25th November 2012, 22:15 | #15801 | Link |
When using DXVA with H.264 files, seeking causes madVR to jumble up the frame order. If the video is, say, 100 frames long, seeking to frame 50 from frame 20 seems to cause the frames to be played back in this order until it hits the seek point: 20,50,21,50,22,50,23,50...
http://stfcc.org/misc/madVR - log v0.85.1.zip |
26th November 2012, 01:36 | #15802 | Link |
Continuous Beta Tester
Congrats for the latest version of MadVR and the DXVA2 support.
I think the biggest problem for ATi users after enabling DXVA-CB was the VC1 1080i50/60 playback. Now i can watch all the BBC Planet earth & Life BDs using MadVR. Till now, i have the best results (PQ, lower Cpu load & properly deinterlaced) using Arcsoft Video Decoder for VC1. If you want i have uploaded only the necessary files in this folder here. The idea and the checkactivate.dll is from this thread. At last one more question. Many people talk here about didee`s finesharp script. Is it the same shader like the MPC-HC built-in finesharp or you need to add it using avisynth`s LSFmod? thx in advance! |
26th November 2012, 01:40 | #15803 | Link |
When I activate fullscreen together with changing the refresh rate, the start menu icon (from "Classic Start Menu") stays on top of the movie until I exit and enter fullscreen again (without changing the refresh rate).
Of course it only happens with windowed fullscreen, not exclusive mode. Screenshot: http://ajpanton.se/menu.png Logfile, in case it's even there: http://ajpanton.se/log.zip |
26th November 2012, 09:23 | #15804 | Link | |
Problem 2: It seems to only be related to DXVA2 decoding, not the scaling. I created a log. (Opened video, seeked once, waited a few seconds, seeked again, waited a few seconds, seeked again, waited a few seconds, then closed the player) Out-of-order/jerkyness on all three seeks. It looks a bit like this happens until the decoder has caught up after the seek. Not really sure. log (mirror) sample (mirror) MPC-HC Win 7 x64 HD 5850 (Cat 12.11 Beta 8) This doesn't seem to happen here, even though LAV says it's using dxva2 native. /edit: Or is "[DXVA2]" only supposed to be added to the debug OSD? Last edited by sneaker_ger; 27th November 2012 at 13:39. |
26th November 2012, 10:58 | #15806 | Link |
Ever since NVIDIA fixed the issue with the playback glitches in madVR, i would go NVIDIA for video without any reservations. AMD just has a bad history of not properly supporting the things they claim to support, the latest being 4K decoding, which the 7xxx series claimed to do, but it never worked properly and was simply turned off in the latest drivers. NVIDIA drivers have been rather solid since the glitch fix, at least for me.
26th November 2012, 12:43 | #15809 | Link |
I am the one who knocks
What I found interesting about DXVA2 scaling is that my GTS450 uses two different scalers for different resolutions.
DXVA2 upscaling for a 720p file looks like bilinear. For SD it looks more like lanczos. Also, I've tried a 1280x546 file and it's treated like sd (sharp scaler and wrong colors) but 1280x580 is treated like HD (soft scaler and correct colors). |
26th November 2012, 13:20 | #15810 | Link | |
I think the 650 would be cutting it pretty fine, I think your best bet is the 660. |
26th November 2012, 14:19 | #15811 | Link |
@Madshi (or anyone):
Whenever I play a dvd in MadVR OSD it is wrongly reported "movie 25 fps" even if it's actually 23.976 or 24 fps as correctly reported in real time by both FFdshow raw video filter and reclock. Why? Can be fixed? Notice that by showing the wrong frame per second rate you lose also the information (which I like a lot) about the frame repeat every...The worst thing is that if I let MadVR take care of the display frame reate switching according to the movie fps it goes to 50HZ, which is wrong, MPCHC autochange fullsceen monitor otherwise behaves correctly. Thanks |
26th November 2012, 16:36 | #15813 | Link |
Stupid questions, but im trying to figure this whole DXVA vs. software thingie out.
About DXVA Deinterlacing. If I enable the deinterlacing in mVR, will I automatically get the DXVA deinterlacing? And if I get the DXVA deinterlacing does that mean Im getting the Vector Adaptive deinterlacing? I am using ATI 5770. I think i read somewhere mVR will just pick the best deinterlacing algorithm available from the graphics card? |
26th November 2012, 23:09 | #15814 | Link |
As I understand it, yes, MadVR uses hardware deinterlacing (as EVR does). I believe for nVidia the best quality deinterlacing is used by default (vector adaptive for most cards I think), for AMD you have to set what you want in the CCC.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
27th November 2012, 01:24 | #15815 | Link | |
Kid for Today
They've also been kind enough to make a few adjustments in the profiles automatic rules in order to make it easier to specify a different PS script based on resolution and frame rate, too good I find it rather sarcastic how what I've been dreaming of for years is finally possible now that I'm just about to buy a pj with a CMS This said, the ISF CMS stuff uses something called "CCA tables" and that doesn't seem nearly as easy as inputting the RGBW xy coordinates in an excel sheet...so backup plans are always good, should I need a few days/weeks to figure out that CCA stuff But it can allow 5% tolerances on saturations with a ΔE no higher than 2 so it will be well worth the effort anyway....as nothing can do that on a PC at this point AFAIK, tritical gave me a definitive NO and yesgrey told me years ago that he'd think about it. Last edited by leeperry; 27th November 2012 at 03:49. |
27th November 2012, 02:54 | #15816 | Link |
Error trying to use DXVA2 native
Hi madshi, when I tried to use lav video decoder (0.54) to DXVA2 native output NV12 to madVR (0.85.1), I got "creating Direct3D device failed (8876086c)" with all video. Can you you tell me how to set the decoder to feed the renderer correctly?
Thank you. |
27th November 2012, 03:32 | #15818 | Link |
Doesn't happen with EVR custom, only with madVR. I have Geforce 9800gtx+ with 306.23 driver. With Lav video decoder output 8-bit to NV12, EVR Custom displays it with no problem but always gets above error with madVR.
27th November 2012, 06:40 | #15820 | Link | |
I see... That's why I am also curious that all of my 3 machines never get Lav 0.54 dxva2n activated with madVR 0.85.1 dxva scaling. ION with Geforce driver 306.23 GTX260+ with Geforce driver 306.23 HD5450M with Catalyst 11.12 Last edited by pie1394; 27th November 2012 at 15:18. Reason: Describe the root cause of issue |
