Old 1st February 2016, 22:09   #13841  |  Link
BigPines
Originally Posted by Snowknight26 View Post
Just because eac3to tells you that a component is missing doesn't mean it's required. The ArcSoft DTS decoder, for example, is essentially unneeded.
Unless you run into low bitrate or extension for secondary audio DTS streams. Why not configure it just in case?
BigPines is offline   Reply With Quote
Old 1st February 2016, 23:21   #13842  |  Link
Snowknight26
Because the chances of that happening and you needing to convert it are so low that you'll spend more time getting eac3to to recognize every other program than necessary, but to each their own I guess.
Snowknight26 is offline   Reply With Quote
Old 2nd February 2016, 01:36   #13843  |  Link
BigPines
Yes, for me it was worth it to deal with it once and never have to think about it again...hopefully anyway.
Old 2nd February 2016, 16:23   #13844  |  Link
Music Fan
Originally Posted by BigPines View Post
6) Install Haali Media Splitter
What is its utility with eac3to ? I never installed Haali Media Splitter.
Music Fan is offline   Reply With Quote
Old 2nd February 2016, 16:45   #13845  |  Link
BigPines
Music Fan, it is for muxing into mkv container. Haali Media Splitter replaces the older Haali Matroska Muxer.
I am now running into a new problem I hadn't noticed before on my prior install. When converting a DTS-MA track to mono wavs, I get the following warning from libDcaDec: "XLL output not lossless". I found this post that seems to be related: http://sasshkas.blogspot.com/2015/11...s-are-not.html
Are we sure libDcaDec is just as accurate as ArcSoft?
Old 2nd February 2016, 18:10   #13846  |  Link
Thunderbolt8
maybe its related to this: https://github.com/foo86/dcadec/comm...1a96efff05309e
perhaps not so much the reason why you get the message, but more so that it shouldnt matter regarding the quality of the track.
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 2nd February 2016, 18:16   #13847  |  Link
nevcairiel
The message is normal, some streams just can't be decoded losslessly because they were mastered badly. The result is identical to other DTS decoders.
The post you found talks about something else entirely.
Yes.
Old 2nd February 2016, 19:24   #13848  |  Link
BigPines
Thanks. The message is a bit disconcerting. I wish I understood exactly what is happening but for now, I guess I'll just ignore it.
Now, every DTS-MA track I convert gives me this "XLL output not lossless" message. Does everyone else get this message every time too?
Old 5th February 2016, 12:24   #13849  |  Link
Nico8583
Is there a way to apply DRC with eac3to ? I've seen this option on BD Rebuilder but I know it doesn't use eac3to and I would like to test this feature without rebuild a Blu ray.
Thank you !
Nico8583 is offline   Reply With Quote
Old 5th February 2016, 18:07   #13850  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Nico8583 View Post
Is there a way to apply DRC with eac3to?
Nope.
Apply DRC is intended to be used at play time, not at recode time.
If you want use the DRC included in AC3 streams when recode you can use BeHappy or the old BeSweet.
If you want apply something like DRC over any audio stream you can use Sox compand.
Old 5th February 2016, 19:04   #13851  |  Link
Nico8583
Nope.
Thank you, I would like to apply DRC when converting DTS to AC3 (or AC3 to AC3 if necessary to apply DRC) so I think I should go to BeHappy thread ?
Old 5th February 2016, 20:50   #13852  |  Link
tebasuna51
tebasuna51's Avatar
DRC info in DTS is optional, and most the times don't exist.
Then you can obtain the same output decoding with or without apply DRC.
Like I say you the DRC must be applied at play time.
Recode to AC3 don't have sense for me.
I can recommend only when you want downmix to stereo.
Then you can use BeHappy:
1) Load your AC3 source
2) Select NicAc3Source and Configure to "Down2, DRC"
3) Apply Normalize (100%)
4) Encode to AAC
EDIT: for more info use BeHappy thread
Old 5th February 2016, 20:56   #13853  |  Link
Nico8583
Thank you, but I want to keep 5.1 so I don't want to downmix to stereo. So I forget DRC, I will keep AC3 without recode and I will recode DTS to AC3 with eac3to or ffmpeg
Thank you for the advise
Old 6th February 2016, 15:28   #13854  |  Link
.sk
Is it possible to losslessly merge mp3 files (same encoder and settings) with eac3to into one mp3 file?
.sk is offline   Reply With Quote
Old 6th February 2016, 16:02   #13855  |  Link
Thunderbolt8
dunno, but maybe it already works with "copy file1.mp3+file2.mp3+file3.mp3..."
Old 6th February 2016, 18:57   #13856  |  Link
tebasuna51
tebasuna51's Avatar
If you do:
copy /B file1.mp3 + file2.mp3 output.mp3
- some tags at end of file1.mp3 are at the midle of output.mp3
- If are VBR, the duration of output.mp3 show only the duration of file1.mp3.
And some players can stop play at this duration.
You can use eac3to:
eac3to file1.mp3+file2.mp3 output.mp3
- the tags at end of file1.mp3 are skiped
- The problem with VBR duration still exist.
You can use Foobar2000 and right click over the mp3 -> Utilities -> Fix VBR MP3 header
Old 7th February 2016, 10:15   #13857  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
MP3DirectCut can also losslessly join two MP3 files (if they have been encoded exactly in the same way of course). You will have to copy the whole content of file 2, and paste it at the end of file 1, then save the complete audio. No problem with the tags or duration. Only the replay gain info (if any) may be wrong. And BTW, with the Copy /B trick (and perhaps also with eac3to), another problem exists. The bad samples at the end of the first file and beginnong of the second file are not removed, and a short silence may be perceptible. With MP3DirectCut, you cannot copy that part of the file (if it has been created with a good encoder), and there is no problem.
There are several versions of the MP3DirectCut program. I use the old one, still available here. The new version is here. I don't remember why I have preferred the old version.
BTW, I've tried to remove one channel from a stereo MP3 without re-encoding, but I haven't found a tool to do it. It's useful when a mono track has been encoded in stereo, to regain disc space and be more coherent with the source. The two channels contain exactly the same data (or, with joint stereo, the second channel should be almost empty). Someone knows a tool able to do that?
r0lZ
Old 7th February 2016, 10:26   #13858  |  Link
LigH
LigH's Avatar
Efficient MP3 encoders use Joint Stereo for audio which has probably similar channels, and use adaptively the Mid/Side encoding (not encoding the left channel separately from the right channel, but instead their sum and their difference, because the difference is probably rather low in comparison to the sum and thus needs less bitrate). What has not been encoded separately, cannot be separated without recoding.
New German Gleitz board
Old 8th February 2016, 09:43   #13859  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
That makes sense. Thanks.
r0lZ
Old 8th February 2016, 18:54   #13860  |  Link
Stereodude
My understanding is that it's necessary if you want to have eac3to write directly to a MKV container.
Stereodude is offline   Reply With Quote
eac3to
