Old 10th January 2019, 18:08   #61  |  Link
lansing
Ok after reading the hable reference article from ifb's tonemap page, I just realized that hable is not for 4k hdr tv to sdr conversion. It was created for images and SDR games to make them looks HDR. So this whole approach to use it for "4K HDR TV content -> SDR" is just wrong. The right tool for this in vapoursynth is DGHDRtoSDR.
Old 10th January 2019, 18:20   #62  |  Link
asarian
So, maybe you know a solution to my problem too. See: DGHDRtoSDR lacking in contrast
Which also makes me wonder, would there be a way for DGHDRtoSDR to extract values like 'Max luminance: 1000' from the metadata itself?
Gorgeous, delicious, deculture!
asarian is offline   Reply With Quote
Old 11th January 2019, 08:58   #63  |  Link
lansing
I don't have UBD content, so I don't know what they look like.
For HDR TV, HDR was suppose to look different from SDR, as it preserves detail on both highlight and shadow instead of "white" being blown out in SDR in comparison. But as a result, it will look washier and less contrast than SDR. You HDR result looks ok to me except for the saturation.
Old 26th March 2019, 10:22   #64  |  Link
Alexkral
I don't think that matters at all, it's a curve as valid as any other and as you can see mpv is using it for this purpose.
Alexkral is offline   Reply With Quote
Old 26th March 2019, 16:15   #65  |  Link
lansing
And maybe that's why it gives the obvious wrong color on HDR content?
Old 26th March 2019, 17:04   #66  |  Link
asarian
I do not have (1080p) Blu-Rays for all UHD discs I own, so I will only seldom be able to do a comparison. Hence, my initial question, "would there be a way for DGHDRtoSDR to extract values like 'Max luminance: 1000' from the metadata itself?" And then for contrast too, of course.
Old 26th March 2019, 17:45   #67  |  Link
Alexkral
I don't see those wrong colors in mpv, so the problem is in the script, not in the curve. It may be because the script is tone mapping the RGB channels instead of the luminance. I don't know what DGHDRtoSDR does in that sense, but it seems to be using the Reinhard TMO which is much simpler.
Old 26th March 2019, 17:54   #68  |  Link
Alexkral
@asarian
DGHDRtoSDR doesn't even have a parameter for that.
Old 26th March 2019, 21:25   #69  |  Link
asarian
@asarian
Why would it need a parameter for that?! Preferably, it would find and extract the info on its own from the UHD Blu-Ray structure (DV layer and what not; or, if it needs a parameter per se, a location of the meta-data file).
Old 26th March 2019, 22:26   #70  |  Link
Alexkral
It would still need a parameter internally for the math.
Old 13th April 2019, 19:45   #71  |  Link
age
I was testing the tonemapping using the hue-constant curves from adobe
https://github.com/Beep6581/RawThera.../curves.h#L919
https://github.com/Beep6581/RawThera.../curves.h#L974
Here's a new script
tonemapping.py
import vapoursynth as vs
def tm_hable(clip="",source_peak=1000 ) :
    core = vs.get_core()
    c=clip
    source_peak=source_peak
    LDR_nits=100
    exposure_bias=source_peak/LDR_nits
    o=c
    c=core.std.Limiter(c, 0)
    r=core.std.ShufflePlanes(c, planes=[0], colorfamily=vs.GRAY)
    g=core.std.ShufflePlanes(c, planes=[1], colorfamily=vs.GRAY)
    b=core.std.ShufflePlanes(c, planes=[2], colorfamily=vs.GRAY)
    lum = core.std.Expr(clips=[r,g,b], expr="0.216 x * 0.715 y * + 0.0722 z * +")
    lum=core.std.Limiter(lum, 0)
    lum=core.std.ShufflePlanes(lum, planes=[0], colorfamily=vs.RGB)
    rr="x  {exposure_bias} * 0.15 x  {exposure_bias} * * 0.05 + * 0.004 + x  {exposure_bias} * 0.15 x  {exposure_bias} * * 0.50 + * 0.06 + / 0.02 0.30 / - 1 {exposure_bias} 0.15 {exposure_bias} * 0.05 + * 0.004 + {exposure_bias} 0.15 {exposure_bias} * 0.50 + * 0.06 + / 0.02 0.30 / - / * ".format(exposure_bias=exposure_bias)
