed Showtime and redownloaded but still get the same error. Windows Media Player plays the disks without a problem.
When all else fails, follow instructions |
6th February 2005, 13:00 | #524 | Link |
great news ! do you remember my problem with visible blocks when playing AVC videos on my TV with the 6800GT s-video output ???!!! i thought there was an bug with nero recode. yesterday, i trided the same thing, but with DVD source (on tv with s-video output), and i have the same problem. it's good cause the prob doesn't come from AVC but from s-video output !!!
7th February 2005, 09:46 | #525 | Link |
Posts: n/a
1. When I Disable Resize, but cropping enabled (which was done by me in proper way so as to eliminate black borders on top and bottom), still the output video had black borders attached at top and bottom!
2. I Resized my anamorhic 16:9 dvd to 704X304 and enabled subtitles muxing, in the output video file, subs were little smaller in size than originals! 3. Is there any way to decide bitrate to be used, and what should be the resize according to bitrate? |
7th February 2005, 13:13 | #526 | Link | |
2. Well, the subs rendering is probably a bit different than in some other software, it's just a rendering issue, since we include the DVD's subtitle stream(s) as it is 3. Well.. when you use automatic resize, it does change the resize automatically relative to your chosen bitrate. Last edited by JohnV; 7th February 2005 at 13:16. |
7th February 2005, 20:28 | #527 | Link | |
JohnV should be able to confirm/deny this behavior. @JohnV: WRT blocks, I agree with Sharktooth--1 bframe mo' better. Thanks! |
7th February 2005, 20:59 | #528 | Link | ||
8th February 2005, 12:44 | #530 | Link | |
moron
9th February 2005, 16:44 | #531 | Link |
Posts: n/a
hi,
pls can anyone tell me which is the best option for dvd sources, keeping automatic smooth enabled or automatic sharp or enabling deblocking strength, also for dvd sources if enabled,what deblocking strength should be used?also, should i use pve for dvd sources? should i disable pve at higher bitrates? Last edited by neo_anderson; 9th February 2005 at 17:01. |
10th February 2005, 00:56 | #532 | Link |
moron
it is recommended by serveral rumors to run the MPEG4 AVC encoders with deblocking strength: '-2'. (so it applies to x264, too) Unfortunately I don't know how 'strong' is the deblocking when it set to -2, but it's true, that produces almost block free output in case of 1Mbps video rate when resolution left @720x576
14th February 2005, 08:23 | #534 | Link |
Posts: n/a
first of all, pls guys, if u find my questions annoying, don't kill me, i'm a newbie!
So, here it goes : For DVD encoding to avc/h.264 using nero recode 2, what should be the ideal bitrate range for a nice looking encode? What DeBlocking Strength Should be used, so that no blocks are visible in the output? In the guide for x264, doom says for 2 cd rips , stay close to 0.25 bpp, so, will nero also give great looking encodes when we chose high filesize? Also, what b-frames and refference frames should be used? Please someone do reply! Thanks....... |
14th February 2005, 19:44 | #535 | Link |
Mr. Sandman
@neo_anderson: keep the b-frames value at 1 and regarding reference frames: higher is better but slower. I'm usually satisfied with 5, someone likes even 15... the remaining settings depend on the source.
@johnv: so, when this "filter" update is coming?
14th February 2005, 19:53 | #537 | Link |
Mr. Sandman
a low motion movie will require less bitrate, an high motion more bitrate... if the movie is grainy then will hurt the compressibility...
now read again: IT DEPENDS ON THE SOURCE. So what are the best settings? finding them by yourself is the best way.
