Old 2nd May 2020, 23:57   #41  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by pinterf View Post
In what aspect is VS syntax more elegant aside from using [] for arrays?
Pascal order (name: type) is obviously always the most elegant!
Myrsloik is online now   Reply With Quote
Old 3rd May 2020, 01:51   #42  |  Link
MeteorRain
結城有紀
IMHO anything that is easier to read, to parse, to extend, is more elegant. If this is done in a more dynamic / higher level language I would simply use a hash map, or a JSON string because it's more readable, have standard library to parse, and can easily be extended should there be extra information adding to the content.
Now this is an ancient C/C++ project, so I don't want to add too many 3rd party things and too many modern things to it. That's why I didn't propose JSON (adding a JSON library to the dependencies). One (and probably the only one) that is both familiar to plugin authors and more readable, would be VS syntax. Again, I'm brainstorming various ways of doing things. One simple way would be what I said, use non-conflicting annotation to indicate arrays. Ugly, not nice, but is a workaround to support a little more thing. The other simple way would be switching to a more elegant syntax and completely solve this problem.
AVS was an ancient project, and lots of things were done in the way that would have been done differently if today's technologies and concepts are provided. But at the end of the day, it's still your discretion whether to move on from an old decision to a modern-er thing.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 4th May 2020, 05:17   #43  |  Link
real.finder
Originally Posted by real.finder View Post
I just note that Asd did backport SmoothUV and DeDot and DeCross from VS, cool
edit: and MatchHistogram, MSharpen
more about Asd https://forum.doom9.org/showthread.p...19#post1871719 and https://forum.doom9.org/showpost.php...postcount=4668
Originally Posted by tormento View Post
To whom redact AviSynth+ Wiki: what about starting to divide plugins into AVS supported interface versions?
It could be easier for programmers to start a revision of the missing plugins.
ok, so I will mention what not has HBD yet
1st is plugins that has VS ports with HBD:-
1 - EEDI3
2 - Dither_resize16/fmtconv
3 - SangNom2/SangNomMod
4 - TTempSmooth
5 - EEDI2
6 - TCanny (there are TCannymod by chikuzen but I think with no HBD)
7 - Yadifmod (there are Yadifmod2 by chikuzen with not completed HBD)
8 - DeblockPP7
9 - median
10 - tbilateral
11 - tedgemask
12 - MSmooth
13 - ASharp
14 - degrainmedian
15 - TDeint
plugins that has VS ports but no HBD:-
1 - scxvid (there are no x64 in avs yet)
2 - hqdn3d (there are avs port but with 16bit hack)
3 - ssiq (there are no x64 in avs yet)
See My Avisynth Stuff
Old 4th May 2020, 07:57   #44  |  Link
pinterf
I'm working with Delphi at my proper office work, sometimes I'm mixing up the C the variable-type order (not to mention the assignment ':=' vs. '=' and the comparison operators as well )
pinterf is offline   Reply With Quote
Old 5th May 2020, 22:26   #45  |  Link
real.finder
1 - EEDI3
4 - TTempSmooth
5 - EEDI2
8 - DeblockPP7
9 - median
10 - tbilateral
11 - tedgemask
12 - MSmooth
13 - ASharp
14 - degrainmedian
15 - TDeint
and there are some filters seems has no VS ports
1 - VariableBlur (it was planed by tp7)
2 - frfun7 (useful for Dot Crawl Removal, used in DDComb)
3 - GradFun2db (maybe it can be replaced with f3kdb?)
4 - LGhost
Old 6th May 2020, 10:37   #46  |  Link
feisty2
I'm Siri
feisty2's Avatar
I tried to port frfun7 and found it was closed source
feisty2 is offline   Reply With Quote
Old 6th May 2020, 11:28   #47  |  Link
real.finder
did you tried ask Prunedtree in IRC for the source code?
Old 6th May 2020, 17:02   #48  |  Link
Reel.Deel
I emailed pruned sometime ago and asked him if he would release the source code but no reply.
