Old 7th April 2011, 16:40   #61  |  Link
doobry
Totally Clueless
doobry's Avatar
Originally Posted by Chikuzen View Post
@doobry
It seems that x264 team schedules to change some encode options.
https://github.com/DarkShikari/x264-...3c468060efe1e4
I think that you might discontinue "x264bd" because it will be outdated soon.
From that commit link...
This option doesn't automatically enforce every aspect of Blu-ray compatibility (e.g. resolution, framerate, level, etc).
As I said when I added it, its really a feature for me, so that I don't have to refer to the website and lookup the correct options for the file i'm encoding... It does however error out when it cannot find a matching "profile" for the video, something that the commit comment says the changes do not do.
It would be great if the same feature ended up in x264 as it would mean I can be 100% sure i'm doing the right thing, x264bd is just a consolidation of info on the web, for my use. Bring on the day I can remove it can have a --profile bluray option on x264 that checks everything (framerate, resolution, interlacing etc) will be correct.
And if someone is relying on it, then I'll just modify the options to match the new guide... when someone writes one
doobry is offline   Reply With Quote
Old 7th April 2011, 21:24   #62  |  Link
doobry
Totally Clueless
doobry's Avatar
Did a little benchmarking, real time in seconds, run 3 times each.
avs2pipe 0.0.3:
avs2pipe26_vs  54.23 54.06 54.01
avs2pipe26_gcc 51.83 52.60 52.10
avs2pipe_vs    54.35 54.27 54.26
avs2pipe_gcc   51.86 52.10 51.97
avs2pipe 0.0.4 alpha:
avs2pipe26_vs  32.99 32.73 32.84
avs2pipe26_gcc 32.85 32.72 32.82
avs2pipe_vs    32.81 32.84 32.95
avs2pipe_gcc   32.80 32.73 32.76
avs2yuv 0.24:
downloaded     45.91 46.43 46.11
vs2010 express 54.20 54.44 54.00
Test Was:
Windows 7 x64, Quad Core AMD, AviSynth 2.6 Alpha 2
32374 frames 720x576 YUV420 video from PAL DVD
FFMpegSource for m2v file
FFMpegSource for ac3 file (Not Processed)
Output piped to NUL
MSYS bash time used to time execution
MSYS md5sum used once to check output identical
Thing that really surprised me was that opening the avs2yuv project in Visual Studio 2010 Express and compiling it reduced it speed from around 46sec to 54sec... Is the Express compiler really that bad?
Old 7th May 2011, 23:24   #63  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Hi.
I fiddled with the code of this tool for about one month.
(The purpose is to make it to more wieldy thing for me, and learning C language.)
binary
deleted
source code
https://github.com/chikuzen/avs2pipemod
Differences with original
* Display total elapsed time.
* contents of 'info'
* New option 'benchmark'.
* 'y4mp', 'y4mt', 'y4mb' and 'rawvideo' options instead of 'video'.
* Add SAR info to yuv4mpeg2 stream header.
* FieldBased input will be corrected to framebased on yuv4mpeg2 output mode.
* Colorspace conversion that takes colormatrix and interlace into consideration.
* 'rawaudio' option.
* Convert bit depth function in audio output mode.
* Only the compilation with mingw/msys is supported.
my repositories
Chikuzen is offline   Reply With Quote
Old 8th May 2011, 19:24   #64  |  Link
b66pak
b66pak's Avatar
thanks a lot...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note...
Visit The Land Of Dracula (Romania - EU)!
Old 9th May 2011, 15:31   #65  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
updated.
avs2pipemod-20110510.zip
*Fix incorrect output of 'x264bd', and some modified.
EDIT
Sorry, I found a bug in '-audio' and '-rawaudio'.
Please Download again if you are using avs2pipemod-20110509.zip
my repositories
Old 9th May 2011, 17:24   #66  |  Link
Midzuki
Unavailable
Midzuki's Avatar
@ Chikuzen:
Many many thanks
BTW, ¿ where is doobry ?
Midzuki is offline   Reply With Quote
Old 19th May 2011, 22:29   #67  |  Link
zambelli
Doom9ing since 2001
zambelli's Avatar
Thanks for this tool, Doobry and Chikuzen. Exactly what I was looking for, and perfect timing too.
zambelli is offline   Reply With Quote
Old 3rd July 2011, 07:23   #68  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
update
avs2pipemod-20110703.zip
add new options '-wav' and '-extwav', and remove '-audio'.
'-wav' outputs audio with normal riff-wave header.
