24th January 2020, 15:06 | #601 | Link |
What label do you have set for the HDMI port on your C9?
madVR options explained |
24th January 2020, 18:48 | #602 | Link | |
Normal mode is leaving the HDMI port label either at default or changing it to anything other than PC (correct me, if there is another label that triggers 4:4:4). In my opinion, if you don't use your PC for anything other than watching media, there is no real reason to use PC mode. In an ideal world, we'd all be using full chroma, but for now the cons outweigh the pros. That is until LG get their act together. There is no reason they can't make this work properly, especially now that HDMI 2.1 is here. Bandwidth and/or processing power should not be used as an excuse any longer.
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex |
24th January 2020, 19:56 | #603 | Link | |
I have noticed as well nobody is setting their GPU to 12bit. Any particular reason?
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR Last edited by Magik Mark; 24th January 2020 at 20:03. |
24th January 2020, 20:52 | #604 | Link |
With anything other than 4:2:2, you don't get to pick 10-bit anyway. It's always either 8-bit or 12-bit (with Nvidia). For 4:2:2 and our OLEDs, I found that there is no real difference visually between 10-bit and 12-bit. This probably has something to do with the fact that in this case the signal is always sent as 12-bit anyway. Not sure if that's an Nvidia bug or something else. I believe SamuriHL pointed this out first, and I confirmed it via my Denon. Nothing's perfect, I guess
24th January 2020, 22:47 | #606 | Link | |
If you can get banding free gradients in PC mode it is better quality than any of the non-PC modes, with madVR. My C9 is great with 8 bit YCbCr 444 in PC mode, and I get better quality with blurays played through madVR in PC mode with that than I do in HDMI mode with 10 bit YCbCr 422. This is only with SDR, my C9 is still very bad at HDR in PC mode. The C9, mine at least, has improved PC mode, albeit only with SDR 8 bit YCbCr input. But, yeah, LG OLEDs require balancing tradeoffs and HDMI mode is a lot more forgiving. PC mode with any other input format is worse than HDMI mode with any input format on my C9 but it is also a different issue, banding in some gradients v.s. every single frame slightly blurred in that subsampled chroma way. I really wish I could keep madVR's 8 bit RGB output untouched.
24th January 2020, 22:58 | #607 | Link |
That's why I said "in my opinion". I would never argue the benefit of full chroma. It's just too much of a hassle with the OLEDs. So, yeah, trade-offs on both sides. I prefer not to switch to a different mode when I watch HDR, which is quite often. And speaking of blurring - we already do that anyway by using smooth motion. There is no win-win.
24th January 2020, 23:07 | #608 | Link |
Good point. I cannot say "not true" to your opinion.
I totally understand not wanting to change HDMI labels all the time, but that is different from saying there is no point to full resolution chroma. Smooth motion blurring is very different from chroma subsampling bluring, but I agree, there is no win-win.
25th January 2020, 17:56 | #609 | Link |
We suffer the limitations of current display tech and hope that these issues get resolved before we upgrade. Well, not you, Asmodian as you seem to have an incurable upgrade disease. I've also settled on YCbCr 422 10 bit on the PC and it looks very good. And yes, to the comment above, nVidia wraps 10 bit in a 12 bit signal on the PC.
25th January 2020, 23:07 | #610 | Link |
Has anyone got a guide for setting up DisplayCal with MadVR 3DLut for SDR and HDR calibration outputting from Win10 PC 12bit 4:4:4 RGB? LG OLED55B6V BTW. When setting the B6 to PC input on HDMI2 (set to accept BT2020 input) the TV auto sets itself to wide gamut. Not sure if it should be on normal or not. Also when doing HDR calibration should Win10 be set to HDR mode on the display and/or HDR Output set in DisplayCal instead of tone mapped?
Damned confusing this. |
26th January 2020, 17:56 | #611 | Link |
Hello guys.
I have a TV LG B9 65", a PC with RX 5700 XT and a Denon X3500H. The PC is connected to the DENON and the DENON is connected to the TV. I have some doubts about the settings: 1. on the LG B9 TV set: - black level on HIGH. - Does dynamic tone mapping turn on or off? - do I have to set the HDMI port to which the PC is connected and the bluray player via the AVR Denon X3500H in PC Mode or in (for example) Home Theater Mode? 2. Imposed the video card: 10-bit color depth and RGB 4: 4: 4: PC standard pixel format (full RGB). |
27th January 2020, 13:13 | #612 | Link | ||||
I do Quote:
- dynamic tone mapping: it's up to you whether enable or disable it - PC Mode or in Home Theater Mode: if you can't live without chroma 4:4:4 (like me ) then go for PC mode, if you can then the other 2. read back the whole thread from the above link and you will see that no win-win situation, you have to decide what you can live with
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
27th January 2020, 17:08 | #613 | Link |
thanks for the replies.
If I enable PC mode in the HDMI 2 port of the TV, the external bluray player will also be connected to this port via the Denon X3500H. Can the PC mode of the TV negatively affect the connection with the external bluray player? |
27th January 2020, 17:44 | #614 | Link |
Yes. But you can manually switch it back of you need to.
27th January 2020, 19:48 | #615 | Link |
In my case with my LG C9 with input set to HDMI mode, RGB FULL/ TV set to black level high has more banding than RGB limited/ TV set to low, and i believe ycbcr 4:4:4 limited with TV set to black level low also has a little less banding than RGB limited/low.
Also Game mode has somewhat worse banding in the near blacks, when looking at a gradient test the black in the gradient test looks different than in ISF dark/bright mode so i believe the gamma is different even if both are set to BT1886. |
28th January 2020, 15:04 | #616 | Link |
I contacted LG about the PC mode or other modes selectable in the Dashboard by changing the HDMI port icon.
LG wrote to me that changing the icon does not change the characteristics of the selected input and therefore does not change the color space either. The icon you choose doesn't matter. I own an LG B9, could it be that for this model the icon has no meaning? |
28th January 2020, 18:17 | #617 | Link |
Just read back or search on the web for it.
28th January 2020, 19:05 | #619 | Link |
Whoever talked to you at LG knows less about the product than their users. Not surprising really, tier one support can be pretty inexperienced.
It is also largely true, only PC mode differs as far as I know.
