Old 10th June 2014, 03:18   #2201  |  Link
MichaelRow
MichaelRow's Avatar
Can't download the Mac packages.
MichaelRow is offline   Reply With Quote
Old 12th June 2014, 23:38   #2202  |  Link
Selur
Selur's Avatar
fixed, btw. will probably release new versions tomorrow,...
Old 13th June 2014, 12:33   #2203  |  Link
Selur
Selur's Avatar
Hybrid rev 2014.06.13.1:
*fixed*
  • audio: using audio from different source than the main input
  • audio: crash when switching between titles with and without audio
  • tools: Windows package contained a kvazaar binary which did cause problems on some systems<
*added*
  • video: initial support for QSVCEnc as encoder
  • video: initial support for FFV1 as encoder
-> downloads: http://www.selur.de/downloads
Cu Selur
Old 15th June 2014, 23:53   #2204  |  Link
digitall.h
*fixed*
  • audio: using audio from different source than the main input...
I use this option very little, but I was going to post it was not working properly... but you already fixed it!
digitall.h is offline   Reply With Quote
Old 17th June 2014, 10:40   #2205  |  Link
Selur
Selur's Avatar
Hybrid rev 2014.06.17.1:
*added*
  • avisynth: de-'dot crawler': DeCrawl, Checkmate, DeCrow
*fixed*
  • decode: mencode decod ecall containing '-vf ,scale', instead of '-vf scale'
  • qsvenc: adjust to feature restriction on system
*changed*
  • avisynth: speed-up FFVideoSource by using setMTMode(5,.. instead of setMTMode(3,..
Hybrid rev 2014.06.17.2:
*fixed*
  • audio: extracted audio didn't get deleted after audio reencoding
Cu Selur
Old 18th June 2014, 20:27   #2206  |  Link
digitall.h
Hi selur,
Latest version Linux64bit Qt4.8 2014.06.17.2 and also previous 2014.06.15.1 does not show preview correctly.
Send you debug.
Old 18th June 2014, 21:01   #2207  |  Link
Selur
Selur's Avatar
please send me a debug output of the latest version, not of the older one
Also preview related stuff requires debug output level 6.
Old 18th June 2014, 21:11   #2208  |  Link
digitall.h
It was from the last version.
I'll activate debug level 6 and send you a new debug.
Old 18th June 2014, 21:14   #2209  |  Link
Selur
Selur's Avatar
Nope it was from:
2014.06.18 - 20:19:52_linux-64bit_4.8.1_2014.06.15.1
Old 18th June 2014, 21:46   #2210  |  Link
digitall.h
Look some lines below (I had not erased previous debug)
Sent new debug with level 6 activated.
Old 27th June 2014, 21:11   #2211  |  Link
DJ-1
Hi, currently using latest Hybrid, wasnt having any issues untill i start getting a windows pop-up msg saying ""ffmpeg.exe - no disk" "there is no disk in drive H:"
Im running Win 8.1 Pro N
I`m using a global data model with only the Paths changed (all pointing to my E
when any source file is scanned the msg pops up, also if i ignore it, hit add-to-queue, then run Queue it qives same error msg.
I do have a drive H: but its part of a usb hub and is always threre.... but theres not any drive `plugged in` to H:
so all a bit wierd....
debug:https://www.dropbox.com/home/Hybrid/no%20disk%20in%20drive%20error%20msg
cheers.
DJ-1 is offline   Reply With Quote
Old 27th June 2014, 21:25   #2212  |  Link
Selur
Selur's Avatar
a. Can't access the message.
b. Need a debug output to see what is happening there.
c. strange thing that Hybrid doesn't produce any popup containing the word 'disk'
-> my guess atm. is that the Windows Explorer or some shell extension is creating that message
Old 27th June 2014, 21:33   #2213  |  Link
DJ-1
Yeah I assume debug level 4 is fine?....
Im just doing some windows updates (about 60) as it's been prompting me for ages hopefully it'll be ok.
Yeah I noticed there's no mention of disk in the debug, it's all very odd at the moment.
I see what happens once all the updates are done...
Old 27th June 2014, 21:36   #2214  |  Link
Selur
Selur's Avatar
Yup debug level 4 should be fine.
I keep my fingers crossed.
Old 27th June 2014, 23:08   #2215  |  Link
DJ-1
hmmm ok all up to date
using the same global profile (default, with only the Paths changed) seems to run a job fine.
But, if i reset cached tools list in Hybrid, close it, re-open i then get same msg "ffmpeg.exe no disk in drive H:"... but assume its windows error as no mention of disk error in debug...
debug:
https://www.dropbox.com/s/9jfr09p2xjh4kuu/HybridDebugOutput.txt
Old 28th June 2014, 06:00   #2216  |  Link
Selur
Selur's Avatar
a. can't access the debug file
b. try if it helps to reset the tool cache (Config->Tools->Clear all cached tool infos)
Old 28th June 2014, 10:07   #2217  |  Link
DJ-1
If I reset the tools list cache, after restart hybrid it triggers the error...
Debug link fixed now
Old 28th June 2014, 10:15   #2218  |  Link
Selur
Selur's Avatar
Is it triggered on startUp, when creating a job, or when processing a job?
Old 28th June 2014, 10:18   #2219  |  Link
DJ-1
On startup, straight after resetting tool list cache...
Sometimes while scanning a source file(not every file though)
Old 29th June 2014, 09:24   #2220  |  Link
Selur
Selur's Avatar
Hybrid rev 2014.06.29.1:
*added*
  • video: initial support for ffvhuff and libutvideo
  • decode: added options to support hardware acceleration when ffmpeg is used.
  • mux: option to disable mkv statistics per track (introduced with mkvtoolnix 7.0.0)
*fixed*
  • preview: fixed preview issue if no avisynth is available on the system
  • video: QSVEnc support, adjusting to QSVEnc 1.23, thanks to rigaya for fixing some problems
  • ffv1: ffv1 mencoder call
  • subtitle: crash on subtitle extraction
  • timecode: fixed a crash in time code handling due to formating issues
  • audio: extracting&muxing aac to mp4 could trigger a conversion to wav, even when 'passthrough' was selected.
  • audio: enabling 'Always extract as wav' and audio handling 'passthrough' interfered
*changed*
  • general: switched to MSVC++ 2013 for Win 64bit builds
Cu Selur