'-extwav' outputs audio with wave extensible header containing channel-mask.
my repositories
Old 3rd July 2011, 07:54   #69  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Old 3rd July 2011, 08:17   #70  |  Link
IanB
Avisynth Developer
add new options '-wav' and '-wavext', and remove '-audio'.
Disappointed you don't honour legacy options, now everybody with -audio has to edit their junk to -wav.
But still a great project.
IanB is offline   Reply With Quote
Old 3rd July 2011, 10:38   #71  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Originally Posted by IanB View Post
Disappointed you don't honour legacy options, now everybody with -audio has to edit their junk to -wav. .
no, I changed -audio to -extwav
However, I changed it again because what you said was justifiable.
avs2pipemod-20110703-2.zip
@@ -720,6 +720,7 @@ void parse_opts(int argc, char **argv, params *params)
     struct option long_opts[] = {
         {"wav",      optional_argument, NULL, 'w'},
         {"extwav",   optional_argument, NULL, 'e'},
+        {"audio",    optional_argument, NULL, 'e'},
         {"rawaudio", optional_argument, NULL, 'a'},
         {"y4mp",     optional_argument, NULL, 'p'},
         {"y4mt",     optional_argument, NULL, 't'},
my repositories
Old 3rd July 2011, 22:20   #72  |  Link
IanB
Avisynth Developer
Thanks!
Old 2nd August 2011, 01:10   #73  |  Link
henryho_hk
Is this build multithread-enabled? I have a AMD 1090T X6 and tried:
avs2pip26mod.exe -y4mp some-720p-with-multithread.avs | x264.exe .... --output video.h264 --stdin y4m -
x264.exe .... --output video.h264 some-720p-with-multithread.avs
The first command can only keep one core busy (~16-17%) and the second one can make it ~99%.
henryho_hk is offline   Reply With Quote
Old 2nd August 2011, 05:08   #74  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
If you want to use avs2pipe(mod) with avisynthMT, add Distributor() at the end of your script.
my repositories
Old 2nd August 2011, 13:33   #75  |  Link
CarlEdman
Avs2pipe(26)?(mod)? does not need to be MT enabled--all of that is determined by the avisynth library, invoked by both avs2pipe and x264. And the scripts need a "Distributor()" at the end to use multi-threading (a long time ago that was not the case for x264, but it was necessary for quite a while--I have not checked recently if that requirement has gone away again).
So why is one execution multithreaded and the other not? One possibility is that you are using 64-bit x264. Avs2pipe is 32-bit. So if you have, a non-multithreaded 32-bit version 2.6 avisynth.dll installed, but a 64-bit multithreaded avisynth.dll (that is quite possible--the 32-bit and 64-bit system look for the same dll file, but in different paths), then you'd see just what you observe.
CarlEdman is offline   Reply With Quote
Old 2nd August 2011, 14:16   #76  |  Link
Gavino
Avisynth language lover
The reason is simply that x264 is 'MT-aware' as far as Avisynth is concerned - if it detects that you are running a MT version of Avisynth (and have used SetMTMode), it will make the necessary call to Distributor() itself.
avs2pipe, on the other hand, is not 'MT-aware' so does not call Distributor(), resulting in single threaded running.
(which is why you have to add it yourself.)
Note that for applications using Avisynth via the VfW interface (eg VirtualDub), this is not an issue since in MT Avisynth this path automatically invokes Distributor().
Old 18th September 2011, 07:14   #77  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Why do you want 64bit version ?
There are always avs2yuv and wavi for x64.
my repositories
Old 18th September 2011, 07:20   #78  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
then, use wavi.
http://forum.doom9.org/showpost.php?...02&postcount=4
my repositories
Old 18th September 2011, 08:24   #79  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Originally Posted by rean View Post
I don't understand how to use it. avs2pipemod works fine for me:
avs2pipemod.exe -rawvideo %avs% | C:\Soft\Video\bin\x264-10bit.exe
avs2pipemod.exe -extwav=16bit %avs% > %wav%
If you don't need channel-mask, then
wavi input.avs output.wav
If you need channel-mask, then
wavi input.avs output.wav /x
If you want to output rawvideo, then
avs2yuv input.avs -raw - | x264 - --demuxer raw ...
FYI, currently, it requires avisynth.lib to compile avs2pipe(mod).
However, there is no avisynth.lib for x64.
Thus, it is necessary to rewrite many codes.
my repositories
Old 18th September 2011, 09:00   #80  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
wavi is a program that use vfw interface like VirtualDub/avs2avi/etc...
If wavi cannot treat avs as avi, you will have failed in installation of avisynth.
my repositories
avs2pipe
