14th May 2023, 14:19 | #1 | Link |
Subtitle Code in Avisynth will output Bold Font defualt,how to output unbold font?
Cilp.Subtitle("Hello", font="Arial",first_frame=0, last_frame=999, x=0,y=0,size=72, text_color=$FFFFFF, lsp=0) this codes output Text will be show as Bold fonts defualt i don't know how to change to unbold font? |
4th June 2023, 02:23 | #3 | Link | |
BlankClip() Subtitle("Hellow World",Font = "Arial",Size=64) Subtitle("Hellow World",Font = "Arial-Regular",Size=64,Y=80) EDIT: NO, that aint right either, change to eg "Arial-RegularZZZZZZ" and same result. (I looked it up in google and somewhere it said "Arial-Regular", but it aint right) Code:
BlankClip() Subtitle("Hellow World",Font = "Arial",Size=64) Subtitle("Hellow World",Font = "arial bold",Size=64,Y=80) Windows 10 font list: https://learn.microsoft.com/en-us/ty...s_10_font_list It aint there. [well not as arial regular] Does not seem to be in XP either [some XP available fonts went missing in later years, I think]. Does not seem to be in W10 Features On Demand https://learn.microsoft.com/en-us/wi...iew=windows-11 But there is a Downloadable version available. https://www.dafontfree.net/arial-regular/f169067.htm EDIT: Damn, its there in my Control Panel Fonts whatsit, [clickMe]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 4th June 2023 at 03:06. |
4th June 2023, 06:01 | #4 | Link | ||
You can't.
https://github.com/AviSynth/AviSynth...LL496C1-L496C1 Quote:
4th June 2023, 06:49 | #5 | Link |
As I remember in Win font rasterizing API exist also 'font weight' param - but for most of fonts it do nothing (or simply select between standard and bold). So font must support different 'weight' drawing data or rendered sets ?
From some branch of win-API docs : https://learn.microsoft.com/en-us/do...owsdesktop-7.0 A font weight describes the relative weight of a font, in terms of the lightness or heaviness of the strokes. Weight differences are generally differentiated by an increased stroke or thickness that is associated with a given character in a font, as compared to a "normal" character from that same font. The FontWeights values correspond to the usWeightClass definition in the OpenType specification. The usWeightClass represents an integer value between 1 and 999. Lower values indicate lighter weights; higher values indicate heavier weights. Font weight usWeightClass Thin 100 ExtraLight UltraLight 200 Light 300 Normal Regular 400 Medium 500 DemiBold SemiBold 600 Bold 700 ExtraBold UltraBold 800 Black Heavy 900 ExtraBlack UltraBlack 950 Also about production fonts rasters for moving pictures domain (not dual tone Black and White font original domain) - the conditioning of glyphs raster in scene linear light and in system transfer domain also changes view (visible width/contrast/thickness) of small (thin) parts of glyphs significantly. " Subtitle() has been hardcoded to only output Bold text" Not all documented Win API actually working in all documented control paths. So old developers may select simply most frequently working way. General idea of AVS developers looks like keep itself even today - let it be simple in features but easy to support and work in most use cases. Last edited by DTL; 4th June 2023 at 10:45. |
5th June 2023, 15:47 | #6 | Link |
Due to the public demand , bold and italic parameters (boolean) were introduced (for "Info" as well). When Subtitle acts as "Text" (non-windows systems), "italic" parameter is simply ignored. Font name must be the same ("Arial" for example) and setting bold=false, italic=true will differentiate.
Other filters with less customization option (Compare, ShowSMTPE, ...) have no such parameter, they keep working on with the defaults. |
5th June 2023, 22:17 | #7 | Link |
Very nice pinterf!
Any possibility of adding a parameter to disable anti-aliasing also? There was some demand for it in this thread: https://forum.doom9.org/showthread.php?t=184627 I know SubtitleEx can do it, which uses Subtitle as the rendering engine. |
7th June 2023, 15:57 | #8 | Link | |
All three new parameters (bold/italic/noaa) were added to some debug filters: ShowSMTPE, ShowFrameNumber, ShowCRC32, ShowTime Check readme_history.txt |
subtitle fonts bold |
