Old 25th June 2018, 16:44   #1  |  Link
K.i.N.G
How to do 3D Lut color correction (.3DL .Cube) with avisynth(+) ?
I wasn't too happy with the current HDR -> SDR filters available so I decided to create some luts but I can't find anything online on how to use them in avisynth?
Surely this must be possible? Since luts are such commonly used files for this kind of thing.
K.i.N.G is offline   Reply With Quote
Old 25th June 2018, 17:58   #2  |  Link
videoh
Which ones did you try and why were you unhappy with them?
Old 26th June 2018, 14:08   #3  |  Link
TheFluff
Excessively jovial fellow
There is a VapourSynth filter that can apply 3D LUT's in .cube format (some Adobe thing I believe), FWIW.
Old 29th June 2018, 12:48   #4  |  Link
K.i.N.G
DGHable and DGReinhard ... i get the impression some tones are problematic.
With my current test im having problems with orange reds (getting too orange yellow). Making skin tones not as good as i'd like.
Maybe its just me? I've only tested 2 discs for now.
Also, I'm not a big fan of exaggerated tinting of a whole movie (there are exceptions) or remasters ruined by bad grading.
Good examples are "the good, the bad and the ugly remastered" or the lord of the rings trilogy extended edition... where the grading looks much worse than the original.
So also in those cases it would be sweet if I could just use/load a lut with corrections I did (to my personal taste).
Old 29th June 2018, 12:54   #5  |  Link
K.i.N.G
Nice, I'll have to try that out later...
Im using DGhable & DGreinhard in avisynth (through StaxRip) though so I'd be more usefull for me if there was a solution using avisynth
Old 9th August 2018, 20:51   #6  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I came across this topic looking for a LUT plugin in Avisynth/Avisynth+.
I'm actually using ffmpeg to apply my LUTs, but it would be really useful to have the VapourSynth filter ported to Avisynth.
Broadcast Encoder
LinkedIn
Old 10th August 2018, 06:58   #7  |  Link
Yanak
I once asked here if somehow possible to port this into avisynth http://forum.doom9.org/showthread.ph...29#post1837229
Seems like it's something that will be difficult... it's really something i miss to make avisynth complete for my use, like you i use ffmpeg to do this task for now when i need it.
Yanak is offline   Reply With Quote
Old 11th August 2018, 00:50   #8  |  Link
TheFluff
I doubt it would be hard to port, the plugin interface is separated from the actual processing.
Old 11th August 2018, 00:51   #9  |  Link
videoh
I've started working on it.
Old 11th August 2018, 07:24   #10  |  Link
Yanak
You cannot imagine how sweet those words sound to my hears
If you manage to get this working on avisynth it will be a game changer for me and i imagine many others.
Thank you very much.
Old 11th August 2018, 14:52   #11  |  Link
videoh
What formats do you need, in order of priority?
Old 11th August 2018, 16:05   #12  |  Link
Yanak
For me I use mostly .cube files, not sure what others use the most, .3dl it's very rare to use those for me, i use more haldclut files than .3dl to say
Thank you.
Old 11th August 2018, 16:17   #13  |  Link
videoh
I was referring to the input and output pixel formats of the filter itself. Can you specify those please?
Assuming the filter exists, what would your script look like?
Old 11th August 2018, 16:51   #14  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Definitely .cube as cube LUT format.
As to the color space and bit-depth, I would say 4:2:0 8bit / 4:2:0 10bit input and output.
LUTs are generally used to apply a specific type of color correction in post-production, but in a 2018-Avisynth scenario, I would say that they would be mainly use them for HDR.
In other words, I think people would use them to tone-map HDR to SDR, HLG to HDR10 and so on.
So I would say that Rec.709 and Rec.2020 should be supported as well.
Is it possible?
If you wanna test out two .cubes, you can find mine here:
Originally Posted by FranceBB View Post
Broadcast Encoder
LinkedIn
Old 11th August 2018, 18:08   #15  |  Link
Yanak
^ What he said 420p8 mostly as input, I guess some use it on 422 too, and mostly 420p8/10 as output i think.
Also used on raw footage ( slog from drones for example) to correct colors, or to apply some effects like with CineStyle_S_Curve lut, or Kodachrome effect, can be used to turn stuff recorded in summer with loads or greens into autumn colors etc etc
Old 11th August 2018, 18:15   #16  |  Link
videoh
OK, guys, thank you.
Old 11th August 2018, 19:02   #17  |  Link
WorBry
Easy to convert HaldCLUT to CUBE with IWLTBAP_LUT_Generator. Did that with Pat David's G'MIC Film Emulations:
https://gmic.eu/film_emulation/negat...1.shtml#browse
Would be nice to use those in AVISynth(+).
Nostalgia's not what it used to be
WorBry is offline   Reply With Quote
Old 12th August 2018, 06:51   #18  |  Link
Yanak
Thanks for the link, i'll give it a try soon, G'mic plugin for Gimp is what i often use to create and generate custom haldcluts from static images i modify, then later apply them on videos via FFmpeg, this will certainly help a lot if videoh manage to get this working on avs+ it will be very nice indeed.
Thank you
Old 13th August 2018, 15:13   #19  |  Link
WorBry
You're welcome.
...videoh manage to get this working on avs+ it will be very nice indeed
Yes, it would open up many possibilities.
Old 13th August 2018, 16:27   #20  |  Link
I have no idea if these couple of files are of any interest to anyone (had them for years, never really looked at them much).
Adobe Cube Lut Specs, v1.0(~228KB):- http://www.mediafire.com/file/ptd2lt....0.pdf.7z/file
yCMS_x86, excerpt from manual, (maybe there is an x64 version somewhere)
yCMS - Color Management System
v1.12 2012/11/07
________________________________________________________________________________
INTRODUCTION
yCMS is a Color Management System (CMS) that uses 3-dimensional lookup
tables ("3D LUTs") to perform the conversion between the input and output
color representations. You can read a little more about CMS here:
http://en.wikipedia.org/wiki/Color_management
The idea of using 3D LUTs was due to the intensive computing that needs to
be performed when converting video data between different color spaces. When
using 3D LUTs all computing is performed offline during its creation. The
computed 3D LUTs (three, one for each component) are then written to a file
which can later be used, when playing videos or viewing photos, simply by
mapping the input data through the 3D LUTs. This way, the conversion can be
performed at runtime using lower computational power and leaving more CPU
available for other tasks. Since all the computing is performed offline its
precision can be increased by using 64bit floating point (per component)
through out all the conversion chain.
(~239KB):- http://www.mediafire.com/file/8ppce1...S_x86.rar/file
EDIT: Above yCMS_x86 (home site is now dead) and thread here on D9 not active since 2013.
https://forum.doom9.org/showthread.p...highlight=ycms
EDIT:
Apply two 3x3 matrices to each pixel? :- https://forum.doom9.org/showthread.php?p=1706626
RGB/XYZ Matrices:- http://www.brucelindbloom.com/index....YZ_Matrix.html
3dl, cube, hdr, lut, sdr
