12th October 2020, 19:06 | #2203 | Link |
QfG Group Germany
Hi stax, is there any chance to add DNxHR Intermediate Output in the FFMPEG section by Encoders? You can delete the "ProRes" button, "DNxHR" is the newer Intermediate Codec.
Here the inputs for DNxHR: Code:
-c:v dnxhd -profile:v dnxhr_lb //Low Bandwidth. 8-bit 4:2:2 (yuv422p). Offline Quality. -c:v dnxhd -profile:v dnxhr_sq //Standard Quality. 8-bit 4:2:2 (yuv422p). Suitable for delivery format. -c:v dnxhd -profile:v dnxhr_hq //High Quality. 8-bit 4:2:2 (yuv422p) -c:v dnxhd -profile:v dnxhr_hqx //High Quality. 10-bit 4:2:2 (yuv422p10le). UHD/4K Broadcast-quality delivery. -c:v dnxhd -profile:v dnxhr_444 //Finishing Quality. 10-bit 4:4:4 (yuv444p10le). Cinema-quality delivery. I can't encode directly via FFMPEG, because i need some Avisynth Tweaks (Inverse Telecine) Greetings
12th October 2020, 19:15 | #2204 | Link | |
Sent from my SM-G986U1 using Tapatalk |
12th October 2020, 20:07 | #2207 | Link |
Currently, I pause 3-6 months. I try to get more people interested maintaining it.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 12th October 2020 at 20:14. |
13th October 2020, 01:08 | #2208 | Link |
I greet everyone. StaxRip-x64-2.1.4.8-Beta.
QVBR (Quality Variable bitrate using bitrate) preset for Intel H.264 does not work. This has been observed in all recent beta. Whatever high bitrate I set, the program switches to QVBR-Q (Quality Variable bitrate using quality - 23). If necessary, I will indicate the exact parameters of my files. Also, another presets for Intel H.264: LA (VBR Lookahead), LA HRD does not work for me. If earlier it was possible to set the maximum Lookahead Depth - 100, now the launch with any settings ends in a crash: Failed to initialize encoder. : invalid video parameters. QSVEncC.exe finished with error! Please pay attention to these problems. thanks Last edited by hevron; 13th October 2020 at 18:42. |
17th October 2020, 09:37 | #2209 | Link |
QfG Group Germany
Updates for following AVS Filter available:
TDeint v1.7 TIVTC v1.22 https://github.com/pinterf/TIVTC/releases/tag/v1.0.22b
17th October 2020, 16:01 | #2210 | Link |
Hope !!
Hi, i would like to ask for some help.
the story is that i'm trying to encode an avisynth filtered video script with NVEnc h265 in StaxRip, i use a lot of filters to do that, as shown in script below. i choose NVEnc to accelerate the process, because the avisynth script contains a lot of filters. usually encoding with x264/x265 CPU costs a lot of time, then eventualy i assume using NVEnc might get the fps higher ^^ so since i'm in x64 env, i installed avisynth+ for both version 64 and 32, and added the plugins to right places, everything works fine, i get the video preview in AVSPmod just OK. the problem is when i start to encode the video, the fps is just the same as when i use only cpu to encode, the GPU does nothing to speed-up the thing. i used MP_PIPELINE to create a process for each filter with max memory set to 1024 Mb, and still i get: gpu 3% and VE 9% and fps 24 (maximum). I kept monitoring the process of MP_pipeline and noticed that cpu actes only without the gpu. my question: is there anything to do to help accelerate the encoding of avisynth scripts with NVEnc h265/h264 ? or am i missing something?? i'll leave more details down below: Windows 10 Pro(x64) (Build 18362) StaxRip v2.0.8.0 Stable NVEnc v4.68 AVSPmod V2.6.1.1 x64 and x32 MicrosoftVC++ Redistributable 2005->2019 x64 & x32 NVidia Driver v441.08 Encoder settings: Code:
--vbrhq 2048 --codec h265 --preset quality --profile main10 --tier high --level 5.1 --output-depth 10 --aq --bframes 6 --ref 16 --gop-len 600 --lookahead 32 --strict-gop --nonrefp --cu-max 32 --cuda-schedule auto --colormatrix bt709 --colorprim bt709 --transfer bt709 --vpp-edgelevel strength=10,threshold=15,black=5,white=2 --mv-precision full-pel --cabac Code:
