Old 13th April 2017, 12:56   #14201  |  Link
Brazil2
Originally Posted by LigH View Post
Additionally, "Take Command" by JP Software (former 4DOS / 4NT) is an enhanced CMD-like command interpreter (Lite version is free to use).
While you're at it, I like ColorConsole:
http://www.softwareok.com/?seite=Freeware/ColorConsole
Brazil2 is offline   Reply With Quote
Old 14th April 2017, 08:04   #14202  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
I recommend to redirect the eac3to help to a file, and load the file in a good text editor to remove the BS characters. Due to the extremely bizarre formatting options of eac3to, it's the only method that gives good results.
r0lZ
Old 14th April 2017, 08:16   #14203  |  Link
LigH
LigH's Avatar
@ Brazil2: But this still lets CMD interpret the commands.
New German Gleitz board
Old 14th April 2017, 11:30   #14204  |  Link
Brazil2
I had the feeling that's what XadoX wanted: to go back to CMD.
Old 14th April 2017, 22:08   #14205  |  Link
CoRoNe
CoRoNe's Avatar
Originally Posted by XadoX View Post
Is there a way while using windows PowerShell to output the eac3to options as list, like usualy with cmd?
I have very little experience with PowerShell, but I believe it can on its own, yes.
Cmd on the other hand doesn't have a replace-tool, so you'd have to use 3rd party software.
My favorite:
eac3to.exe | xidel.exe -s - -e "replace($raw,'[\b]','','!')" | clip
or
eac3to.exe | xidel.exe -s - -e "replace($raw,'\x08','','!')" | clip
Or Cygwin's sed.exe:
eac3to.exe | sed.exe "s/\x08//g" | clip
My hobby website
CoRoNe is offline   Reply With Quote
Old 18th April 2017, 12:10   #14206  |  Link
iSeries
Hi, I was under the impression that when converting a 7.1 track to 5.1, eac3to would automatically run a second pass and reduce the volume if clipping was detected. So I just ran this conversion and eac3to didn't generate a second pass. As a test, I ran the same command with -normalize added, and eac3to applied a -0.09db gain, so in other words, there was clipping. So am I supposed to add -normalize to every 7.1 to 5.1 downmix?
iSeries is offline   Reply With Quote
Old 18th April 2017, 12:21   #14207  |  Link
LigH
LigH's Avatar
I can't tell you for sure, but I guess there may be circumstances where eac3to will only extract a 5.1 core and simply omit additional channels. Or it was just matrix encoded, no discrete 7.1 source anyway. You will have to specify more precisely which source format you have and which parameter set you used.
Old 18th April 2017, 12:28   #14208  |  Link
iSeries
Source was DTS-HD MA 7.1 (Zootopia). I just used the stream extractor gui for eac3to, selected the audio track and selected AC3 for output (which would default to a 5.1 640kbps output). The log in both cases say the additional channels were mixed into the surround channels.
Old 18th April 2017, 12:37   #14209  |  Link
LigH
LigH's Avatar
In this case, I guess a conservative fixed downmix gain was used. Ensures no clipping, but may not utilize the whole amplitude range. Correct me if I'm wrong...
Old 18th April 2017, 12:55   #14210  |  Link
iSeries
I just ran the same tests on a completely different movie (but still DTS-HD MA 7.1), and again no messages about clipping. The second test with -normalize added, eac3to again applied a -0.09 gain.
So I guess eac3to just applies a standard -0.09 gain when downmixing 7.1 to 5.1 when the -normalize switch is used, and no clipping is detected?
So now of course I'm wondering, is using the -normalize switch good practice, or should I just let eac3to mix the surrounds and only automatically normalize if there is detected clipping?
Old 18th April 2017, 13:05   #14211  |  Link
tebasuna51
tebasuna51's Avatar
Correct.
A -0.09db gain can be considered like clipping, because LigH is right when say:
Is not recommended.
Even, if the automatic normalize show a big attenuation value, you can consider use a special downmix (MeGUI or BeHappy) than preserve volume in FL,FR,FC and LFE, and only apply attenuation to mix SL+BL, SR+BR.
Old 18th April 2017, 13:20   #14212  |  Link
iSeries
Correct.
Is not recommended.
Perfect, thanks guys.
Old 18th April 2017, 15:05   #14213  |  Link
SquallMX
Special SeeD
Is there a way to avoid the re-encoding of the AC3 embedded track when processing a segmented movie?
