1st April 2006, 09:55 | #581 | Link |
tritical, i encoded dvd anime the castle of cagliostro and deinterlaced it with TIVTC RC1 2pass. but why the frame on 2nd pass is fewer than 1st pass (140k vs 180k) ?
i dont remember exactly but the script was : mpeg2source("lupan.d2v") tfm().tdecimate() # (i forgot the parameter, but i copy exactly just like '2 pass anime hybrid' example you include on the package) crop() fft3dfilter() #default parameter limitedsharpen() #default paramater the result of 2nd pass is the video length is shorter than the source. source : 1 hour 40 minutes result : 1 hour 22 minutes what is wrong with my script? sorry, but i'm really new in encoding with avisynth |
1st April 2006, 10:51 | #582 | Link |
ангел смерти
Second pass should always be less frames; for films it'll usually be near 1/5 less (unless it's really hybrid). But it shouldn't be shorter! Sounds like something else is setting the framerate wrong. You're muxing it with the timecode file after encoding, right?
2nd April 2006, 08:16 | #583 | Link |
no, the result file was not muxed yet. i encoded it using Megui (in x264 r477 package). encoded the first pass first, then the 2nd pass(result file). i encoded it in full length of the film so the output file was only 1 (video only).
i know 2nd pass frame is fewer cause x264 warned me that 2nd frame is fewer. i played the result and it has a shorter duration. |
2nd April 2006, 21:32 | #584 | Link |
ангел смерти
Tritical, if you have time in the future, can you check on something for me? I get a lot of crashes using eedi2 on hi-res material ( > 500 lines or so, increasingly common the higher it goes, but sometimes it even works just fine on 2000 lines, eg, 1500x2000 images) in both yv12 and yuy2. They're not hard crashes, but Avisynth System Exception - Access Violations. I can provide samples where it consistently fails on almost every open (it usually works the first time, but not after), and if I dig around maybe less common ones. Trying it with a few large pics with imagesource should do it though.
Alternately, if it doesn't happen for you, I could try to debug, but I guess I'd need a debug avisynth? (I can make eedi2.) fft3d does this sometimes as well, which is why I suspect it's an out-of-memory error (although I have 2gb, I'm not sure what avisynth can access), just weird that it happens at all different sizes. |
3rd April 2006, 09:21 | #585 | Link |
[link removed], changes:
+ Added pp parameter and pp modes 1, 2, and 3 - A few minor internal changes - Fixed some documentation errors (field parameter) - do a vi.SetFieldBased(false) in constructor - fixed a bug causing reads past the last line and incorrect interpolation of the very top or very bottom line in some cases For debugging those types of errors it's probably the best/easiest if you can make a debug build of the filter + a debug build of avisynth and then open the script that causes the problem in vdub with the vs.net debugger running. Make sure it is set to break into the debugger on win32 exceptions. A debug build of avisynth also does some tracking of the values immediately before and after vfb's which can help catch outside writes. @aichan Did you get your problem worked out or no? The second pass having fewer frames is normal unless the entire video is hybrid like foxyshadis said. If you are doing a two pass encode with a codec then you'll need to run the first/second pass for the codec on the second tivtc script (I gather from your post that you ran the first pass on the first tivtc script and the second pass on the second script). Last edited by tritical; 7th June 2006 at 21:11. |
6th April 2006, 21:45 | #586 | Link |
In this thread:
http://forum.doom9.org/showthread.php?t=106837 I described the unique method I have devised for transferring film to video at a full 24 fps. The one sentence description of what is in that thread is that I remove the shutter from a 16mm film projector; videotape the output using a high shutter speed in the video camera; and then use modified IVTC software (TFM) to recover the original frames. Here is a link to a 5-second AVI sample of what the raw capture from the projector looks like. This is a free server, so the link will only be good for seven days. http://download.yousendit.com/4769F7937CBF6A84 This film transfer process always guarantees two good fields of video for each frame of film. The field immediately after the two good fields can either be: 1. A third duplicate (rare, but can happen). 2. A good field of the next frame of film. 3. A "bad" field showing the film in motion between frames. The TFM portion of TIVTC.dll is absolutely awesome, and the new parameters -- especially the metrics parameter -- have gotten me to the point where everything is almost working. However, I need help in two areas. First, is there a way to have TFM make its decisions on a modified version of the clip, but then operate on the original clip? Much of the film I am transferring has sections that were poorly exposed (low contrast). TFM's comb detection, which on normally-exposed film works well, fails on the portions that are low contrast. A solution to this problem is to use "Levels" to increase the contrast. (Actually, this improves detection even for normally exposed film.) However, I don't want to do the exposure correction in AVISynth, because I can do a far better job later in Vegas (my video editing program). Thus, I want TFM to do its detection based on a modified version of my clip, but than do its frame recovery on the original clip. Perfect comb detection is essential to this process because the only time it occurs is when a video frame contains a field that was captured during pulldown (#3 in my list above). If you download the clip, you'll see that these are normally very easy to see visually, and with normal contrast material, TFM catches them quite easily (although if the pulldown has just barely started, the combing can be pretty slight). I think I can write values to a file in one pass (using the "output" parameter) and then read them back in the next pass (using "input"), but I thought I'd ask if there is an easier way to handle this. The "clip2" parameter seems like it might be designed to do this, but I am not quite sure whether it can do what I am trying to do. Second, decimation in my film transfer system cannot strictly be "1 of n" because the ratio of the projector speed to camera capture speed is not synced and is not absolutely, perfectly constant. I can get pretty close using cycleR=9,cycle=44 in tdecimate, but I still end up with a few duplicate frames (obviously I want to err on the side of having duplicates rather than drops). My current solution is a real kludge: I write parameters to a file, and then based on those parameters, create a file that can be read by MultiDecimate. Given that AVISynth has to know the total number of frames when it loads a file, this may be the only way to make arbitrary decimation work, but I'd thought I'd ask. |
6th April 2006, 22:35 | #587 | Link |
AviSynth plugger
johnmeyer,
A little offtop, but do you know about my GetDups plugin?
