20th April 2018, 08:56 | #50281 | Link |
I just exchanged my GTX 1070 from my Htpc to my gamig rig. My RX480 is now back in my htpc.
Is there anything I need to know in regards to madvr? I know that it is not as powerful as the gtx1070 with NGU. What about automatic switching with hdr files? does this work differently with amd cards?
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64) LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set |
20th April 2018, 14:05 | #50285 | Link | |
Hi, what do you mean you need the latest nightly, DIRECT3D 11 has been working for ages on my system, its required for HDR to work. What does it fix? |
20th April 2018, 14:41 | #50286 | Link |
Hi, there are a few used RX580 cards now on ebay for around £200 so prices have come down a little, they are all 4gig though, I currently have a 4 gig RX 460, can anyone hazzard a guess how much more MADVR grunt i'll get from this, roughly as a percentage, trying to work out if its worth selling the RX460 and getting one.
20th April 2018, 16:31 | #50287 | Link | |
20th April 2018, 18:16 | #50290 | Link |
No, 4GB of VRAM is just the right amount.
20th April 2018, 20:47 | #50292 | Link | |
20th April 2018, 23:23 | #50295 | Link | |
GTX1660Ti 6GB, H270M, i5-7500 3.4GHz, 16GB PC4-19200,Win10 Pro 64, JriverMC, Silicondust Tv Tuners, Denon AVRX2200, Sony XBR-Z9D |
20th April 2018, 23:51 | #50296 | Link |
The Vega 11 iGPU can do NGU low luma doubling from 1080p -> 4K. I'm not sure if that's good or not. It's about as powerful as a GT 1030, so you'd have to know what the GT 1030 can do.
21st April 2018, 00:03 | #50297 | Link | |
madVR options explained |
21st April 2018, 00:16 | #50298 | Link | |
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 21st April 2018 at 01:38. |
21st April 2018, 00:22 | #50299 | Link |
Yay! I got the green check mark. Running at 4k now. Initial testing looks very good. Thanks so much.
21st April 2018, 15:19 | #50300 | Link | ||
With some older driver branch - don't remember which one - I had kind of the same issue you have, with clipping. I had to set the GPU (and TV of course) to Limited to get it fixed permanently but of course you then lose in picture quality. Is YCbCr the only mode that fixes it on your TV, or does RGB Limited works too? Do you by any chance have another device to test with? If you have an NVIDIA, try changing the "Content type reported to the display" setting and see if it changes something. When I had that issue with NVIDIA drivers, changing that option to literally anything else than the one currently selected fixed the problem until the next display resync, at which point I had to change it again. The problem was then fixed in the following driver branch.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