    gg="y  {exposure_bias} * 0.15 y  {exposure_bias} * * 0.05 + * 0.004 + y  {exposure_bias} * 0.15 y  {exposure_bias} * * 0.50 + * 0.06 + / 0.02 0.30 / - 1 {exposure_bias} 0.15 {exposure_bias} * 0.05 + * 0.004 + {exposure_bias} 0.15 {exposure_bias} * 0.50 + * 0.06 + / 0.02 0.30 / - / * ".format(exposure_bias=exposure_bias)
    bb="z {exposure_bias} * 0.15 z  {exposure_bias} * * 0.05 + * 0.004 + z  {exposure_bias} * 0.15 z  {exposure_bias} * * 0.50 + * 0.06 + / 0.02 0.30 / - 1 {exposure_bias} 0.15 {exposure_bias} * 0.05 + * 0.004 + {exposure_bias} 0.15 {exposure_bias} * 0.50 + * 0.06 + / 0.02 0.30 / - / * ".format(exposure_bias=exposure_bias)
    r1 = core.std.Expr(clips=[r,g,b], expr="x y >=   y z > {rr}   z x > x y - z y - / {bb} {gg} - * {gg} +     z y > {rr} {rr}   ?  ?     ?    x z >=   x z - y z - / {gg} {bb} - * {bb} + z y >  {rr}   {rr}            ? ? ?     ".format(exposure_bias=exposure_bias,rr=rr,gg=gg,bb=bb))
    g1 = core.std.Expr(clips=[r,g,b], expr="x y >=   y z > y z - x z - / {rr} {bb} - * {bb} +  z x > {gg}      z y > {gg}  {gg}   ?  ?     ?    x z >=   {gg}  z y >  y x - z x - / {bb} {rr} - * {rr} +   {gg}            ? ? ?        ".format(exposure_bias=exposure_bias,rr=rr,gg=gg,bb=bb))
    b1 = core.std.Expr(clips=[r,g,b], expr="x y >=   y z > {bb}   z x > {bb}      z y > z y -  x y - / {rr} {gg} - * {gg} +  {bb}   ?  ?     ?    x z >=   {bb}  z y >  {bb}   z x - y x - / {gg} {rr} - * {rr} +            ? ? ?    ".format(exposure_bias=exposure_bias,rr=rr,gg=gg,bb=bb))
    crgb=core.std.ShufflePlanes(clips=[r1,g1,b1], planes=[0,0,0], colorfamily=vs.RGB)
    lumtm = core.std.Expr(clips=[r1,g1,b1], expr="0.216 x * 0.715 y * + 0.0722 z * +")
    lumtm=core.std.Limiter(lumtm, 0)
    lumtm=core.std.ShufflePlanes(lumtm, planes=[0], colorfamily=vs.RGB)
    clum = core.std.Expr(clips=[o,lum,lumtm], expr=" x {exposure_bias} *  y {exposure_bias} *  / z *  ".format(exposure_bias=exposure_bias))
    clum=core.std.Limiter(clum, 0)
    mask=core.std.Expr(clips=[lum,lumtm], expr=" x {exposure_bias} * y - abs {exposure_bias}  1 - /  ".format(exposure_bias=exposure_bias))
    mask=core.std.Limiter(mask, 0,1)
    ctemp=core.std.MaskedMerge(crgb, lumtm, mask)
    c=core.std.Merge(clum, ctemp, 0.5)
    return c
It looks similar to the new algo used by madvr at 200 nits target, not as good as madvr because the script needs a gamut compression when converting to rec.709 color primaries
http://screenshotcomparison.com/comparison/133859
http://screenshotcomparison.com/comparison/133858
http://screenshotcomparison.com/comparison/133861
It has only a parameter source_peak
this is the usage of the script
import tonemapping
c = core.ffms2.Source(source = 'C:/Users/.../videos/HDR.mp4')
source_peak=1200
matrix_in_s="2020ncl"
transfer_in_s="st2084"
c=core.resize.Bicubic(clip=c, format=vs.RGBS, filter_param_a=0, filter_param_b=0.75, matrix_in_s=matrix_in_s,chromaloc_in_s="center",chromaloc_s="center", range_in_s="limited",dither_type="none")
c=core.resize.Bilinear(clip=c, format=vs.RGBS, transfer_in_s=transfer_in_s, transfer_s="linear",dither_type="none", nominal_luminance=source_peak)
c=tonemapping.tm_hable(c,source_peak=source_peak )
c=core.resize.Bilinear(clip=c, format=vs.RGBS, primaries_in_s="2020", primaries_s="709",dither_type="none")
c=core.resize.Bilinear(clip=c, format=vs.RGBS, transfer_in_s="linear", transfer_s="709",dither_type="none")
c=core.resize.Bicubic(clip=c, format=vs.YUV420P8,matrix_s="709", filter_param_a=0, filter_param_b=0.75, range_in_s="full",range_s="limited", chromaloc_in_s="center", chromaloc_s="center",dither_type="none")
c.set_output()
age is offline   Reply With Quote
Old 16th May 2019, 20:26   #72  |  Link
chipseps
Originally Posted by age View Post
Thank you all for your suggestion and the hdr samples.
