24th August 2008, 23:02 | #201 | Link |
One more somewhat lame question. I was suggested to use constant quality for encoding one particular HD stuff - and also to make it DXVA compatible if possible. But there's no constant quality preset in the DXVA category, all are 2pass. Using constant quality would be bad for some compatibility or how is it? I am pretty new to this, only have experience with DVDs so far, so it's quite confusing.
25th August 2008, 03:18 | #202 | Link |
Mr. Sandman
1pass VBV compliancy is not optimal.
just use 2 passes if you have VBV restrictions (DXVA has them...).
25th August 2008, 05:42 | #203 | Link |
edited
When using DXVA presets, the video must be resized to mod16? I tried to encode something and was given an error message: Your AviSynth clip has the following problem: AviSynth clip doesn't have mod16 dimensions: Width: 1920 Height:1080 This could cause problems with some encoders, and will also result in a loss of compressibility. I suggest you resize to a mod16 resolution. Continue anyway? I think I don't get this with unrestricted profiles. Last edited by Octo-puss; 25th August 2008 at 11:42. |
25th August 2008, 12:23 | #204 | Link |
The posts from Dirk362 & Avenger007 are very interesting. Thanks to take time to explain taking experience in count.
I just have a question about deblock 1:0:0, how it can be modified in the preset, I see the Deblocking window in Main Tab... but It doesn't appear in the command line window? |
25th August 2008, 12:45 | #205 | Link |
Mr. Sandman
@octo-puss
presets updated: v67
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 25th August 2008 at 12:59. |
25th August 2008, 14:19 | #206 | Link | ||
If you type in a command prompt when x264.exe is located x264 --longhelp you will find all the settings, and default values etc. Quote:
Most of my testing is with 1080p, and I've found 32 works well across a wide range of live action movies. When encoding time isn't an issue, and only for 1080p, setting to 64, whilst dramatically increasing encoding time, lends itself to higher perceived quality due to better ME. Last edited by dirk362; 25th August 2008 at 14:34. Reason: rewrite so that it makes sense ! |
25th August 2008, 23:24 | #207 | Link | |
Forum Member
Also, are profile settings interchangeable? Meaning, if the preset is set to Automated Two-Pass, can it be changed to say Const. Quality and vis versa without complications? Or are those settings only meant to be used with their default mode? Last, if you use Const. Quality of say 18 and after the encode it says the output bit-rate was around 4956, would using that number with VBR two-pass return the same quality? |
25th August 2008, 23:55 | #208 | Link | ||
Basically yes. |
26th August 2008, 07:01 | #209 | Link |
Forum Member
Also, when you enable Turbo mode, it allows for faster encoding, but causes a quality drop, correct? And does it matter if MeGUI shows my CPU as an Intel Pentium III Xeon when it is an Intel Core 2 Quad (like not taking advantage of all cores during encoding)? |
26th August 2008, 12:28 | #210 | Link |
Mr. Sandman
turbo mode allows a faster first pass. the drop in quality is negligible.
also megui is just a gui... the encoding is done by the encoder... so it doesnt really matter what CPU is shown.
26th August 2008, 19:05 | #211 | Link | |
and again after updating presets via autoupdate |
26th August 2008, 19:14 | #212 | Link |
Mr. Sandman
doesnt happen here.
i updated the presets as well and everything is working and didnt crash.
26th August 2008, 19:38 | #213 | Link |
It happens to me ALL THE TIME. I don't know. Right after I click to overwrite the last preset or after checking "don't ask again". And so it does if I delete the presets first. The only working method is manually importing.
26th August 2008, 19:58 | #214 | Link |
Mr. Sandman
i do it every time i publish the new presets... and it doesnt crash...
is your system up to date? have you tried reinstalling megui from scratch?
27th August 2008, 00:14 | #219 | Link | |
Mr. Sandman
in general, it slowers the encoding, and gives better quality.
megui, x264 presets |
