Old 7th August 2005, 06:39   #281  |  Link
Moitah
Does anyone else see a bunch of green stuff when using TDeint(type=1) with TDeintv1b3? Source frame, After TDeint(type=1) (Sorry they are a bit blurred from the JPG compression)
moitah.net
Moitah is offline   Reply With Quote
Old 8th August 2005, 03:01   #282  |  Link
tritical
Yep, it is a bug in YUY2 type=1 chroma interpolation... forgot to change three lines when ap was added in beta 3. All the YV12 routines and all the other YUY2 routines are ok. I'll try and fix that soon. Thanks for reporting.
tritical is offline   Reply With Quote
Old 11th August 2005, 06:35   #283  |  Link
acrespo
Brazilian Anime Ripper
Can I trim video before use TFM with flags= 0 to 2 like this:
mpeg2source("smx.d2v")
Trim(449,32701)++Trim(35087,47956)
TFM(d2v="smx.d2v",mode=3,pp=7,slow=2,chroma=true,flags=3)
TDecimate(mode=1,hybrid=1)
Capture cards:
Compro VideoMate Gold+ (Philips SAA7134 based) (not active)
Hauppauge PVR 150MCE (not active)
ATI TV Wonder Elite (active)
acrespo is offline   Reply With Quote
Old 11th August 2005, 09:15   #284  |  Link
tritical
You can, but it wont work correctly . For flags=0 to 2 there can't be any modification of the # of fields or the order of those fields between mpeg2source() and tfm()/tdecimate(). flags=3 as you have now will work ok though. If you want to use flags=0,1, or 2 you would need to move the trim to after tdecimate.
Old 14th August 2005, 07:46   #285  |  Link
tritical
Here is [link removed].
This version adds a hybrid=3 option to tdecimate which is similar to hybrid=1 except that instead of leaving 24p sections untouched and blend converting 30p sections to 24p, hybrid=3 leaves 30p sections untouched and blend converts 24p sections to 30p. This version also adds isse optimizations for more blocksizes for tdecimate's metrics calculations. The last addition is a new parameter called "sco" to TFM which can be used to allow u/b matches only at scenechanges (good for dealing with the case of orphaned fields that only appear at scenechanges due to edits). The only thing left on the todo list for tivtc at this point is optional blending in mode 2 of tdecimate.
Old 14th August 2005, 08:56   #286  |  Link
tritical
Changes:
- SetCacheHints call to diameter instead of radius
- Fixed type=1 YUY2 interpolation routine giving messed up chroma output
   (bug was introduced in v1.0 beta 3)
Old 14th August 2005, 12:53   #287  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Originally Posted by tritical
The last addition is a new parameter called "sco"[...]
Sure beats writing "Litigious Bastards"...
Anyhow, I'd have one request for TIVTC - while blending 30FPS sections down to 24 works fine, I've found that some of the CGI car scenes in GITS:SAC were oddly enough rendered in 15FPS, i.e. every frame is shown twice.
The problem here is that TIVTC decimates these scenes since it thinks it's material that had pulldown applied to it, and thus introduces jerkiness. Would it be possible to check if every other frame (or probably 2 out of 3 and 3 out of 4 frames) is a duplicate and in that case treat this scene as video instead of film?
Yeah, I know it's a rather odd case, but it exists nonetheless...
np: Richard Devine - Arc-Acid (Cautella)
Leak is offline   Reply With Quote
Old 14th August 2005, 13:11   #288  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
Well, as I asked before:is it possible to code a mode switcher?
(modes: Film, 30p, 60i)
like this pseudo-code for standards conversion:
mpeg2source("NTSC-Hybrid.d2v")
a=bob().convertfps(50) # 60 to 50
b=telecide().changefps(50) # 30 to 50
c=telecide().decimate().changefps(50) #24 to 50
T-Switch(last,a,b,c)
resize(width,576)
assumetff().separatefields().selectevery(4,0,3).weave()
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 14th August 2005, 14:13   #289  |  Link
Leak
Leak's Avatar
Wouldn't that have the problem that there could be discontinuities at the points where the mode is switched? I.e. a frame might be repeated since both the film and 30P stream considered it essential at that spot, or a frame might be skipped for similar reasons; which could be prevented by a single filter that handles everything.
np: Jah Wobble - Fly 2 (I Could Have Been A Contender (Disc 1))
Old 14th August 2005, 14:40   #290  |  Link
scharfis_brain
brainless
this could maybe be avoided by checking, which of the new rendered frames is closer to the before chosen one...
