Old 10th June 2009, 19:38   #8961  |  Link
DoomBot
Is better use wav than pcm like intermediate file to obtain a w64 accepted by TsMuxer.
So i shouldn't have any problems with a seamless branching movie with no over gaps using wav output?
DoomBot is offline
Old 10th June 2009, 20:15   #8962  |  Link
TinTime
I always convert TrueHD to wav with eac3to and haven't encountered any problems, seamless branching movie or otherwise. The only possible issue is the one that eac3to warns you about - oversized (>2GB) wav files. As you're converting the wav to w64 with eac3to that doesn't matter though as it handles large wavs.
Converting truehd to either pcm, wav, or w64 there isn't any quality loss its bit for bit correct? there all doing the same thing?
Yep. As tebasuna51 said wav is the best bet for an intermediate file in this case (it's just pcm data with a header describing it stuck at the front).
TinTime is offline
Old 10th June 2009, 20:18   #8963  |  Link
DoomBot
Thanks for your response that's exactly what i wanted to hear.
DoomBot is offline
Old 11th June 2009, 22:46   #8964  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
TSmuxer also accepts large .wavs. I tried 7GB wav and it was correctly muxed to .m2ts So in fact we don't have to use .w64 for now.
Atak_Snajpera is offline
Old 12th June 2009, 01:35   #8965  |  Link
wildchild22
When eac3to outputs wavs all I used to get was sound for the first 15-30 minutes then white noise.
wildchild22 is offline
Old 12th June 2009, 01:50   #8966  |  Link
tebasuna51
tebasuna51's Avatar
If is correct is a new and undocumented feature. But this is the eac3to thread.
The audio data in wav is ok, maybe your player can't play it.
There are many soft to manage wav files >4GB (encoders, AviSynth, ...)
tebasuna51 is offline
Old 13th June 2009, 13:40   #8967  |  Link
Tarnatos
DTS-ES Matix demux
Hello,
i have a problem with dts-es matrixed files.
If i try to create the waves from the source file with:
X:\temp>eac3to demo.dts c:\temp\demo.wavs
DTS-ES, 5.1 channels, 0:01:55, 16 bits, 755kbps, 48khz
Decoding with ArcSoft DTS Decoder...
Patching bitdepth to 24 bits...
Writing WAVs...
Creating file "c:\temp\demo.R.wav"...
Creating file "c:\temp\demo.L.wav"...
Creating file "c:\temp\demo.C.wav"...
Creating file "c:\temp\demo.SL.wav"...
Creating file "c:\temp\demo.LFE.wav"...
Creating file "c:\temp\demo.SR.wav"...
Everthing works fine.
But i want that 7th channel so i use the -7 cmd to force the extraction.
But i doesn't work:
X:\temp>eac3to demo.dts c:\temp\demo.wavs -7
Writing WAVs...
Eac3to only creates a log file and interrups.
Here the content of the log file:
eac3to v3.16
command line: eac3to demo.dts c:\temp\demo.wavs -7
Writing WAVs...
Every other file i had tested worked fine.
Here is a little part of that file so you can test by yourselves.
DL: http://rapidshare.com/files/244067335/demo.dts
##EDIT
With Sonic it doen't work, too!
eac3to demo.dts demo.wavs -sonic
Decoding with DirectShow (Sonic Audio Decoder)...
DirectShow reports 5.1 channels, 24 bits, 48khz
Writing WAVs...
Creating file "demo.L.wav"...
Creating file "demo.SL.wav"...
Creating file "demo.LFE.wav"...
Creating file "demo.C.wav"...
Creating file "demo.SR.wav"...
Creating file "demo.R.wav"...
eac3to demo.dts demo.wavs -sonic -7
Writing WAVs...
With libAv it's the same. Only 6 channels.
Greetings
-Tarnatos
Tarnatos is offline
Old 13th June 2009, 20:35   #8968  |  Link
aleg
Is it possible to downmix a 2/2 recording (an old quadrophonics with L-R-SL-SR) to stereo?