Max B frames are 0 frames. NVEncC (x64) 4.68 (r1402) by rigaya, Mar 7 2020 13:54:44 (VC 1916/Win/avx2) OS Version Windows 10 x64 (18362) CPU Intel Core i7-8550U @ 1.80GHz [TB: 2.59GHz] (4C/8T) GPU #0: GeForce GTX 1050 (640 cores, 1493 MHz)[PCIe3x16][441.08] NVENC / CUDA NVENC API 9.1, CUDA 10.2, schedule mode: auto Input Buffers CUDA, 41 frames Input Info Avisynth+ 2.60(yv12)->nv12 [AVX2], 1280x720, 24000/1001 fps Vpp Filters copyHtoD cspconv(nv12 -> yv12(16bit)) edgelevel: strength 10.0, threshold 15.0, black 5.0, white 2.0 cspconv(yv12(16bit) -> p010) Output Info H.265/HEVC main10 @ Level 5.1 1280x720p 1:1 23.976fps (24000/1001fps) Encoder Preset quality Rate Control VBRHQ Bitrate 2048 kbps (Max: 153600 kbps) Target Quality auto Initial QP I:20 P:23 B:25 VBV buf size auto Lookahead on, 32 frames, Adaptive I, B Insert GOP length 600 frames B frames 0 frames [ref mode: disabled] Ref frames 16 frames AQ on CU max / min 32 / auto VUI matrix:bt709,colorprim:bt709,transfer:bt709 Others mv:full-pel nonrefp Code:
MP_Pipeline(""" ### platform: win64 FFmpegSource2("C:\Users\LEGEND\Desktop\Filter\File.mkv", width=1280, height=720, resizer="BICUBIC", colorspace="YV12") ### ### ### platform: win32 SetMemoryMax(1024) LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\eDeen.dll") eDeen(r=2, ty=14, tuv=21, ly=7, luv=10, hqc=true) ### prefetch: 32, 16 ### ### ### platform: win32 SetMemoryMax(1024) LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\Deen.dll") Deen(mode="a2d", rad=2, thrY=14, thrUV=16, min=0.5) ### prefetch: 32, 16 ### ### ### platform: win32 SetMemoryMax(1024) Sharpen(0.20) ### prefetch: 32, 16 ### ### ### platform: win32 SetMemoryMax(1024) LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\aWarpSharp2.dll") aWarpSharp2(depth=20) ### prefetch: 32, 16 ### ### ### platform: win32 SetMemoryMax(1024) LoadPlugin("C:\Program Files (x86)\AviSynth+\plugins\MSharpen.dll") msharpen(threshold=10, strength=70,mask=false, highq=true) ### prefetch: 32, 16 ### ### ### platform: win32 SetMemoryMax(1024) FastLineDarken(strength=100, luma_cap=191, threshold=4, thinning=24) ### prefetch: 32, 16 ### ### ### platform: win32 SetMemoryMax(1024) Trim(18200, 25900) ### prefetch: 32, 16 ### ### """)
i7-8550U 4C/8T @1.8 Ghz (TB 3.9 Ghz) GeForce GTX 1050 (Mobile) 4 GB VRAM 16 GB DDR4 2400 Mhz RAM |
18th October 2020, 06:00 | #2211 | Link |
@Legend, you need to monitor the CPU usage, to know what's happening.
I bet the CPU usage is low. Meaning, you're not taking advantage of the CPU speed for some reason. This reason could be that one or more of the AVisynth plugins is not working in multi-cpu mode. To force multi-cpu, you have to put at the end of your script, only once: Prefetch(4) 4 being here the number of CPU logical cores. You can set it up to 8 on your i7 setup. Try that and it should solve your problem. Note: I'm not sure that SetMemoryMax(1024) is required here... |
18th October 2020, 18:45 | #2212 | Link | |
Hope !!
you bet right, the CPU usage is 48~58 %. I don't know much about the Avisynth Plugins/Scripts Multi-core/Multithread support. I kept monitoring the Mp_pipeline processes, they don't use much memory nor GPU. i tried removing the lines of setting max memory from the script, and set Prefetch(8) in the end, but the NVENC behaves the same, CPU usage don't exceed 60 % and GPU is at 3% usage 9% VE. My thought is that mp_pipeline is written in C, not CUDA, hence, it doesn't make the child processes of each filter profit from the GPU as it should be in this case. so maybe there's no point in using NVENC when no GPU resources are not being exploited. maybe the solution is to use Vapoursynth. https://i.imgur.com/5iMWl8K.jpg
i7-8550U 4C/8T @1.8 Ghz (TB 3.9 Ghz) GeForce GTX 1050 (Mobile) 4 GB VRAM 16 GB DDR4 2400 Mhz RAM Last edited by L E G E N D; 20th October 2020 at 02:33. |
19th October 2020, 23:22 | #2213 | Link |
@l e g e n d
MP_Pipeline(""" ### platform: win64 FFmpegSource2("", width=1280, height=720, resizer="BICUBIC", colorspace="YV12") ### prefetch: 32, 16 ### ### ### platform: win32 SetFilterMTMode("eDeen", 2) SetFilterMTMode("Deen", 2) eDeen(r=2, ty=14, tuv=21, ly=7, luv=10, hqc=true) Deen(mode="a2d", rad=2, thrY=14, thrUV=16, min=0.5) prefetch(8) ### prefetch: 20, 10 ### ### ### platform: win64 Sharpen(0.20) aWarpSharp2(depth=20) msharpen(threshold=10, strength=70,mask=false, highq=true) FastLineDarken(strength=100, luma_cap=191, threshold=4, thinning=24) Trim(18200, 25900) prefetch(8) ### prefetch: 10, 5 ### ### """)
See My Avisynth Stuff |
20th October 2020, 01:27 | #2214 | Link | |
Hope !!