[a03]eac3to v3.31
command line: "D:\Archivos de Programa\EAC32AC3\eac3to.exe"  "I:\TestTHD\BDMV\PLAYLIST\00620.mpls" 1) 3: "D:\\00620.mpls_3eng.thd+ac3" -progressnumbers -log="D:\Archivos de Programa\EAC32AC3\UsEac3To.log"
M2TS, 1 video track, 6 audio tracks, 4 subtitle tracks, 2:07:47, 24p /1.001
1: Chapters, 16 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: TrueHD/AC3 (Atmos), English, 7.1 channels, 48kHz
   (embedded: AC3 EX, 5.1 channels, 640kbps, 48kHz)
4: AC3, Spanish, 5.1 channels, 640kbps, 48kHz, -9ms
5: AC3, French, 5.1 channels, 640kbps, 48kHz, -9ms
6: AC3 Surround, English, 2.0 channels, 224kbps, 48kHz, -9ms
7: AC3 Surround, English, 2.0 channels, 224kbps, 48kHz, -9ms
8: AC3 Surround, English, 2.0 channels, 224kbps, 48kHz, -9ms
9: Subtitle (PGS), English
10: Subtitle (PGS), English
11: Subtitle (PGS), Spanish
12: Subtitle (PGS), French
[a03] AC3 encoding doesn't support back channels. Will mix them into the surround.
[a03] Extracting audio track number 3...
[a03] Extracting TrueHD stream...
[a03] Decoding with libav/ffmpeg...
[a03] Mixing surround channels...
[a03] Remapping channels...
[a03] Encoding AC3 <640kbps> with libAften...
[a03] Creating file "D:\\00620.mpls_3eng.thd+ac3"...
[a03] Audio overlaps for 5ms at playtime 0:15:21.  <WARNING>
[a03] Audio overlaps for 5ms at playtime 0:48:26.  <WARNING>
[a03] The audio gaps/overlaps can't be removed from the TrueHD bitstream.  <WARNING>
[a03] In order to remove them you'll have to transcode to another format.  <WARNING>
[a03] Original audio track, L: max 23 bits, average 19 bits.
[a03] Original audio track, R+BL+BR: max 24 bits, average 18 bits.
[a03] Original audio track, C: max 22 bits, average 19 bits.
[a03] Original audio track, LFE: constant bit depth of 18 bits.
[a03] Original audio track, SL: max 21 bits, average 18 bits.
[a03] Original audio track, SR: max 20 bits, average 18 bits.
[a03] Processed audio track, L: max 23 bits, average 19 bits.
[a03] Processed audio track, R+SL+SR: max 24 bits, average 19 bits.
[a03] Processed audio track, C: max 22 bits, average 19 bits.
[a03] Processed audio track, LFE: constant bit depth of 18 bits.
Video track 2 contains 183851 frames.
eac3to processing took 6 minutes, 58 seconds.
Done.
SquallMX is offline   Reply With Quote
Old 7th May 2017, 12:10   #14214  |  Link
rhaz
Hi, what's the command to disable the notification 'boink' sound? If you run some batch file with 10 encodes, it boinks 10 times for each which drives me crazy while wearing headphones.
rhaz is offline   Reply With Quote
Old 7th May 2017, 12:14   #14215  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
You can delete the WAV file.
it doesn't crash if there's no WAV file.
Win10 (x64) build 18362| GPU Caps Viewer 1.42.4.0
NTSC | DVD: R1 | BD: A
Intel Xeon X5660 @2.80GHz
Old 8th May 2017, 10:23   #14216  |  Link
rhaz
Uhhh okay...
Old 8th May 2017, 15:55   #14217  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Uhhh okay...
That is, I don't believe there is a "command" to disable the notification. It's just designed that way.
Hence: Delete the WAV file in the eac3to folder.
No WAV file, no sound.
It doesn't break anything if you delete it.
Try looking inside the folder with eac3to, or whatever GUI/AiO you are using and delete the WAV files.
They're not really needed.
Old 8th May 2017, 19:23   #14218  |  Link
Asmodian
I do that right away, after the first success sound reminds me I rename the wavs to nos. It is actually a nice and easy way to configure that feature.
madVR options explained
Old 12th May 2017, 21:12   #14219  |  Link
stax76
stax76's Avatar
Looks like eac3to writes chapters to m4a or is it created by NeroAacEnc?
