29th August 2017, 11:27 | #45204 | Link | |
Soul Seeker
29th August 2017, 11:34 | #45206 | Link | |
Soul Seeker
00 ff ff ff ff ff ff 00 10 ac 8b 40 00 00 00 00 2e 16 01 04 a5 43 1c 78 3e ee 95 a3 54 4c 99 26 0f 50 54 25 4b 00 81 00 b3 00 71 4f 81 80 d1 c0 01 01 01 01 01 01 7e 48 00 e0 a0 38 1f 40 40 40 3a 00 80 0e 21 00 00 1a 74 55 00 a0 a0 38 25 40 30 20 3a 00 80 0e 21 00 00 1a 00 00 00 fc 00 44 45 4c 4c 20 55 32 39 31 33 57 4d 0a 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 ce 02 03 1d 40 50 90 05 04 03 02 07 16 01 06 11 12 15 13 14 1f 20 23 09 1f 07 83 01 00 00 02 3a 80 18 71 38 2d 40 58 2c 25 00 e0 0e 11 00 00 1e 01 1d 80 18 71 1c 16 20 58 2c 25 00 e0 87 10 00 00 9e 01 1d 00 72 51 d0 1e 20 6e 28 55 00 40 b4 10 00 00 1e 8c 0a d0 8a 20 e0 2d 10 10 3e 96 00 b4 78 00 00 00 18 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 e0 |
29th August 2017, 11:44 | #45208 | Link | |
Hi, sorry if I use a PM, but I don't know if I can publicly post this video: *in PM* . With that, my screen should change to 29.97Hz (which is supported, I just tested with another video), but it remains at 23.97Hz. In case is any useful, I have: Win8.1, AMD A6-4455M, smooth motion off, D3D11 exclusive. Thank you. Edit: what report? Last edited by a8213711; 29th August 2017 at 12:04. |
29th August 2017, 12:03 | #45210 | Link |
I have recently been trying D3D11 decoding, however it seems that either I get alot of repeated frames the first few seconds OR a couple of dropped frames (lag-like) in the first few minutes of pretty much every file I play.
Anyway to troubleshoot it/log it/test it? It didn't happen on DXVA2 (Copy-Back) Edit: is this possibly memory or CPU related? or not at all? Second Edit: on DXVA2 (Copy-Back) I had de-selected HW-Decoding for HD content and it also happens on HD content, on D3D11 I do use HW-Decoding for HD content. Last edited by Sarlaith; 29th August 2017 at 12:21. |
29th August 2017, 13:48 | #45211 | Link |
Just for the record. I have found that obsolete Haali has similar problem with crop, but it crashes imediatelly.
https://www.matroska.org/technical/specs/index.html There is, when you enter "crop" in search field some more information that would be possibly helpful to someone. But I know that this problem has very very low priority. Bernix |
29th August 2017, 14:38 | #45212 | Link | |
29th August 2017, 14:43 | #45213 | Link | ||
The flashing not working on your non-HDR monitor might be related, hopefully if you solve this you'll solve the other issue. What happens in HDR is that the last displayed frame is stuck, whether it's a black screen (first frame) or the last frame displayed in windowed mode if you go full screen > window > fullscreen. So the flashing not working on your non-HDR monitor might indicate a similar problem, the last displayed frame stuck. This is the only file causing such issue here, so if it's not representative of a wider bug it's safe to let it go, it might just be an issue with the file mastering. However, the same file plays fine on the UB900 (that's how I've been using it until now) so it's not an issue with all players.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
29th August 2017, 15:46 | #45214 | Link |
Is HDR data independent from the bit depth of the video (number of steps between each color)? Can be displayed correctly theoretically a 12-bit encoded HDR video which has the same HDR metadata as the source file which was 10 bit encoded?
Would appreciate any help. |
29th August 2017, 15:47 | #45215 | Link | |
I just played these 3 files over and over from demo-uhd3d The_World_in_HDR_in_4K_HDR10 Sony_4K_HDR_Camp LG_Chess_HDR Pretty standard clips for testing. I was on madvr 0.92.1. |
29th August 2017, 16:35 | #45217 | Link |
Slightly offtopic but a quick note for anyone interested in HDR test patterns.
There is ongoing development of free HDR10 patterns set by video enthusiasts for other enthusiasts. Current version is here: https://yadi.sk/d/RPrX2C7l3HEjPq There is no guide/readme or separate forum discussion topic for now but we've tried to keep file names self-explanatory. Hope it could be useful! |
29th August 2017, 17:43 | #45218 | Link | ||||
Yes, it's independent. Quote:
29th August 2017, 18:26 | #45220 | Link |
I do this all the time. What issues do you have?
madVR options explained |
