15th October 2017, 13:22 | #46561 | Link | |
Have a look at the samples below with the same above settings. Comes from the same episode. It's something that has to be use with care or be turned off with quality high resolution content. Original https://www.mediafire.com/file/iq6epk00eef57e0/Off.png Rca-5, rra-1 https://www.mediafire.com/view/iwdjz...2C%20RRA-1.png That said, the new features does work magic on sd and poorly mastered sd-to-hd anime content. Thanks madshi!
Core i7 4790K@4.6Ghz - Asus Maximus VII Formula - AMD R9 290X 4GB Crossfire - Windows 10 Pro x64 |
15th October 2017, 13:29 | #46562 | Link | |
15th October 2017, 13:50 | #46563 | Link |
Hello,
Is it possible to set up a separate setting profile for 3D frame-packed content? My standard 2D "1080p" profile settings make my 1080 Ti video card "exploding" (rendering times ~doubles) when playing 3D due to doubling each frame instead of only 1pc of 2D frame. Is it the correct behaviour of madVR to upscale BD sources/DVD sources to 4320x2430p? It is a bit far from 3840x2160p. This behaviour also has negative impact on my JRivers UI (stayed "zoomed in" even after finishing play). Is it the correct behaviour of madVR to output at 8bit even if chosing 10bit as "the native display bitdepth"? My source is 8bit (BD mostly), but my TV can handle 10bit surely. Any help would be appreciated. |
15th October 2017, 14:08 | #46564 | Link | |
But the symptoms are not quite identical to Potplayer. The madVR OSD doesn't appear. I get a windows alert sound after a few secs, and sometimes MPC gets unhung and the playback starts. Also hanging seems to occur differently, when I clobber one file instead of when I change between files. |
15th October 2017, 14:14 | #46565 | Link | |
You could be right |
15th October 2017, 14:27 | #46566 | Link | |
I can't say this will work for everyone, but it did for me. |
15th October 2017, 14:39 | #46568 | Link | |
lacking in comparison and i find no shorige of bad content. I'm using the awesome reducing random noise and compression artefacts when needed, but in this situation i have to use them, and this solution brings the questions of subtle harm and more GPU freedom being lost (then just having the previus AS checked). If other options come to light more joy to me, i did caught on that the new AS is stronger, so if i tone it down a bit and if the grain is not as visible i guess i'll survive the change. |
15th October 2017, 14:57 | #46573 | Link |
http://madvr.com
latest release v0.92.7 |
15th October 2017, 14:58 | #46574 | Link | |
Soul Seeker
15th October 2017, 15:02 | #46575 | Link | |
It looks like madshi actually controls that website now?!
I swear that didn't use to be the case. I am very glad madVR.com is in good hands. Quote:
madVR options explained Last edited by Asmodian; 15th October 2017 at 15:15. |
15th October 2017, 15:28 | #46576 | Link | |
I hope everybody here realizes how lucky we are to have you. Last edited by ashlar42; 16th October 2017 at 02:33. |
15th October 2017, 16:27 | #46578 | Link |
I'm encountering a strange problem where video playback is smooth for the first 6-8 minutes or so, and then I start dropping frames like crazy. Pausing and then playing again doesn't help, but restarting the video player (PotPlayer, although I've also tried MPC-HC) fixes the problem immediately... for the next 6-8 minutes. Task manager doesn't show anything that stands out while frames are being dropped -- no spikes in CPU, GPU, or RAM.
It doesn't seem like a hardware issue, as madVR is the only thing that has seems to have any issues. I'm on the latest windows 10 insider build, so this might be the culprit, but it only happens on my NVIDIA GTX 1070 machine. I have another desktop with the AMD RX-480 that's also on the latest insider build, but the problem doesn't happen there. I've tried old NVIDIA drivers and old madVR builds, but had no luck. Has anyone encountered anything like this before? |
