29th March 2008, 23:33 | #822 | Link |
Life's clearer in 4K UHD
Yes...
For those re-muxing MKV sources it would be most useful, as the PAR signalling is often removed from the stream and placed within the container. Cheers
29th March 2008, 23:46 | #823 | Link | |
survivant001
29th March 2008, 23:50 | #824 | Link |
@roman have you had a chance to take a look at my samples i uploaded yet? i still am getting a black screen and no sound with all my 1080 files when creating bluray structure/avchd dvd regardless of what format they are in even original files straight from bluray without encoding give the same result. this is very odd as all my files will play on my pc and if streamed to the ps3 and also from ext usb. btw all files will play in avchd dvd/bluray structure if created by
tsremux any ideas ps this problem is apparent also with latest Version 1.7.1(b) |
30th March 2008, 00:01 | #826 | Link | |
I'll keep you inform. Last edited by survivant001; 30th March 2008 at 00:25. |
30th March 2008, 01:15 | #827 | Link |
Thats what i have been doing just wanted to know you were aware of the issue and wanted confirmation that its not just me who is getting this problem i uploaded some samples but nobody has yet confirmed i guess it just my ps3 then as i seem to be the only one to be experiencing the black screen no sound problem
thanks Last edited by gav1577; 30th March 2008 at 01:19. |
30th March 2008, 03:01 | #828 | Link | |
Edit: My bad... I just realised this was already answered. Isn't PAR the acronym for Pixel Aspect Ratio not Picture Aspect Ratio? I thought AR meant the Aspect Ratio, which is what the player uses to determine the picture AR. Am I misunderstanding this? Last edited by Ryu77; 30th March 2008 at 05:23. |
30th March 2008, 07:52 | #830 | Link | |
I tried Cars (all regions with 28 files) with V1.71, and can confirm that tsmxuer still doesn't join the files together the same way as demuxing, running through h264info and remuxing. there is still the bump at the seams, judder, audio out of sync followed by a frozen image when played back on the tvix 6500a. Update: I also retried Charlie & The Chocolate factory HD-DVD. It went through all the way to the end, but I got several E-AC3 Out of sync messages (which I didn't get using EvoDemuxer, VC!CONV & tsmuxer. The same for Bourne Supremacy HD-DVD, but this time it failled 63.1% through, with the 'encountered a problem and needs to close' message fo Offset 00044d1d. Mike Last edited by mrr19121970; 30th March 2008 at 08:32. Reason: V1.71 Don't work for a couple of HD-DVDS |
30th March 2008, 12:38 | #832 | Link | |
chamb_link
I plan the following: 1. Add .srt subtitles support and ability to convert srt to PGS 2. Add dvd subtitles support and ability to convert srt to SUB. 3. Ability to convert SUB to PGS 4. Add HD-DVD subtitles, ability to convert HD-DVD subtitles to DVD SUB or PGS. 5. Add other txt based subtitles |
30th March 2008, 13:04 | #833 | Link | |
Please hurry on this! I give you full permission to stay awake for the next 48 hours until this is created! Where would you like the 1kg jar of Coffee shipped to? Hehe... Last edited by Ryu77; 30th March 2008 at 13:07. |
30th March 2008, 13:17 | #834 | Link | |
#6 - multi-titles (like for anime) #7 - menus a) (1 by movie, ) b) for chapters with a picture of the first frame of the chapter ) c) for audio track d) for subtitle ON/OFF what do you think ? Last edited by survivant001; 30th March 2008 at 16:12. |
30th March 2008, 14:14 | #835 | Link | |
30th March 2008, 14:23 | #836 | Link |
Great work Roman, great prog and support
Now tried Planet Earth HD-DVD and after removing pulldown stream is detected as interlaced. It is possible to do same kind of work as VC1CONV does? When I import VC-1 raw stream from VC1CONV, your prog detect it correctly as 1920x1080p, 23.976. Thanks ExSport |
30th March 2008, 16:11 | #837 | Link | |
example if you pass the command -menu-audio it will create the audio menu, .. |
30th March 2008, 16:37 | #838 | Link | |
Removing pulldown doesn't work?
VC1Conv did the job. |
30th March 2008, 16:44 | #839 | Link | |
dirkr
tsmuxer |
