Old 15th February 2018, 11:09   #81  |  Link
PCU
Originally Posted by cork_OS View Post
Oops, warez detected!
call it pirate.
PCU is offline   Reply With Quote
Old 15th February 2018, 16:13   #82  |  Link
clsid
AAC files do not contain duration information. The duration must be guessed based on bitrate and size. This file has variable bitrate, so the guessed duration is not accurate. That can't be fixed.
You should mux the aac file into the mkv file with MkvToolnix. Then it will play perfectly.
Old 15th February 2018, 16:32   #83  |  Link
pikaczu
Posts: n/a
I checked in mpc be, it's good time.
Old 16th February 2018, 06:05   #84  |  Link
boxmax
Hi All
any one can add "subscene" in Provider Subtitle ?
i don't know how add that ?
maybe this can help
https://pypi.python.org/pypi/subscene-api/2.0.0
and thanks for support
boxmax is offline   Reply With Quote
Old 16th February 2018, 06:37   #85  |  Link
Scoty
Scoty's Avatar
How can i change Interface Language?
Gaming-PC: AMD 7700X | RTX 4070 Ti | ASUS ROG Strix X670E-E Gaming WIFI | G-Skill RGB 32GB, DDR5-6000 | Corsair HX1200 | Lian Li Air Mini |
Scoty is offline   Reply With Quote
Old 16th February 2018, 09:35   #86  |  Link
varekai
Suspended for forum rule violations
Keyboard press O --> Options --> Player --> Language
varekai is offline   Reply With Quote
Old 16th February 2018, 09:42   #87  |  Link
LigH
LigH's Avatar
(O)ptions: the very first category group in the left tree view: [Player]
New German Gleitz board
Old 16th February 2018, 11:39   #88  |  Link
Scoty
Scoty's Avatar
Ok German not work?
Edit: Download full now and working now.
Old 16th February 2018, 11:46   #89  |  Link
LigH
LigH's Avatar
If you only downloaded the most recent "EXE only update", then you would have missed all the supplemental DLL's...
First the full archive, then the new EXE as update. And it works well in German.
Und im Gleitz-Board kann man das auch in deutsch besprechen.
Old 16th February 2018, 12:02   #90  |  Link
Scoty
Scoty's Avatar
The last entry is very old on German Forum.
Old 16th February 2018, 12:41   #91  |  Link
LigH
LigH's Avatar
True, that was a "News" topic which did not get regular care... but discussions how to use it would happen in a different subforum, anyway.
Old 18th February 2018, 09:16   #92  |  Link
pikaczu
Posts: n/a
do I understand that there is no chance for my changes + improved handling of the aac file?
will there be new versions of codecs and fixes / functions?
Old 18th February 2018, 17:36   #93  |  Link
LigH
LigH's Avatar
At least there will not be any development effort by clsid.
If the changes have to be made in LAV Filters, then there is a chance that MPC-HC 1.7.14+ may include a new set of internal LAV Filters some day.
If the changes have to be made in MPC-HC, then clsid will wait for patches provided by anyone else.
Old 18th February 2018, 19:50   #94  |  Link
pikaczu
Posts: n/a
hopefully someone would do it.
Old 20th February 2018, 19:32   #95  |  Link
PCU
how to normalize the audio of an quite movie in mpc-hc?
Old 20th February 2018, 20:03   #96  |  Link
nussman
Can you stop trolling here?
nussman is offline   Reply With Quote
Old 20th February 2018, 20:27   #97  |  Link
PCU
just kidding, ok?
Old 22nd February 2018, 15:12   #98  |  Link
clsid
MPC-HC 1.7.15 is now available. It includes latest stable release of LAV Filters (v0.71).
Old 22nd February 2018, 15:31   #99  |  Link
PCU
guys, what do you recommend for hardware acceleration: intel quicksync or d3d11?
Old 22nd February 2018, 15:53   #100  |  Link
pikaczu
Posts: n/a
thanks, I wish there was a fix for aac files
as there will be no changes.