The -down2 option leaves it as a 4-channel recording.
aleg is offline
Old 13th June 2009, 23:19   #8969  |  Link
tebasuna51
tebasuna51's Avatar
-7 don't force to extract 7 channel (-7 means the pcm input have 7 channels)
Like you see is a 5.1 and the BackCenter channel is an analog matrix mix in BackLeft and BackRight channels.
There are other kind of DTS-ES with a discrete BackCenter than can be extracted, eac3to inform with this message:
DTS-ES, 6.1 channels, 0:00:22, 16 bits, 1510kbps, 48khz
Old 14th June 2009, 09:23   #8970  |  Link
Tarnatos
Than it is not possible to extract the matrixed backcenter channel?
Greetings
-Tarnatos
Tarnatos is offline
Old 14th June 2009, 10:27   #8971  |  Link
tebasuna51
tebasuna51's Avatar
For what?
You can play the 5.1 and the phantom BackCenter is there.
BTW, you can try to make a stereo with BL,BR and use a dpl decoder to 5.0, the new FL' is the original BL, the new FC' the original BC, and the new FR' the original BR (the news BL', BR' must be empty).
To do this conversion you can use Foobar2000 and the foo_dsp_fsurround.dll plugin.
Old 14th June 2009, 12:50   #8972  |  Link
cybpsy
Hello!
I'm using eac3to 3.16. I have 7.1 TrueHD audio track. I'm trying to recode it to flac or to wavs, but I get such error:
eac3to.exe 00003.track_4352.ac3 audio.wavs
TrueHD/AC3, 7.1 channels, 48khz, dialnorm: -27dB
(embedded: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB)
Extracting TrueHD stream...
Removing TrueHD dialog normalization...
Decoding with libav/ffmpeg...
Remapping channels...
Writing WAVs...
libav Invalid channel 13 specified as output from matrix
The libav decoder reported an error while decoding.
Aborted at file position 262144.
I understand that it's problem of audio track or decoder, but may be there is some work around in eac3to?
I've made sample of the audio: http://rapidshare.com/files/24440854...track_4352.ac3 (105 MB)
cybpsy is offline
Old 14th June 2009, 16:38   #8973  |  Link
tebasuna51
tebasuna51's Avatar
Or maybe the tool used to extract the track (.ac3 with thd content?).
Let eac3to extract the track to the flac or wavs from the container.
Old 14th June 2009, 22:55   #8974  |  Link
cybpsy
The track is .ac3 only because it was demuxed by tsmuxer. I have also tried eac3to in two ways: decoding from BD directly and demuxing from BD (thd+ac3) and decoding to flac or wavs. Just the same error.
cybpsy is offline
Old 15th June 2009, 00:00   #8975  |  Link
tebasuna51
tebasuna51's Avatar
But eac3to can't imagine a TrueHD when say:
Then the stream is corrupt
Old 15th June 2009, 04:10   #8976  |  Link
odin24
odin24's Avatar
Location: The Great North (the better half of North America)
Strange error
Has anybody encountered this before? If so, is there anyway around it? I've examined all of the m2ts files in the two playlists with tsMuxeR, each branch has identical streams within the whole playlist... both 1) and 2).
odin24 is offline
Old 15th June 2009, 05:31   #8977  |  Link
setarip_old
setarip_old's Avatar
There are two observable differences:
1) A total 13 second time difference
2) Different sequence of the audio tracks
What is the title of your BluRay disc?
setarip_old is offline
Old 15th June 2009, 07:52   #8978  |  Link
mrr19121970
@odin24
why have you blanked out your name in 3 out of 4 C:\Users\XXXXX> ?
and yes, I saw it yesterday. With the 'March of the Pengiuns' German version, Kinowelt have added a 13 second trailer to the start of the film. There were 3 playlists all with 00026.mts (from memory). The chapter points are different.