First time I contacted him was thru IRC then email, that is how FRFun7 (2013) came about.
Old 6th May 2020, 17:45   #49  |  Link
real.finder
maybe you are not a Developer so he didn't, since he previously was parole that the code should be cleaned and developed before publication (as tp7 said for Checkmate plugin)
anyway, there are always reverse engineering option
Old 6th May 2020, 18:22   #50  |  Link
feisty2
I'm Siri
feisty2's Avatar
dude, deciphering assembly is HARD
Old 6th May 2020, 18:33   #51  |  Link
real.finder
how SEt, tp7 and jackoneill did it then?
anyway even if you got the source code I think it don't has C code just like most old plugins
Old 6th May 2020, 18:40   #52  |  Link
feisty2
I'm Siri
feisty2's Avatar
deciphering a few clearly outlined functions written in assembly with possibly also comments is not the same as blind-deciphering an executable... especially if the binary has been heavily optimized or involves some weird shit like C++ name mangling
Old 6th May 2020, 18:42   #53  |  Link
videoh
Useful n00b
Instead of all that reversing nonsense, you have to re-implement the algorithms. What's the big deal?
Old 6th May 2020, 21:12   #54  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Re-implementing the algorithm, makes sense.
Out of pure curiosity, you meant using things like IDA Pro and start from there? I'm not an avs developer, but I can tell you that staring at several lines of disassembled code totally undocumented is way beyond my understanding. (And I believe it would be a pain in the b... for many experienced developers as well).
I'm always surprised by how people in the past used to rely on assembly for everything and were so good in it while I can't really wrap my mind around that as I generally lose track of the main picture after just a few lines (i.e I might understand what a single block of code is doing, but I fail to understand what the program as a whole is doing... )
(I still remember people of the David Brailsford era carrying mugs with "Real man code in Assembler" before retiring )
Old 7th May 2020, 09:43   #55  |  Link
feisty2
I'm Siri
feisty2's Avatar
(certain) engineers code in assembly, mathematicians code in lisp, scientists code in... who knows
anyways, it has nothing to do with "real man"
Old 7th May 2020, 16:27   #56  |  Link
real.finder
I am not a programmer, but I see tp7 said this back then in IRC (about sangnom2)
also it's what SEt did in awarpsharp2
anyway, tp7 got the source code of Checkmate from Prunedtree as I said, so I think any developer can do ask Prunedtree for the code like https://forum.doom9.org/showthread.p...60#post1792960 and https://forum.doom9.org/showthread.p...79#post1825279
Old 7th May 2020, 16:58   #57  |  Link
Groucho2004
It used to be a joke a long time ago (or maybe still is?), particularly when C# was introduced (as far as I recall).
Real men code in C++
No, real men code in C
No, real men code in assembler
No, real men punch in hex code on numeric keyboards
etc...
By the way, this is a piece of art:
Groucho's Avisynth Stuff
Old 7th May 2020, 18:57   #58  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Uhhh! Hexadecimal with a 7 Segments display!
I studied those in my Digital Electronics class!
This is what I came up with to count in Hex (0, 1, 2, 3, 4, 5, 6, 7, 8, 9, A, B, C, D, E, F) in a 7 Segments Display:
I studied a lot for that exam and I was sure I was going to kill it, but unfortunately things didn't go as planned I've got 23 out of 30
I was so upset that day...
(but I accepted the grade of course, I have never refused one, that's my "mantra" xD)
That was back when I was studying for my bachelor degree...
Will I ever get my master degree? Who knows...
Old 7th May 2020, 19:02   #59  |  Link
Groucho2004
Cool, a fellow electronics engineer. How old are you, if I may ask?
Old 7th May 2020, 19:09   #60  |  Link
feisty2
I'm Siri
feisty2's Avatar
masters are mostly cash-cow programs, go for a PhD program instead if ur interested in grad schools
