10th May 2012, 11:26 | #11163 | Link | |
10th May 2012, 16:31 | #11165 | Link |
use older working ripbot version. old versions are availabe at videohelp.com
11th May 2012, 07:15 | #11170 | Link |
Any pointers on why I suddenly get the following error and I cant seem to shake it off no matter what recent versions [that support distributed encoding] I try:
The encoder client opens after pressing start on the Ripbot264 window with title bar reading "Can not open file C:\Temp\Ripbot264temp\jobxx\video.mkv.ffindex_track00.kf.txt. The s....." truncates rest of the title bar - any way to turn on a verbose/debugging mode? where to look? what to do? Thanks in advance! |
11th May 2012, 08:51 | #11171 | Link |
slalom what is your default decimal separator set in windows?
what do you do step b step?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 11th May 2012 at 09:24. |
11th May 2012, 08:59 | #11172 | Link |
sreemv
does this happen regardless of selected input file? .avi .mp4 .mkv ... when you get that error could you send me content of jobxx folder . obviously without heavy files like video.mkv or audio...
11th May 2012, 09:41 | #11173 | Link | ||
Should it be 1,640.23€? While the D.E. has begun encoding on two machines, I use a third machine to log to the first using R.D. Connection. That's when the error appears. If I'm already connected and start the procedure from the beginning, everything goes fine. Sometimes I get this error too Quote:
11th May 2012, 12:32 | #11174 | Link |
Issue when no subtitles present in DVD
Hi Atak_Snajpera. When trying to add a DVD which contains no subtitles, it goes through joining the VOB's and the usual, then gets to "Demuxing Subtitles" (according to the status message at the bottom of the encoding settings window) and just stays there. I had a look at the LogFile.txt and it correctly lists that there are no subtitles, so I'm not sure why it's trying to demux something which isn't there.
I'm using 1.17.1 on Windows 7 x64. I still had a installation of 1.17.0 on my machine, so I tried the same DVD on that version, and it adds in fine... Edit: Oh, I also tried the update for 1.17.1 a few pages back, and it made no difference to the issue. Last edited by coreying; 11th May 2012 at 12:39. Reason: Add note about trying update. |
11th May 2012, 16:01 | #11175 | Link | |
I sent you PM with link to jobxx contents - thanks for your help!! I was trying to understand your tool flow - how the hand off happens from the ripbot264 to encoder client.. I saw it say "copying tools" - next thing I expected it to see was indexing but thats not happening? |
11th May 2012, 16:15 | #11176 | Link |
your custom plugins are not copied. Try again without your fancy plugins.
11th May 2012, 17:25 | #11177 | Link | |
I removed all custom plugins and I still end up with the same issue - so, I dont believe thats the issue - please let me know if there is anything else I can check. Thanks again. Last edited by sreemv; 11th May 2012 at 18:45. |
11th May 2012, 19:06 | #11178 | Link | |
@slalom i also fixed your issue with decimal separator as well as invisible encoding server in remote desktop mode. new version will be released once i increase number of supported servers in client. @sreemv i will investigate your job folder a little bit closer tomorrow.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 11th May 2012 at 19:15. |
11th May 2012, 19:24 | #11179 | Link |
Really? Last time this happend, I just switched the SAME encode to another machine with the same exact Ripbot version and everything else and the D.E worked fine but I hate switching around. I would like to debug this and fix.
11th May 2012, 19:47 | #11180 | Link |
maybe ripbot264temp is no longer shared?