1) 1:22:26 mins long one with the trailer.
2) can't remember
3) 1:22:15 mins long - was clearly the original film without the trailer
However on demuxing either 1) or 3) I always got the longest version.
Here are the logs...
eac3to v3.16
command line: "E:\TVIX\Clown_BD\eac3to\eac3to.exe" "s:\" -LOG="D:\DEMUX\March of the Penguins\eac3to_PASS1_LOG.LOG"
1) 00027.mpls, 00026.m2ts, 1:22:29
- Chapters, 12 chapters
- VC-1, 1080i50 (16:9)
- DTS Hi-Res, German, multi-channel, 48khz
- DTS, French, multi-channel, 48khz
- DTS, German, multi-channel, 48khz
- AC3, German, stereo, 48khz
- AC3, French, stereo, 48khz
2) 00037.mpls, 00026.m2ts, 1:22:16
3) 00028.mpls, 00026.m2ts, 1:22:15
4) 00002.mpls, 00002.m2ts, 0:52:50
- MPEG2, 576i50 (16:9)
5) 00005.mpls, 00005.m2ts, 0:52:49
6) 00004.mpls, 00004.m2ts, 0:46:03
7) 00038.mpls, 0:32:49
[14+10+17+12+13+21+24+18+11+23+25+20+16+15+9+19+22].m2ts
- Chapters, 17 chapters
8) 00003.mpls, 00003.m2ts, 0:19:21
- MPEG2, 576i50 (4:3)
mrr19121970 is offline
Old 15th June 2009, 10:37   #8979  |  Link
BZeeme
I get the same results as you using eac3to on CJ7. I'm trying to back it up using BD Rebuilder (movie only). The movie only result would play with PowerDvD but not my Sony standalone (audio, subtitles, but no video).
BZeeme is offline
Old 15th June 2009, 11:40   #8980  |  Link
pascalwil
Using Nero AAC decoder in eac3to
Originally Posted by poisondeathray View Post
From Page 1:
I do have Nero 7.0.8.2 and the Blu-ray/HD-DVD plug-in registered.
I can use Nero WaveEditor or Nero Burning ROM to convert a 5.1 AAC file to a 5.1 AC3 file but I can't seem to be able to get eac3to to use the Nero AAC decoder to do the same job. I wonder what I've done wrong. eac3to reports the following:
eac3to v3.16
command line: "G:\Bin\eac3to316\eac3to.exe" -test
eac3to (v3.16) is installed
Nero Audio Decoder (Nero 6 or older) doesn't seem to be installed
http://www.nero.com/eng/store-blu-ray.html
CAUTION: You need Nero 7. Nero 8 won't work with eac3to.
ArcSoft DTS Decoder (1.1.0.0) works fine
Sonic Audio Decoder (4.3.0.169) works fine
Haali Matroska Muxer doesn't seem to be installed
http://haali.net/mkv
Nero AAC Encoder (1.3.3.0) is up to date
Surcode DTS Encoder (1.0.21.0) is installed
MkvToolnix (2.2.0.0, 2008-03-04) is installed
Of course I can use Sonic but I would love to use Nero inside eac3to. Can someone help? Many thanks.
And the log gives:
eac3to v3.16
command line: "G:\Bin\eac3to316\eac3to.exe" "Y:\Music (Video)\Movie\Original - x264\Movie - en-English.aac" "Y:\Music (Video)\Movie\Original - x264\Movie - 2005 - en-English - eac3to 3.16 with GUI - nero.ac3" -384 -nero
AAC, 5.1 channels, 48khz
I'd like to use the Nero decoder, but it doesn't seem to work. <ERROR>
Madshi could you tell us a little bit on how eac3to checks for Nero Audio Decoder installation?
Maybe with some inputs from you I could check whether I meet your requirements. Thanks.
pascalwil is offline
eac3to