Old 14th August 2005, 19:12   #291  |  Link
tritical
@Leak
Could you send me a sample from gits:sac to test on? Such cases are indeed not handled correctly with vidDetect=3. You would probably be better off using vidDetect=0 or possibly vidDetect=2, but I doubt it will fix everything.
@scharfis_brain
It is possible of course, but I've already got a lot to do on my existing filters and I have no material to test on that is a mix of 24p/30p/60i. Would you be able to send some samples?
Old 14th August 2005, 21:25   #292  |  Link
Leak
Leak's Avatar
@Leak
Sure... give me a minute or five...
Here it is.
Actually, after taking a closer look at this sequence it's not simply 15 FPS animation, but something quite strange...
I doubt doing that for maybe 15 seconds of footage (if even) for a 24 minute episode is worth it...
Old 14th August 2005, 23:10   #293  |  Link
tritical
I looked at the clip and to me it looks like plain 12fps animation. After field matching there is a 3 frames (1 new + 2 dups) followed by 2 frames (1 new + 1 dup) pattern and mode = 1 with tdecimate handles it fine. It did have some irregular rff flagging so using d2v="" in tfm with flags = 0, 1 or 2 lead to incorrect decimation in a couple cycles where mode=1 w/o the rff info picked the correct frames to decimate. I went ahead and added in some extra logic to prevent mode=1 using d2v dup info in such cases.
Here is the result (xvid const quant 2) after using the following script:
mpeg2source("C:\gits.d2v")
tfm(d2v="C:\gits.d2v")
tdecimate(mode=1)
gits clip
Old 15th August 2005, 07:18   #294  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
yeah. GITS SAC sticks to 24fps all through except in the last couple of episodes, and the japanese intro sequence (which comes out slightly jerky in the PAL version due to decimation). i think towards the end of the show some shortcuts were taken in editing, so there's a mix of pure 24p and some 30p. but i can only say this based on the PAL conformed version (which has some full-frame blending in it on the last tape that wasn't on any of the others!).
kinda makes me wish there were a way to get the best of all worlds in standards-conversion. speed up the film bits, blend the 30p and 60i bits to 50i, and encode interlaced.
the intro to Gantz has all three types of content. anywhere you want it uploaded? i'll grab it tomorrow (at home now...).
Old 15th August 2005, 08:26   #295  |  Link
tritical
@Mug Funky
68.119.245.113
port 17252
upload/upload
If that wont work just pm me.
I've seen the intro sequence for the first gits:sac r1 dvd and it has 30p, but I think most of the actual ep is 24, if not all, though I couldn't guarentee it.
Old 15th August 2005, 11:21   #296  |  Link
scharfis_brain
brainless
@MugFunky: DEFT converters can do this. (I don't know what their price is)
but they are still inperfect, because they are deinterlacing and blending the 30p to PAL
I prefer fieldmatched 30p, which has became telecined (changefps) to PAL.
Old 15th August 2005, 22:41   #297  |  Link
tritical
[link removed]
Changes:
TDecimate:
   + mode=1 w/ d2v info and hybrid=3 decimation improvements
Old 23rd August 2005, 05:49   #298  |  Link
B.F.
B.F.'s Avatar
New DGMPGDec is out.
d2v opinion don't work now.
B.F. is offline   Reply With Quote
Old 23rd August 2005, 07:04   #299  |  Link
tritical
Support will be added in the next release, but I am working on adding some other features so it won't be out immediately. For now, to use the d2v option with v11 d2v files just make a copy of the d2v file and in the copy change the very first line from:
DGIndexProjectFile11
to
DGIndexProjectFile10
and use that copy as the file for the d2v argument in tfm(). The only change in v10 to v11 was removing a number before the path entries and that wont make any difference to tfm's d2v parsing/reading.
Old 24th August 2005, 06:54   #300  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
all of it except the last 2 episodes. don't know why it went that way (deadlines in production?).
tdeint, tivtc
