Old 14th December 2004, 19:29   #121  |  Link
tritical
In a word, yep . The main things that make it so much slower are:
1.) by default decimate only checks luma while tdecimate checks both luma and chroma (set quality = 3 in decimate to sample both)
2.) tdecimate uses overlapping blocks while decimate doesn't
3.) tdecimate can use user defined block sizes in metric calculations (the blockx and blocky parameters) while decimate uses fixed 32x32 blocks
I am suprised it was that much of a drop off, though it would make more difference with larger frame sizes. I could try adding a quality setting like decimate has (to do subsampling) or having a metrics mode that does not use overlapping blocks or both. Though then tdecimate would be pretty much the same as decimate for most similar 1-in-N non-hybrid cases.
tritical is offline   Reply With Quote
Old 14th December 2004, 19:38   #122  |  Link
BangoO
Thx for the fast answer
It would be nice to have a TDecimate as fast as Decimate, but then it would be Decimate... so...
I'll try playing with Decimate() parameters to check if I can get something perfect.
It works perfectly 99% of the time, TDecimate worked on the last 1%, too bad
BangoO is offline   Reply With Quote
Old 15th December 2004, 05:45   #123  |  Link
tritical
[link removed, look farther down], changes:
  TDecimate:
      - Fixed problems with longest string decimation and static to
           panning and panning to static scene workarounds in longest
           string decimation
      + added se parameter (causes mode 3 to stop early once the last
           actual frame is delivered)
      + mmx and sse2 blending routines now work with any width (not
           just mod 8 and mod 16)
This version should fix all problems with longest string decimation and correctly handle Leak's clip (whichever way it is decoded ).
Old 15th December 2004, 15:00   #124  |  Link
BangoO
triptical, I have a file (29.97fps 3:2 pattern, that I'm trying to IVTC) with a glitch in the middle resulting in a field order change (bff to tff).
When I was using Telecide, my script looked like that:
Loadplugin("C:\Program Files\AVIsynth 2.5\plugins\mpeg2dec3.dll")
a = trim(mpeg2source("D:\test.d2v"),0,80192)
b = trim(mpeg2source("D:\test.d2v"),80193,0)
a = Telecide(a,order=0,guide=1,post=2)
a = Decimate(a)
b = Telecide(b,order=1,guide=1,post=2)
b = Decimate(b)
return a + b
So, with your filters, I thought I could use:
Loadplugin("C:\Program Files\AVIsynth 2.5\plugins\TIVTC\TIVTC.dll")
a = TFM(a,order=0)
a = Decimate(a)
b = TFM(b,order=1)
b = Decimate(b)
return a + b
But it does not work, the second part of the clip goes "forward and backward".
So I tried this:
TFM()
Decimate()
But it displays lots of interlaced frames in the second part since the field order is wrong.
So, then, I tried to play with the options of TFM and tried this:
TFM(mode=3)
Decimate()
It seems to work just fine, and does not care about the field order.
What do you think about all this ?
Thx again
PS: I'm using TIVTCv095.
Old 15th December 2004, 18:48   #125  |  Link
tritical
Not really sure off hand, but I do have a couple questions:
First, in this script where the second part is messed up:
a = TFM(a,order=0)
a = Decimate(a)
b = TFM(b,order=1)
b = Decimate(b)
return a + b
If you set order = 0 in the second TFM call does it also produce bad results on the second part?
Second, if you use this script:
TFM(d2v="D:\test.d2v")
Decimate()
Does TFM pop up an error about illegal transitions? If so, does the resulting fixed d2v file produce correct output with that script?
Also, the reason setting mode=3 seems to fix things is because, as you said, it really doesn't care about the field order since mode 3 does 3-way matching.
Old 15th December 2004, 19:24   #126  |  Link
BangoO
Yes it does.
It does pop up an error about illegal transition, and the fixed d2v works !
This is GREAT !
Just so I know, what does it fix in the d2v so that the field order is now the same all along ?
I'm concerned about this as I don't want to loose some frames even if they look like crap because of the glitch, otherwise the sound will be off synch.