Audio encoding using eac3to 3.31 x86
D:\Projekte\VS\VB\StaxRip\bin\Apps\eac3to\eac3to.exe "D:\Video\Samples\MKV\720p SBR_temp\720p SBR ID2 44ms.flac" "D:\Video\Samples\MKV\720p SBR_temp\720p SBR ID2_out1.m4a" -quality=0.35 -normalize +44ms -progressnumbers
FLAC, 2.0 channels, 0:00:41, 24 bits, 827kbps, 44.1kHz
Decoding FLAC...
Applying RAW/PCM delay...
Writing WAV...
Creating file "D:\Video\Samples\MKV\720p SBR_temp\720p SBR ID2_out1.m4a.pass1.wav"...
The original audio track has a constant bit depth of 24 bits.
Starting 2nd pass...
Reading WAV...
Reducing depth from 64 to 32 bits...
Encoding AAC <0.35> with NeroAacEnc...
Applying 0.05dB gain...
The processed audio track has a constant bit depth of 32 bits.
eac3to processing took 1 second.
Done.
Start: 21:53:24
End: 21:53:25
Duration: 00:00:01
General
Complete name : D:\Video\Samples\MKV\720p SBR_temp\720p SBR ID2_out1.m4a
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (M4A /mp42/isom)
File size : 318 KiB
Duration : 41 s 215 ms
Overall bit rate mode : Variable
Overall bit rate : 63.2 kb/s
Encoded date : UTC 2017-05-12 19:53:25
Tagged date : UTC 2017-05-12 19:53:25
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Bit rate mode : Variable
Bit rate : 61.4 kb/s
Maximum bit rate : 70.0 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 spf)
Compression mode : Lossy
Stream size : 309 KiB (97%)
Writing library : Nero AAC codec 1.5.4.0
Encoding settings : -q 0.35
Menu
Muxing using mkvmerge 11.0.0 pre x64
D:\Projekte\VS\VB\StaxRip\bin\Apps\MKVToolNix\mkvmerge.exe -o "D:\Video\Samples\MKV\720p SBR_new.mkv" "D:\Video\Samples\MKV\720p SBR_temp\720p SBR_new_out.h264" --audio-tracks 0 --language 0:ger --default-track 0:0 "D:\Video\Samples\MKV\720p SBR_temp\720p SBR ID2_out1.m4a" --global-tags "D:\Video\Samples\MKV\720p SBR_temp\720p SBR_new_tags.xml" --ui-language en
mkvmerge v11.0.0 ('Alive') 64bit
'D:\Video\Samples\MKV\720p SBR_temp\720p SBR_new_out.h264': Using the demultiplexer for the format 'AVC/h.264'.
'D:\Video\Samples\MKV\720p SBR_temp\720p SBR ID2_out1.m4a': Using the demultiplexer for the format 'QuickTime/MP4'.
'D:\Video\Samples\MKV\720p SBR_temp\720p SBR_new_out.h264' track 0: Using the output module for the format 'AVC/h.264 (unframed)'.
'D:\Video\Samples\MKV\720p SBR_temp\720p SBR ID2_out1.m4a' track 0: Using the output module for the format 'AAC'.
The file 'D:\Video\Samples\MKV\720p SBR_new.mkv' has been opened for writing.
The cue entries (the index) are being written...
Multiplexing took 0 seconds.
Start: 21:53:36
End: 21:53:37
Duration: 00:00:00
General
Complete name : D:\Video\Samples\MKV\720p SBR_new.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 11.4 MiB
Duration : 41 s 156 ms
Overall bit rate : 2 324 kb/s
Encoded date : UTC 2017-05-12 19:53:36
Writing application : mkvmerge v11.0.0 ('Alive') 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Video
Format : AVC
Format profile : Baseline@L2.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : V_MPEG4/ISO/AVC
Duration : 41 s 66 ms
Bit rate : 2 264 kb/s
Width : 480 pixels
Height : 272 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.578
Stream size : 11.1 MiB (97%)
Writing library : x264 core 148 r2762 90a61ec
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 41 s 146 ms
Bit rate : 61.5 kb/s
Delay relative to video : 10 ms
Stream size : 309 KiB (3%)
Language : German
Default : No
Forced : No
Menu
00 : 00:00.059 : en:00:00:00.059
stax76 is online now   Reply With Quote
Old 12th May 2017, 21:46   #14220  |  Link
sneaker_ger
Written by NeroAacEnc to signal AAC encoder delay.
eac3to
