Old 23rd July 2011, 18:18   #8841  |  Link
Wile-E-Coyote
Oh well, attachments to this forum sometimes take weeks to be approved. You better upload them somewhere else...
There you go
Wile-E-Coyote is offline   Reply With Quote
Old 23rd July 2011, 18:21   #8842  |  Link
JarrettH
Originally Posted by Wile-E-Coyote View Post
The copy-protect fail has nothing to do with macrovision-fail. For some reason something (MPC? Directshow? Windows?) believes you are about to rip the DVD you're trying to watch on your hardware. Using a software that gets rid of copy-protections solved this issue for me (can't say more than that here I'm affraid).
As for the blank screen, I've never had this issue so I can't really tell.
Here's the filters I use to play DVDs in MPC-HC with madVR.
LAVSplitter (prefer)
LAV Audio Decoder (prefer)
NVidia Video Decoder (default merit)
ffdshow Audio Processor (prefer)
You can replace NVidia Video Decoder with ddfshow, it works too. I use NVidia's for hardware acceleration, but if LAV Cuvid worked with DVDs I'd be using that.
@madshi : I'll be testing 0.68 and report back if the gree screen problem is still present
How are you getting NVIDIA video decoder to appear in the external filters list? I mean the only one I know of is the ancient PureVideo one which was an application to install.
Good observation though...the macrovision error doesn't happen anymore
Old 23rd July 2011, 18:35   #8843  |  Link
madshi
Ok, I can see one small bug that creeped in, but I somehow doubt that it causes this problem. Anyway, let's give it a try. Here's a special build:
http://madshi.net/madVR69test.zip
Does that fix the problem? If not, try deactivate the option "delay playback start until render queue is full". Does that help?
Old 23rd July 2011, 18:36   #8844  |  Link
Wile-E-Coyote
Well yeah that's the one, I installed the application and added the filter to my external filter list.
Old 23rd July 2011, 18:39   #8845  |  Link
Wile-E-Coyote
Installing 0.69 didn't help, but ticking off "delay playback start until render queue is full" did. Should've tinkered a bit before screaming for help
Old 23rd July 2011, 19:48   #8846  |  Link
kostik
Thanks Madshi for your response. But still what is the need in internal decoder if we use ffdshow or other decoders :\ I am confused .
kostik is offline   Reply With Quote
Old 23rd July 2011, 19:53   #8847  |  Link
dansrfe
I second that
Old 23rd July 2011, 19:55   #8848  |  Link
fairchild
It's for something up-and-coming he has with the renderer which he is not ready to talk about. If you feel like using the decoders to test you can. One of the NOW benefits you get from using his internal decoder is that it will properly decode 10-bit 4:4:4 x264 clips. (I get artifacts with ffdshow) It's not that common yet, but I verified that with the internal libav codec I can play a demo 10-bit 4:4:4 x264 clip glitch free. The example clip I'm referring to is:
BBB444p10.mkv
from http://x264.nl/developers/Dark_Shikari/
MPC-HC/MPC-BE, Lav Filters, MadVR
CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S
fairchild is offline   Reply With Quote
Old 23rd July 2011, 20:14   #8849  |  Link
ForceX
madVR is giving black screen if color/gamma correction is enabled with RGB32 video input.
ForceX is offline   Reply With Quote
Old 23rd July 2011, 20:52   #8850  |  Link
cyberbeing
Broadband Junkie
Fixed Bug: The subtitle sample I gave you is now fixed in 0.69.
Old Bug: The frozen black screen when using the refresh rate changer and the internal decoders still exists in 0.69.
http://www.mediafire.com/?c5oud6irdlgoxcg
New Bug: Black screen with RGB32 output from FFDShow
http://www.mediafire.com/?lgw6yrkwe0mvjy6
Other: madVR [benchmark] is still 0.67.