Old 15th December 2004, 19:25   #127  |  Link
Dreassica
Or use dgindex to create d2v, since that fixes fieldorder changes.
Dreassica is offline   Reply With Quote
Old 15th December 2004, 21:28   #128  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Yes, it does...
Now, how Bandai managed to b0rk the telecine in this part so there's a cycle of 5 frames with no dup right after the cycle containing the scene change (with the pan going at the same speed per new frame as in the cycles after it) so that it'll pan faster during that cycle when viewing it on a TV is beyond me - now IVTC would have to drop a frame that really isn't a dup or blend the frames down, but what can you do?
It plays smoother with conCycle=1, though, so I'll use that. Also, Last Exile for instance had a few blend transitions where they faded quickly from one pan into another with the telecine patterns not matching up where blending down looked much better (it's a fade after all) than a dropped field in the middle...
np: Autechre - PIOBmx19 (Garbage)
Leak is offline   Reply With Quote
Old 15th December 2004, 22:58   #129  |  Link
tritical
Actually, dgindex can still produce d2vs with illegal transitions... though the only time I've seen them is on vob boundaries. Also, I don't think dgfix, which only supports dgindex's d2vs, would be included with dgindex if it never suffered from this problem?
It changes the rff flags in places where two consecutive top or bottom fields are called for (which is what changes the order). It wont cause any syncing problems, a single field may be added (repeated) or eliminated (not repeated) at each of the illegal transition points, but that is it. So no frames will be dropped or anything like that. For more info look here.
Old 16th December 2004, 09:37   #130  |  Link
BangoO
Ok, thx a lot for those explanations, and for those great filters
Old 17th December 2004, 05:46   #131  |  Link
acrespo
Brazilian Anime Ripper
I have too many jagged lines with TFM. I already tried all modes but I have the same ammount of jagged lines to all modes.
My source is anime (Inuyasha TV Episodes).
My actual script is:
LoadPlugin("d:\encodes\filtros\removegrain.dll")
LoadPlugin("d:\encodes\filtros\removedirt.dll")
LoadPlugin("d:\encodes\filtros\dup.dll")
LoadPlugin("d:\encodes\filtros\dgdecode.dll")
LoadPlugin("d:\encodes\filtros\mpasource.dll")
LoadPlugin("d:\encodes\filtros\masktools-v1.5.5.dll")
LoadPlugin("d:\encodes\filtros\tivtc.dll")
LoadPlugin("d:\encodes\filtros\degrainmedian.dll")
LoadPlugin("d:\encodes\filtros\mvtools.dll")
LoadPlugin("d:\encodes\filtros\hqdn3d.dll")
import("d:\encodes\filtros\degrainMC.avs")
import("d:\encodes\filtros\LimitedSharpen.avs")
import("d:\encodes\filtros\FastLineDarken_1.3.avs")
video=MPEG2Source("d:\inuyasha117.d2v")
audio=MPASource("d:\inuyasha117.mpa")
AudioDub(video,audio)
Trim(107,10213)++Trim(10369,21066)++Trim(21224,36415)
TFM(mode=1)
TDecimate(mode=1,hybrid=1)
Crop(2,18,-6,-16,align=true)
LimitedSharpen(dest_x=320,dest_y=240)
DeGrainMC()
hqdn3d()
FastLineDarken()
dup(threshold=1,blend=true,maxcopies=8)
Capture cards:
Compro VideoMate Gold+ (Philips SAA7134 based) (not active)
Hauppauge PVR 150MCE (not active)
ATI TV Wonder Elite (active)
acrespo is offline   Reply With Quote
Old 17th December 2004, 12:06   #132  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
could you post a small sample of the m2v where it exhibits this problem?
i've noticed that some telecines are inherently a little jaggy (though not as bad as you get from field-discarding), like Evangelion Platinum (better than the old release, but could be better) and Serial Experiments Lain. so even with correctly matched fields there might still be some jaggyness from a rough telecine.
Old 17th December 2004, 13:41   #133  |  Link
Didée
DeGrainMC()
hqdn3d()
FastLineDarken()
Ouch, the pain.
Jagginess might come from applying too much filtering on a *too small resolution*. I'd have a particular suspect on FastLineDarken for that respect.
