7th January 2009, 14:46 | #5562 | Link | |
Leak was referring to the first, and you are referring to the last. There are 3 VMR9 possible modes of operation (More details here): -VMR9 Windowed -VMR9 Windowless -VMR9 Renderless You can use all this 3 modes in a window, or full screen, but only renderless allow the fullscreen exclusive access mode, like the games do. The question is if madshi tearing is when using mpc-hc in a window (when you have the borders, menus, title bar, etc. showing) and when activate fullscreen it disappears, or if it disappears only when he selects the exclusive access mode. |
7th January 2009, 14:50 | #5563 | Link | |
Kid for Today
anyhow, from what I've seen only HR does realtime jitter correction...the other software renderers simply drop frames if they're too late Last edited by leeperry; 7th January 2009 at 14:58. |
7th January 2009, 14:57 | #5564 | Link | |
MPC-HC 2.2.1 |
7th January 2009, 14:59 | #5565 | Link | ||
Maybe I didn't express myself clearly. I'm not talking about tearing in a window. I'm getting tearing even in normal fullscreen mode. It goes away only when using MPC HC's special "Direct3D fullscreen" mode. |
7th January 2009, 15:02 | #5567 | Link |
Does your display want PC levels (black at 0) or video levels (black at 16)? In the first case there's no way to get BTB/WTW. In the 2nd case you have to set ffdshow to RGB32 and in the "RGB conversion" tab under "contrast" you have to use "Full range".
7th January 2009, 15:05 | #5568 | Link | |
What's your OS? Have you tryed with an NVidia card? |
7th January 2009, 15:07 | #5569 | Link | |
P.S. Also the subtitles are flickering with internal splitter and vc-1 / DMO !
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 7th January 2009 at 15:11. |
7th January 2009, 15:10 | #5570 | Link |
Mobo: AOpen i945GTm-VHL (MoDT).
Graphics card: Club3D 3850 and Gigabyte 2600 Pro Yes. 53GB/s bandwidth. Should be plenty. XPSP2 Professional. Had a XFX 7600GS once. But that's long time ago. I *think* I had the same problems with it, too, but I don't remember for sure. I also once had a Fujitsu-Siemens mainboard. Same problems, as far as I remember... |
7th January 2009, 15:14 | #5571 | Link | |
MPC-HC Project Manager
Commercial video data does not contain BTB/WTW BTB/WTW is only needed for desktop |
7th January 2009, 15:19 | #5572 | Link | |
Kid for Today
you might try to fiddle around with your motherboard BIOS(disabling all unused ports, disable/enable spread spectrum etc), or simply change to a newer model...you could try with a cheap GA-EP31-DS3L it works perfectly fine, and is a complete steal |
7th January 2009, 15:44 | #5573 | Link | ||
7th January 2009, 15:47 | #5574 | Link | |
You're right! |
7th January 2009, 15:48 | #5575 | Link |
These methods of stopping tearing.... I still don't see them as being a perfect answer if your looking for smooth playback. OK no tearing but it doesn't mean the frames from your video content are synced with your refresh rate correctly....
Maybe reclock is the only answer to tearing + proper syncing? |
7th January 2009, 17:28 | #5576 | Link |
I was thinking that would be that... and let me guess, have you ever opened and initialized the Windows media player after upgrading to SP2?
I use ZoomPlayer and mpc-hc. When I had XP SP2, sometimes I had several problems when playing my media files. After a few minutes of playing, the video and audio started loosing sync. One time, I tryed reinstalling the SP2, and it fixed it. After a while it appeared again. I reinstalled SP2 and it fixed it again. I then realized that the problem was the Windows Media Player. It could not be used, not even initialized (after the SP2 update, if we run WMP always appear a brief tutorial of settings, this must be allways closed). I even had removed the shortcut from my quick launch bar because I could click it by mistake. I don't know if it would fix your tearing, but you could always give it a try and re-install SP2. Currently I use SP3, but before you try with SP3 do it with SP2. That, I am certain worked for me, SP3 I don't know. Now I realize that I should try re-installing SP3, because the last time I saw a movie the jerkiness was back... Yes, due to VC1 decoder, I have updated to WMP11, and have opened it... Remember that commercial video is YUV, and our displays are RGB. Only Y is limited to 16-235, UV is limited to 1-254, so, when you convert to RGB, you could get RGB lower than [16,16,16] and higher than [235,235,235] even if the YUV data is inside spec... And yes, some dvd's could have Y values out of those, but they are not out of spec, because it's not a hard limit, it's just reference values... Last edited by yesgrey; 7th January 2009 at 17:30. |
7th January 2009, 18:56 | #5578 | Link | |
Kid for Today
a wild guess would be that your mobo BIOS is either not properly configured, or badly optimized by the manufacturer himself. any change if you set the PCI-E speed to 115/120/125Hz ? sure is Last edited by leeperry; 7th January 2009 at 19:14. |
7th January 2009, 19:24 | #5580 | Link | |
Kid for Today
well maybe you could create another topic ? I really wonder where that tearing comes from, and the more testimonials the better....probably video data is not copied fast enough by the chipset, so your only option is to get a new mobo... |
