2nd August 2014, 11:56 | #1801 | Link |
Hi guys, quick question, with solely interlaced footage, in my avisynth script, do I need to add AssumeTFF() or AssumeBFF() depending on what DGIndex detects as the field order, or does it not matter at all, does QTGMC detect the field order anyway so I dont need those commands in, or do I have to have them in.
Currently I have an avisynth script each set up, one for TFF and another for BFF. Thanks |
2nd August 2014, 12:44 | #1803 | Link |
QTGMC will rely on the field order AviSynth assumes after loading the source clip.
Not all source filters are able to determine the field order correctly (e.g. AviSource will probably assume BFF because the AVI container does not flag it, each VfW codec may have its own default, and BFF is the most common default for DV in AVI); sometimes even the encoding studio flagged the material wrong. In general, better be safe than sorry (to have wasted hours due to QTGMC creating motion "holes" because the assumed order was wrong). Furthermore, never use QTGMC if there is no regular interlacing (e.g. don't use it on Telecine with 3:2 or worse pulldowns, or even on norm conversion results with blending). |
2nd August 2014, 13:03 | #1804 | Link |
Pig on the wing
Out of interest, what is a good way to bob when redoing blended crap? I've been using QTGMC since it provides good quality even with non-purely interlaced material. Maybe it's just some of the post-processing stuff there that works well, I don't know.
2nd August 2014, 14:00 | #1805 | Link | |
Dependiong on the root cause for the blending srestore() often helps. It might be a bit tricky (trial and error) to find the original (progressive) framerate if it is not compliant with one of the common (standard) rates. Blended fields are more difficult or hopeless to fix, I think .... |
2nd August 2014, 14:05 | #1806 | Link |
Pig on the wing
Oh, I meant preprocessing (=bobbing) the clip to feed to SRestore. SRestore itself works quite well in most cases if the pattern is constant.
2nd August 2014, 14:21 | #1807 | Link |
I normally use tdeint(mode=1) as a bobber,
or QTGMC(input type=0) followed by srestore(omode="pp3"), possibly followed by tdecimate() for removing double-blended fields. You may already have tried this though .... Last edited by Sharc; 2nd August 2014 at 14:44. Reason: mode=1 |
4th August 2014, 07:16 | #1808 | Link |
Hi, if I want a good analysis of source material I need to have trimmed my source from time to time. I usually use dvd shrink & use its cut feature but have read about programs not doing 'clean-cuts'.
Can someone recommend a 'clean-cutting' cutter?, thanks. |
4th August 2014, 07:23 | #1809 | Link |
For MPEG2 sources like on DVD Video: Cuttermaran or MPEG2Schnitt. They will be able to cut GOP-wise, or even frame-accurate with smart re-encoding if you use one of the MPEG2 encoder "provider" modules (e.g. for HC).
4th August 2014, 12:41 | #1811 | Link | |
Does your script work with blended fields from interlaced videos (resized without de-interlacing) ? |
4th August 2014, 19:33 | #1812 | Link | |
Both fields of a frame are blended.
Perhaps someone else could chime in .... |
10th August 2014, 19:19 | #1813 | Link | |
22nd September 2014, 22:11 | #1814 | Link |
Would it be normal for QTGMC to be slower when working with non-mod16 video than if it's mod16?
I've been re-encoding some old video which is mostly 720x576 and running QTGMC in progressive mode to clean it up a little. QTGMC(InputType=1, Ezdenoise=1) I noticed every so often one of the encodes would take much longer. A little investigating seems to indicate it's due to a mod4 width. If I resize to mod16 in the script before QTGMC the speed goes back to normal, but that's not ideal as I'm also resizing after QTGMC. It's not the end of the world and something I probably only noticed because the old dual-core I'm using is pretty slow anyway. When the resolution is 720x576 it only manages about 5.5fps, but CPU usage sits on 90%-100%. When the width is mod4 (ie 716x576) it drops to about 2.8fps and CPU usage hovers around 70%. There's a couple of encodes which I think ran even slower and they may have also had a mod4 height. I'd need to go back and do some more testing to confirm that. I've tried QTGMC 3.32 and 3.33. I've checked to see whether I'm still using the QTGMC recommended versions of the various plugins and went back to the recommended versions where I wasn't but that didn't seem to make any difference. Avisynth 2.6.0.4, Windows XP. Thanks. |
23rd September 2014, 07:10 | #1815 | Link |
Pig on the wing
It could be memory alignment playing tricks on you (see Crop in Avisynth's documentation). You could try using Crop with the align=true option to get around it. Or Crop(0,0,-0,-0,true) if you've already cropped the video elsewhere.
23rd September 2014, 08:04 | #1816 | Link |
Thanks Boulder.
I ran a test with a source video with a resolution of 716x576. With this script it runs at about 2.8fps LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll") FFVideoSource("E:\video.mkv", cachefile="D:\video.ffindex", fpsnum=25, fpsden=1, threads=1) crop(0,0,-0,-0,true) QTGMC(InputType=1, Ezdenoise=1) crop(4, 4, -4, -6) Spline36Resize(656,480) With this script it runs at 5.1fps LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll") FFVideoSource("E:\video.mkv", cachefile="D:\video.ffindex", fpsnum=25, fpsden=1, threads=1) Spline36Resize(720,576) QTGMC(InputType=1, Ezdenoise=1) crop(4, 4, -4, -6) Spline36Resize(656,480) I even tried a second PC (quadcore). Being slow and running in single threaded mode, I'd normally run two QTGMC encodes at the same time. When I do, the encode of the video with a mod16 resolution runs a fair bit faster (close to 2x) than the one with the mod4 resolution. I've tested without fpsnum=25, fpsden=1 and threads=1, but they don't seem to be causing it. QTGMC's Ezdenoise doesn't seem to be the culprit either. |
23rd September 2014, 08:25 | #1818 | Link | |
Several QTGMC options even require mod16; so, always best to pad your source up to mod16 to begin with, I'd say.
Gorgeous, delicious, deculture! |
23rd September 2014, 08:28 | #1819 | Link |
In the end, I've used this script to solve the slowdown problem, while wondering why I didn't just think of it in the first place......
LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll") FFVideoSource("E:\video.mkv", cachefile="D:\video.ffindex", fpsnum=25, fpsden=1, threads=1) AddBorders(4,0,0,0) QTGMC(InputType=1, Ezdenoise=1) crop(8, 4, -4, -6) Spline36Resize(656,480) I use QTGMC for noise reduction quite a bit and I've not paid much attention to the source video dimensions in the past. Next time I'll try something similar if the source isn't mod16 to test whether the speed difference is normal. Edit: I found the solution while you guys were suggesting it too, but I didn't see your posts until I submitted this one. Thanks! Last edited by hello_hello; 23rd September 2014 at 08:32. |
4th November 2014, 01:01 | #1820 | Link |
Kudos to the VapourSynth guys for getting QTGMC native. Wonder how well it works.
Just passing by to say hello - happy to see the script still being used. My avisynth development fell by the wayside when other things came up. Today I needed to do some video processing for first time in a long time. I found I didn't even have a working avisynth setup, lol. I seem to have lost the latest QTGMC version I had been working on. Probably for the best, it was getting even more complex... |
