Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD Rebuilder
Old 3rd July 2018, 18:49   #27501  |  Link
MrVideo
MrVideo's Avatar
That's pretty much what I meant by changing the font. As the spacing gets adjusted, the point size changes as well. Otherwise the text in the lines would start overlapping very quickly.
Sorry, wasn't obvious that you were also talking about point size. To me, changing a font doesn't mean changing the point size.
I'll just have to remember to subtract 37 from any vertical position I am interested in (if I really need to be specific). The most I will do is 7 lines a page, but usually only 5. That should result in sticking with the defaults.
My Total Eclipse 2017 Photos
Old 3rd July 2018, 22:58   #27502  |  Link
Lathe
Lathe's Avatar
Thanks for the lecture, Capt Obvious. It's amazing that I've managed to last this long without your insights! That's pretty much what I meant by changing the font. As the spacing gets adjusted, the point size changes as well. Otherwise the text in the lines would start overlapping very quickly.
Lathe is offline   Reply With Quote
Old 11th July 2018, 11:06   #27503  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by MrVideo View Post
I'm hoping that the problem will be solved with a different mobo.
Well, the new Gigabyte mobo is installed. Of course, with the old ASUS drivers installed, the mobo refused to boot: BSOD. Try as I might to remove drivers, it still crashed. M$, in their wisdom (they have wisdom?), do not detect driver failure and not bother to use said driver, so that the OS could boot and allow for the new drivers to be installed. Nope, to easy.
I've not run a project yet, but will in a day, or too. The issue with the keyboard/rodent connected via USB has not shown up yet. Hopefully that is a start of good things to come, like no permission errors.
Old 11th July 2018, 20:39   #27504  |  Link
Lathe
Lathe's Avatar
Rodent...
I hope you get it running Bro!
Old 19th July 2018, 08:16   #27505  |  Link
MrVideo
MrVideo's Avatar
Hurray!!!! The Doom9 server is back up.
I can now run jobs without the dreaded "file not found" or the most often produced "permission denied" errors. The rodent/keyboard issue via the USB connection still happened, but that took a long time before it did. There is a strange display issue that has nothing to do with BDRB. But, it doesn't keep BDRB from doing its thing.
At the moment, I am a happy camper.
Old 19th July 2018, 17:34   #27506  |  Link
Rich86
Rich86's Avatar
Problem: BDRB frequently fails when converting a BD to DVD in movie only mode when including english subtitles.
Ripped using DVDFab64 to hard disc - folders/files mode.
"Starting MPLEX" goes all the way to 100% - but then fails (see below).
[15:17:31] PHASE ONE, Encoding
[15:17:31]PHASE ONE complete
[15:17:31]PHASE TWO - Rebuild Started
- [15:17:31] Building ALTERNATE OUTPUT Structure
- [15:17:31] Converting 1 subtitles to DVD format.
- [15:18:27] Starting MPLEX.
- ERROR in attempt to mux (MPLEX)
[15:20:27] - Failed to REBUILD
This does not happen on all titles - but it seems to happen more frequently as time passes. This latest example is on "Pacific Rim: Uprising" using the BD included in my 4K-UHD set.
multiAVCHD converts these BD titles to DVD just fine - in case that is helpful info.
I am happy to assist in testing or providing more info.
Rich86 is offline   Reply With Quote
Old 19th July 2018, 19:48   #27507  |  Link
Lathe
Lathe's Avatar
Hey, that's great!
'Strange display issue'... Hmmm... have you been getting unwanted pictures of gonca too? I think he's hacked into our systems and then sends questionable pictures of himself in various states of undress.
Terrible thing...
Old 19th July 2018, 20:28   #27508  |  Link
dracore
will bd rebuilder be supporting the encoding of 4k uhd disks to keep menus ect aswell
dracore is offline   Reply With Quote
Old 19th July 2018, 20:34   #27509  |  Link
Ch3vr0n
Jdobbs is looking into that, so don't ask for an ETA
Sent from my Nexus 7 with Tapatalk
Ch3vr0n is offline   Reply With Quote
Old 19th July 2018, 21:55   #27510  |  Link
dracore
Thank you for the reply
Old 20th July 2018, 01:57   #27511  |  Link
MrVideo
MrVideo's Avatar
Nope. Must be only you. Probably because he knew that you would love them.
Old 20th July 2018, 02:28   #27512  |  Link
gonca
Terrible thing...
You looking in the mirror?
gonca is offline   Reply With Quote
Old 20th July 2018, 03:09   #27513  |  Link
Wolfe999
Exactly 2 months since I asked for help in this matter:
When I import the MKV files set in the same folder with the name of the BD I want (all mkv's are compliant), the process always aborts when it enounters latin accentuated words, in this specific case, of 12 files, 4:
-Satélite
-Tecnología
-Área
-Titánico
I'm sure there must be a way to solve it, but I wasn't able to locate it. Would appreciate any help.
So I must understand there is no way to avoid this?
Well, in any case thank you for the interest showed.
Wolfe999 is offline   Reply With Quote
Old 20th July 2018, 03:46   #27514  |  Link
Lathe
Lathe's Avatar
Old 20th July 2018, 04:21   #27515  |  Link
jdobbs
-Satélite
-Tecnología
-Área
-Titánico
I’m sorry that my free support for my free software hasn’t met your standards. I guess I was busy doing something that puts food on the table.
Website: www.jdobbs.net
Old 20th July 2018, 04:23   #27516  |  Link
Lathe
Lathe's Avatar
I love the sense of entitlement. I write free software... and you feel you are entitled to it... but are disappointed with how long I take to provide the free support. Oh well... I guess this is where we are these days.
Don't worry, the rest of us ingrates, deviants, and all around roust-a-bouts appreciate you Boss!
Old 20th July 2018, 12:48   #27517  |  Link
dracore
everything you do is appreciated
Old 20th July 2018, 23:21   #27518  |  Link
MrVideo
MrVideo's Avatar
I suggest changing the accented characters to non-accented during the BDRB build. When the build is done, replace the non-accented characters with the accented characters.
Yes, it is a little bit of extra work, but it will get you through the builds.
Old 21st July 2018, 13:49   #27519  |  Link
Wolfe999
Will try it.
Thank you, MrVideo
Old 21st July 2018, 19:42   #27520  |  Link
AmigaFuture
Hmm, that could be read another way also. Making it known how long it has been between first request, and some people are very precise. My Girlfriend is like that, and me, too sometimes. But I don't get a sense of entitlement, like I do from a guy with combed forward hair and an almost constant "O" face when he talks. Haha!
But I'm also able to read it from your view, Boss, and it does seem that way then. Then again, I haven't keep updated with the thread.. But the Highlighted MrVideo wasn't really called for...that, I view as a little bit of a slap.
Do you remember that "bug" I reported a long time ago about clicking a button with BD-RB and it Looks like it clicked but there isn't a reaction? I came across it the other day, and I DIDN'T remember to record it before I click it. HAHA! It's become a funny for me. I capture it soon enough.
Anyway, other than that and DVD's 16:9 becoming resized if I don't use DirectShow, BD-RB is doing very well. Love this program!
@Lathe
Those pictures...a bit TMI of your personal interests. Perhaps a little less Parrot drink before replying? Hehe!
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