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
6th April 2006, 22:49 | #588 | Link |
No I don't, which is surprising because I thought I had used everything you've ever written. I'll go right now to check and see what it does. |
6th April 2006, 23:20 | #589 | Link |
Very interesting plugin. It is close to what I was looking for, but it appears to be "hard-wired" for 16.67 fps. The projector I am using uses a synchronous motor that is set for 24 fps. Because of belt slippage, etc., it actually doesn't run precisely at that speed, so the decimation can't make any assumptions.
Even though I may not be able to use GetDups, I found HotSpot, which may help me eliminate the residual hot spot from the condenser/aerial lens arrangement I am using. |
7th April 2006, 01:30 | #590 | Link |
@johnmeyer
The clip2 parameter allows you to use deinterlaced frames from another source instead of using TFM's own postprocessing. I typically use this feature to postprocess my clips with EEDI2. However, it doesn't allow you to process a different video than the one you analyse. I'm not a programmer, but I don't think it would be too hard for Tritical to add this. Just go to his website and you can find his email at the bottom of the page.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
7th April 2006, 01:51 | #591 | Link |
I think I just about have this figured out. With all the new controls in the latest versions of TFM, coupled with the "new" (to me) "Output" capability, I can output all the TFM decisions to an external file. From this, using my own software, I create an input file that MultiDecimate can use in the second pass. Since the whole thing has to be two passes, I use the Levels filter to increase the contrast on the first pass in order to get MUCH improved field matching and comb detection. I then, in the second pass, use the identical script, but without the Levels filter, but WITH the Multidecimate filter, using the external file I created as input.
The only thing I haven't yet figured out how to do is to get TFM to use all the decisions that it made during the first pass. The problem is that without the Levels filter, TFM wants to choose different fields. I'm still stumped on that. Also, I'm posting elsewhere about a separate, smaller problem, namely that the film apparently wiggles sideways in the gate in the projector, sometimes causing the two good captured fields to not align. I need to figure out how to take each recovered frame from TFM and then re-align the two fields using Depan. I can get this to work field-to-field-to-field, but I don't want it to work between the second field of one frame and the first field of the next frame; I just want it to line up the two fields from one frame. Last edited by johnmeyer; 7th April 2006 at 02:15. |
7th April 2006, 02:55 | #592 | Link |
ангел смерти
input=YourOutputFile.txt
Thus, the results of the first pass are imported and no testing takes place (faster that way, too!). I'm glad to know I'm not the only one who does things to filters they were never meant for. |
7th April 2006, 04:30 | #593 | Link | |
Yes, I'm definitely using this in a way that wasn't intended. I have a "Workprinter" for transferring 8mm movies, but when it came time to do 16mm, I couldn't bring myself to spend $2,000 for the equivalent machine in the larger format. I started to build my own, but after I took out the projector's shutter and started to think about things, it became clear that once the projector shutter is gone, if you captured using a REALLY fast video camera shutter speed (e.g., 1/1000 second), you would be absolutely assured of getting two consecutive fields of video for each frame of film. As I looked at the timing diagrams I drew, they looked identical to the IVTC problem, and that's how I ended up here. The darn thing really works: "Workprinter" discrete frame film transfer, but at full 24 fps, including sound. My next step is to do the transfer with my HDV camera, something that cannot be done with workprinter (because HDV uses long GOP and therefore you cannot do frame-by-frame "grabs"). |
8th April 2006, 01:20 | #594 | Link |
Running tfm with output="" on the adjusted clip and then using the generated file as input when processing the normal one will work (it will use the matches and combed frame decisions from the input file). The one thing you will probably have to do is adjust the crc value stored in the file as it most likely wont match the non-adjusted clip. To get the crc for the non-adjusted clip use the output="" option to generate a file for it (it doesn't need to process any frames, just load the script in vdub and then close it). Once that file is generated just copy the crc value from it into the other output file. The crc value is computed from the first 15 frames of the clip.