Thank you real.finder i tried the script above and got 100% CPU usage, performance jumped to 43 fps. also there are some artifacts that show up periodically. i'll leave two pictures for comparison. anyway THANK YOU ^^. original: https://i.imgur.com/xEcnSRv.png artifacts: https://i.imgur.com/VHaYEqV.png [/SPOILER]
i7-8550U 4C/8T @1.8 Ghz (TB 3.9 Ghz) GeForce GTX 1050 (Mobile) 4 GB VRAM 16 GB DDR4 2400 Mhz RAM Last edited by L E G E N D; 20th October 2020 at 02:31. |
20th October 2020, 11:14 | #2215 | Link |
you can replace the old FastLineDarken with FastLineDarkenMOD4 for more speed and stability
yes that come from edeen, that why I hate using close sources plugins! you can't do anything about it, except change SetFilterMTMode("eDeen", 2) to SetFilterMTMode("eDeen", 3) or remove prefetch(8) from the block that has eDeen and in both cases you may get back to old speed (eDeen will be a Bottle neck) edit: also you can replace Code:
SetFilterMTMode("eDeen", 2) SetFilterMTMode("Deen", 2) eDeen(r=2, ty=14, tuv=21, ly=7, luv=10, hqc=true) Deen(mode="a2d", rad=2, thrY=14, thrUV=16, min=0.5) prefetch(8) ### prefetch: 20, 10 Code:
eDeen(r=2, ty=14, tuv=21, ly=7, luv=10, hqc=true) Deen(mode="a2d", rad=2, thrY=14, thrUV=16, min=0.5) ### branch: 4 ### prefetch: 20, 10
See My Avisynth Stuff Last edited by real.finder; 18th November 2020 at 13:00. |
1st November 2020, 08:51 | #2217 | Link |
How to load VapourSynth with StarxRip?
I use python 3.8.6 and VapourSyntth R52 my test.vpy script, it's a sample from http://www.vapoursynth.com/doc/gettingstarted.html Code:
from vapoursynth import core video_in = core.ffms2.Source(source='Rule6.mkv') #video_in = core.lsmas.LWLibavSource(r'Rule6.mkv') video_in = core.std.Transpose(video_in) video_in.set_output() I can run the script from command line too. Code:
vspipe --y4m test.vpy - | x265 --y4m - --output encoded.mkv StarxRip 2.1.4.8 Beta, give an error when open script: When I chage video_in = core.ffms2.Source(source='Rule6.mkv') to video_in = core.lsmas.LWLibavSource(r'Rule6.mkv') StarRip give me another error: I already put file LSMASHSource.dll into: "StaxRip-x64-2.1.4.8-Beta\Settings\Plugins\VapourSynth" and "StaxRip-x64-2.1.4.8-Beta\Apps\FrameServer\VapourSynth\vapoursynth64\coreplugins" do some search, I found this post: https://forum.doom9.org/showthread.p...63#post1816963 stax76 said: "Let staxrip create a vpy script" But how to do that? Last edited by Dann0245; 1st November 2020 at 08:55. |
1st November 2020, 11:54 | #2218 | Link |
It means you have to open staxrip, click where you read AVS Filters (in blue) and select Filter Setup > Vapoursynth. It will change to VS Filters.
Then open or drag and drop the video file in staxrip, and build your filters from there (read staxrip doc). Staxrip will build the script for you, and you'll be able to execute the process without the whole scripting method that is explained in Vapoursynth. Last edited by 44vince44; 1st November 2020 at 11:57. |
2nd November 2020, 02:10 | #2219 | Link | |
Thank! |
14th November 2020, 16:29 | #2220 | Link |
I appeal to experts for help. Updated plugins on Update-Links Staxrip -Stuff.
Plugins_JPSDR: in the folder there are 8 pieces, which of them should be selected? AVS-Stuff real.finder: avs 2.6 and up or avs 2.5 and up should be selected? Thank you. Win10x64. Last edited by hevron; 14th November 2020 at 16:38. |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