Well I've discovered some interesting things....
First, a better version of the hable tonemapping that gives better contrast,brightness and saturation.
http://screenshotcomparison.com/comparison/203550
I've tried different algorithms, the aces tonemapping too but I don't like it very much.
Here a good link for a lot of open source tm operators :
https://github.com/tizian/tonemapper.../src/operators
And a different version of aces:
https://github.com/keijiro/PostProce...emapping.cginc
new script with correct parameters
c = core.ffms2.Source(source  = 'C:/bla')
source_peak=1000 #set manually
LDR_nits=100     #set 150 or 200 for lowering the brightness
c=core.resize.Bilinear(clip=c, format=vs.YUV444PS, range_in_s="limited", range_s="full",chromaloc_in_s="center",dither_type="none")
c=core.resize.Bicubic(clip=c, format=vs.RGBS, matrix_in_s="2020ncl", range_in_s="full",dither_type="none")
c=core.resize.Bilinear(clip=c, format=vs.RGBS, transfer_in_s="st2084", transfer_s="linear",dither_type="none", nominal_luminance=source_peak)
exposure_bias=(source_peak/LDR_nits)
#hable tone mapping  correct parameters
#["A"] = 0.22
#["B"] = 0.3
#["C"] = 0.1
#["D"] = 0.2
#["E"] = 0.01
#["F"] = 0.3
#["W"] = 11.2
#((x * (A*x + C*B) + D*E) / (x * (A*x+B) + D*F)) - E/F"
tm = core.std.Expr(c, expr="x    {exposure_bias} * 0.22 x    {exposure_bias} * * 0.03 + * 0.002 +    x   {exposure_bias} * 0.22 x   {exposure_bias} * * 0.3 + * 0.06 + / 0.01 0.30 / -  ".format(exposure_bias=exposure_bias),format=vs.RGBS)#12=1200 nits / 100 nits
w = core.std.Expr(c, expr="{exposure_bias} 0.22 {exposure_bias} * 0.03 + * 0.002 + {exposure_bias} 0.22 {exposure_bias} * 0.3 + * 0.06 + / 0.01 0.30 / -  ".format(exposure_bias=exposure_bias),format=vs.RGBS)
c = core.std.Expr(clips=[tm,w], expr=" x  1 y  / *  ",format=vs.RGBS)
#c=core.fmtc.primaries(clip=c, prims="2020", primd="709")
c=core.resize.Bilinear(clip=c, format=vs.YUV420P8, matrix_s="709", range_in_s="full",range_s="limited",chromaloc_in_s="center")
c.set_output()
Hi you! With color filtering like this, what command must we use to crop and resize to 1080p? Because I'm newbie encodec so I don't know! Hope to help you! thank you very much!
chipseps is offline   Reply With Quote
Old 16th May 2019, 21:16   #73  |  Link
gonca
The master display data, CLL, and FALL is "extracted by DGIndexNV
gonca is offline   Reply With Quote
Old 16th May 2019, 21:42   #74  |  Link
videoh
... and recorded in the DGI file.
hdr, sdr