And instead of calling LimitedSharpen before all those denoisers, you can completely drop it as well and spare its CPU time: everything it has done will be 100% destroyed by the aftercoming filters ...
What about
DeGrainMC()
hqdn3d()
FastLineDarken()
Old 17th December 2004, 14:09   #134  |  Link
acrespo
No, it's not the filters, because I tried Kernelbob+BlendBob and the problem is not occurring.
The jagged problem is really from TFM.
Capture cards:
Old 17th December 2004, 20:42   #135  |  Link
ObiKenobi
Posts: n/a
Try turning off postprocessing and see if that helps.
Old 17th December 2004, 22:26   #136  |  Link
acrespo
Yes!! PP=0 resolve the jagged problem but I need PP because I have too many interlaced parts now. What can I do?
Capture cards:
Old 18th December 2004, 00:41   #137  |  Link
tritical
@acrespo
Could you provide some more information, such as if the problem is there are too many false combed frame detections (in which case try setting chroma=false), or if combed frame detections are ok but you just don't like the results from cubic deinterlacing (in which case try using PP = 5 for blending or PP = 7 for ela). Using display=true in tfm could help with determining which is the case. If you could provide a small sample clip that would be even better.
@All
Well there was another problem with hybrid detection, it was from not correctly differentiating between deinterlaced frames and c matches when checking for duplicates via matches in tdecimate. It would cause some cycles that had combed frames that were deinterlaced to not be detected as video when they should have been. Also, I haven't been invoking a cache between TFM and TFMPP when PP>4, which was making things slower when frames needed deinterlacing.
On the non bug related side, I've added handling for the case when 2 dups need to be dropped when there's a change from a panning scene to another panning scene. In the case of vfr (hybrid=2) both dups are dropped and the timecodes are adjusted for that cycle to compensate and in the cfr case either 1.) both dups are dropped and the frame before the scenechange is repeated or 2.) if tdecimate doesn't know exactly where the scenechange is it drops the lowest metric frame and replaces the other with a blend of its two neighbors. If anyone has any other ideas or suggestions for what to do in such a case feel free to post them.
Old 18th December 2004, 17:50   #138  |  Link
Leak
Leak's Avatar
Would you happen to have a link for your latest version? If nothing terrible happens tomorrow, I'm going to dig into it and try to come up with some MMX/SSE/SSE2 code - which probably would be a good idea to do on the latest code...
np: Autechre - Dial (Gantz Graf EP)
Old 19th December 2004, 09:14   #139  |  Link
DarkNite
Almost Silent Member
DarkNite's Avatar
Just wanted to drop in and say that I've been getting great results with TIVTC. TFM is working well and TDecimate is coming along great.
Keep up the good work, and best of luck on future optimizations.
Rethinking the "Why?" chromosome.
DarkNite is offline   Reply With Quote
Old 20th December 2004, 08:05   #140  |  Link
tritical
Was gonna post this last time, but there was one lingering problem I didn't get fixed before I had to leave. So here is [link removed, look farther down], pretty much just the changes/fixes mentioned before:
   TFM:
      - Fixed not invoking a cache between TFM and TFMPP when PP > 4
      + Some internal additions to allow TDecimate to tell the
           difference between c matches and deinterlaced frames
      + Added debug output to d2v checking... when debug=true and a
           d2v file is specified it will report the type of d2v
           detected, the detected field order from the d2v if order = -1,
           and report the errors if any are found
   TDecimate:
      - Fixed not differentiating between c matches and deinterlaced
           frames when hybrid > 0 and checking for dups via matches
      - Fixed crash with debug=true and large cycles (> 50) due to
           too small of a string buffer
      - Changed default sceneThresh to 13
      - conCycle and conCycleTP now default to 1 when vidDetect = 3
           and still default to 2 when vidDetect != 3
      + Added handling for cycles around scene changes which need 2
           dups removed
      + Some other internal changes
@DarkNite
Thanks for the comments, glad to see someone got some use out of it, and hopefully Leak will work some mmx/isse magic to improve the speed a little.
tdeint, tivtc