8th April 2006, 02:13 | #595 | Link |
ангел смерти
Or just delete it like I do.
Anyway, Tritical, so far the new EEDI2 hasn't crashed on me yet, so I guess that was it. Thanks! I haven't strenuously tested it, if I do happen to catch anything later I'll give you a heads up. |
8th April 2006, 05:15 | #596 | Link |
@tritical
my 2pass problem not worked out yet, alternatively i used 1 pass NTSC hybrid. when i compare the picture quality,2 pass tivtc is better than 1pass. btw, 2pass tivtc script is mkv vfr right? but i used it on mp4, is that okay? i think yes, Megui detected it as hybrid film interlaced. i'm going to try your suggestion, doing the 2nd pass with 2nd tivtc script. but if i do this, what about the 1st pass tivtc script? thx |
8th April 2006, 21:01 | #597 | Link | ||
I forgot that deleting it would also work. For backwards compatibility with super old versions a crc value isn't strictly required to be present .
@aichan Quote:
1.) encode each fps section separately to mp4 and then concatenate them. 2.) use my tc2cfr program with the timecode file that tdecimate generates as input to generate a 120fps avi file. Then mux that avi file into mp4 which should remove the null frames. Of course, this method requires the video to be in the avi container. I would recommend reading http://www.avisynth.org/VariableFrameRateVideo if you haven't already. Quote:
1.) run 1st tivtc script - no codec pass 2.) run 2nd tivtc script - codec first pass 3.) run 2nd tivtc script - codec second pass which you were probably already doing. Last edited by tritical; 8th April 2006 at 21:04. |
9th April 2006, 19:22 | #598 | Link |
TFM: + minor field matching improvements + optimized postprocessing (mmx/sse2 cubic/blend deint, mmx/sse2 motion map creation, mmx/sse2 clip2 mask copy, faster link/denoise routines) + added ovr help information listing to bottom of output file - call setcachehints for clip2 when used TDecimate: - fixed opt parameter not be respected in the blurring functions used when predenoise=true RequestLinear: - fixed not testing if n <= rlim if the current request was <= to the last request (it was only testing if rall=true) Code:
1.) detected combed frames a.) frame #, mic value b.) ranges allowing small breaks with non-combed frames 2.) possible missed combed frames a.) frame #, mic value 3.) u/b and against order (either n or p) matches a.) frame #, match Last edited by tritical; 8th May 2006 at 13:57. |
10th April 2006, 10:08 | #599 | Link |
+ optimized combed frame detection functions (now match tivtc) + added second spatial combing metric and "metric" parameter (same as tfm and is/showcombeditvtc) + optimized denoise routines + improved the field comparison routine (now equal to slow=0 in tfm) + mode 2 uses the field comparison routine instead of full frame subtract for determining the best matching frame (more accurate) - directly assign frames from emask clip (no need to copy) - changed blim default to -2.0 (disabled) - call setcachehints for emask/edeint clips when used As far as tdeint/tivtc go, the following are left on the list of things to do: tdeint: 1.) possibly add slow=1/2 and mchroma field matching functionality so that tdeint matches tfm 2.) html doc tivtc: 1.) hclip for tdecimate hybrid=1/3 2.) fix bug in mmx routine 2.) html docs I would like to get that stuff done and release final versions sometime soon. I've made some improvements to eedi2 so there'll be a new version of that as well. After that I'm planning to finally get back to making a motion masking filter capable of producing longer masks (8 or more fields) to be used with tdeint via the emask parameter. Last edited by tritical; 5th October 2006 at 01:49. |
10th April 2006, 18:11 | #600 | Link |
I have a problem with TDeint. I'm using it to deinterlace an interlaced video, captured from a videogame with a capture card. It works wonderfully, except on some frames (pretty rare), that I found are normal interlaced frames, but repeated 2 times or 3 times, probably a bug when the stream was captured. The problem is that the 2 identical frames are interlaced, and handled like 2 different frames by tdeing, and it generates some very ugly artifacts... And if I just delete them, I have a sound that keeps getting more out of sync. Is there any parameter that can be used to not have this problem, or something I can do on the video before deinterlacing it? A perfect thing would be a parameter on tdeint that tells it to ignore a frame when it is perfectly identical to the last, and just output a duplicate deinterlaced frame (to keep sound sync). Anybody had this kind of problems? Thanks. |
tdeint, tivtc |
