Old 13th January 2019, 19:28   #54281  |  Link
madjock
well no: https://abload.de/img/wellno2ikpj.png
good job HDMI organisation.
and i'm sending 10 bit just for the fun of it with an nvidia card.
Thats not a normal NVCP...show us RGB - Full then win a prize
Old 13th January 2019, 19:37   #54282  |  Link
do yourself and this thread a favour and move on from this topic.
nev has said anything that needs to be said about this.
sending 10 bit RGB is a no issue with AMD cards the nvidia controls are not as flexible as these from AMD in this regard.
sending 12 instead 10 would always be fine if the processing in TVs would be solid.
Old 13th January 2019, 19:47   #54283  |  Link
Warner306
That doesn't make much sense. It should be option, but most UHD players output 12-bit YCbCr 4:2:2.
Old 13th January 2019, 20:05   #54284  |  Link
madjock
Old 14th January 2019, 01:01   #54285  |  Link
ryokoseigo
Could anyone recommend me the settings to best lower noise?
I'm wondering if the high sharpness is causing more grain in the videos I'm watching. I'm using 4k hdr videos of high quality bitrate through MPC-BE and MAdVR. But some videos just dont look very good, for example The Prestige looks like a grainy mess, and Infinitywar isnt very great.
Are there settings I should use that are simply better then other options? I have LAV hardware decoder set to d3d11.
I'm using gtx 1080ti and 8700k so power shouldnt be an issue.
ryokoseigo is offline   Reply With Quote
Old 14th January 2019, 05:37   #54286  |  Link
ryrynz
ryrynz's Avatar
This sounds like film grain, it's meant to be there. Reduce all your sharpening (TV/madVR) and observe, you have 4K high bitrate sources, there is little reason to add even moderate sharpening which may exacerbate noise.
Not sure if you looked but madVR does have a option called 'reduce random noise' under processing -> artifact removal.. Not sure how you missed that. Also your TV itself with have some artifact/noise removal options too.
Old 14th January 2019, 11:34   #54287  |  Link
svengun
you may want to have a look at madleveltweaker.exe
Thanks ! very handy
svengun is offline   Reply With Quote
Old 14th January 2019, 14:36   #54288  |  Link
tp4tissue
tp4tissue's Avatar
Huhn, I are confused now.
If I have nvidia, and I want to output HDR to TV, should my setting on the nvcp output page be 4:2:2 10bit / 12bit ?
or does it not matter, and the Madvr auto pops the screen to NVHDR, which does whatever it does , "which is ??"
I also have an ATI card incoming, what should my output be set for ATI
Ghetto | 2500k 5Ghz
Old 14th January 2019, 14:47   #54289  |  Link
for best results you should always send RGB if possible.
madVR doesn't care about the output of the GPU it just send images the driver which is always RGB.
sorry to hear that. AMD needs 10 bit output from madVR or the AMD HDR API will not work.
the rest doesn't change. you should not go over 10 bit on AMD use the chance of 10 bit RGB on them for a at least in theory untouched output.
Old 14th January 2019, 20:36   #54290  |  Link
glc650
I'm thinking about sending my Radeon 580 back. How does a GTX 1060 6GB compare to a Radeon 580 8GB?. With the 580 I'm able to run NGU A-A low for chroma upscaling and Jinc with sigmoidal light & anti-ringing for image upscaling. I also have most of the image enhancement and upscaling refinement options enabled (with default values).
glc650 is offline   Reply With Quote
Old 14th January 2019, 20:49   #54291  |  Link
tp4tissue
tp4tissue's Avatar
So... got my rx580.
How do I get madtpg to kick into HDR mode, during displaycal.
It seems that -unlike- nvidia, the madtpg won't kick into hdr mode at all ?
I can play an hdr movie, and the regular player will go into amd-hdr mode, and so will the tv.
I've tried both, 09214 and 09217..
This is so confusing
I did, 10bit in display, d3d11, fullscreen in madtpg, win10 hdr OFF
Ghetto | 2500k 5Ghz
Old 14th January 2019, 21:53   #54292  |  Link
Asmodian
You probably need to have it fullscreen so madVR enables 10-bit. This means the TV will go into HDR only when displaying patches.
madVR options explained
Asmodian is online now   Reply With Quote
Old 14th January 2019, 22:13   #54293  |  Link
tp4tissue
tp4tissue's Avatar
I've tried this, displaycal is launching the madtpg process in fullscreen, and the patches are all displayed full screen.
The setup is still not kicking into HDR.
Ghetto | 2500k 5Ghz
Old 14th January 2019, 23:00   #54294  |  Link
ryrynz
ryrynz's Avatar
It's quite a bit faster with NGU. If The 1060 6GB is all you can afford just do it its not like you have a lot of options.
Old 15th January 2019, 09:35   #54295  |  Link
mrmojo666
just saying, in the last months i noticed that sometimes ddu doesn't clean well amd drivers, so after and ddu and driver installation i got no hdr switching, at that point a ddu clean in safe mode + ddu clean in normal mode and then driver installation solved the issue, pay also attention that amd driver must set up to 10/12 bit to get hdr switch working. no need of FSE for HDR with AMD.
bye
AMD Ry 1500x - 8GB - RX460 4GB
TV Philips 55pus6501+ Marantz 1608 avr
WIN10(1903) 4K/444RGB
Mediaportal - Mpc-hc
MADVR-D3D11/10bit
mrmojo666 is offline   Reply With Quote
Old 15th January 2019, 10:08   #54296  |  Link
ileile
wrong edid and multiple identifications
It seems that madVR can't properly read the edid of my monitor. the manufacturer name, the native resolution, etc, all of them are wrong, they looks like NVIDIA defaults, but not read from the device. But other software could read correct values.
And madVR generates many identifications, it may always consider the monitor connected with a new and different configuration when the player runs, so a new entry is added (with same defaults values) and being active (old ones never be active again) every time.
edid data read by madVR:
00 FF FF FF FF FF FF 00 3A C4 00 00 00 00 00 00
00 00 01 04 95 00 00 78 EC 91 A3 54 4C 99 26 0F
50 54 00 20 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 94
02 03 12 71 45 10 04 03 01 00 23 09 07 07 83 01
00 00 02 3A 80 18 71 38 2D 40 58 2C 45 00 B8 6F
21 00 00 1E 56 5E 00 A0 A0 A0 29 50 30 20 35 00
58 54 21 00 00 1A 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CB
and the screenshot.
ileile is offline   Reply With Quote
Old 15th January 2019, 10:29   #54297  |  Link
tp4tissue
tp4tissue's Avatar
bye
For me Madvr playback DOES kick into HDR mode.
However, MADTPG, during displaycal, EVEN in fullscreen mode, will not kick into HDR.
What do you mean amd driver set up 10-12 bit, in the AMD [Display] menu ?.
I will try DDU though, thanks for the suggest.
Ghetto | 2500k 5Ghz
Old 15th January 2019, 11:47   #54298  |  Link
mrmojo666
Yes display settings
MADVR-D3D11/10bit
Old 15th January 2019, 12:17   #54299  |  Link
jmonier
This sounds exactly like the problem I've seen with my LG 34WK95U when connected via the Displayport. (It's fine via HDMI.) I've reported it as a bug and madshi said he'll try to investigate it when he has time.
What monitor and connection do you have?
jmonier is offline   Reply With Quote
Old 15th January 2019, 12:24   #54300  |  Link
Charky
I had the same issue.
I toggled HDR in the Win 10 display options.
Charky is offline   Reply With Quote