Status Update: It appears the MPC-HC internal subtitle renderer is what is causing the madVR render queue (upload queue as well in cases of high CPU load) to fluctuate and produces a high number of delayed frames using 1920x1080 @120hz. Anything you can do about that?
Old 23rd July 2011, 21:16   #8851  |  Link
Gleb Egorych
When I try to run Zoom Player 8 RC3 with madVR 0.69 as a video renderer ZP says there is an error in ntdll.dll. 0.67 is OK.
Gleb Egorych is offline   Reply With Quote
Old 23rd July 2011, 21:24   #8852  |  Link
Luv
Surprise,surprise,Powerdvd h.264 (While coreavc 2.0 does not) and mpeg2 decoders do convert from 4:2.0 to 4:2:2 ! The wmp vc-1 decoder is fine.
Now,how do I get to use the embedded madvr decoders with Zoomplayer,please ?
Luv is offline   Reply With Quote
Old 23rd July 2011, 21:24   #8853  |  Link
alph@
Replicant
alph@'s Avatar
yes, me too, core avc rgb 32 out ffdshow rgb 32 black screen, solved by passing the output in yv12.
alph@ is offline   Reply With Quote
Old 23rd July 2011, 21:33   #8854  |  Link
Blight
Software Developer
Blight's Avatar
v0.69 bug report:
Instantly seeking after the graph is built (used by the 'automatically restore last media position on replay' function) causes a crash:
Access violation at address 77C52D37 in module 'ntdll.dll'. Read of address 05E23EB4.
Here's the MadVR debug log file:
http://t.inmatrix.com/madVRlog.zip
It doesn't happen 100% of the time. For example, it happens with (multiple) MP4 files split by the MPC MP4 splitter and FLV files split with either the LAV or MPC Splitters.
All contain H264 video, which is decoded by FFDShow (latest build).
However, no crashes when playing+seek a Matroska MKV file, split with LAV Splitter containing H264 video or AVI files with microsoft splitter and XVID video.
Switching the video renderer to EVR eliminates the crash.
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
Old 23rd July 2011, 21:36   #8855  |  Link
JarrettH
Bad news is : it won't read DVDs. I didn't touch anything on my filters settings, I uninstalled madVR 0.66, intalled 0.68, kept all settings to default and when trying to launch a DVD it is set to pause and can't be played. I reverted back to 0.66 and DVDs launch fine.
See that's my problem too!!! It goes straight to set to pause with a blank screen. (Your solution may have worked so far Wile.)
Old 23rd July 2011, 21:40   #8856  |  Link
JarrettH
YESSSSSSSS went back to 0.66 and DVDs work
Seek bar does not work when put in full screen mode fyi
Using LAV Splitter, LAV Audio, and Microsoft DTV-DVD
Old 23rd July 2011, 21:42   #8857  |  Link
Luv
Blight,since you are there,would you mind explaining me what I have to do to use madVR internal decoders (I have ZP 5.02)? Thanks.
Old 23rd July 2011, 21:48   #8858  |  Link
italospain
Set madVR as h264/mpeg2/vc1 decoder in smart play
italospain is offline   Reply With Quote
Old 23rd July 2011, 21:51   #8859  |  Link
leeperry
Kid for Today
for the new version!
ffdshow RGB output levels are now automatically detected and handled properly
I've run a comparison between 0.67/0.69/HR in 0-255 RGB32/YV12: http://www.mediafire.com/?5zw7z5ra6gzs6px
<PS: It's 0.67, not 0.66!>
AFAIK HR speaks the truth, 0.67 is wrong in YV12(but OK in RGB32) and 0.69 is fubar
if you could also fix the levels/gamma in YV12, I'd greatly appreciate it....as I'm forced to use RGB32 atm to get the right colors when feeding PC levels content.
Old 23rd July 2011, 21:55   #8860  |  Link
Luv
Thanks for your answer but I can't find them in the list plus the extension is ".mvr".What should I do from there ?
