Old 25th October 2016, 18:44   #39841  |  Link
Warner306
Originally Posted by 70MM View Post
But do I set the Lumagen to 3840 x 2160 also?
Yes, I think so. But you want madVR to do the image scaling.
Maybe you need to disable the Lumagen if it is doing any type of image scaling. That is what madVR is for.
Old 26th October 2016, 10:09   #39842  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
I probably wouldn't use the very latest nvidia drivers. Try one or two versions back using a clean install. Reset madVR to defaults if you must.
Originally Posted by Betroz View Post
The 368.81 drivers from nVidia are good.
Thank you both!
I've been playing with different drivers and I gotta say, some things are not working okay in windows after the latest updates.
I can't use copy-back module, need to use native, otherwise there is a huge spike in render time (not processing time, but render, jumps at 8ms, haven't noticed this before)
I guess that I'll do as I always did with nvidia and windows, use it like this and wait for things to get better.
Georgel is offline   Reply With Quote
Old 26th October 2016, 11:04   #39843  |  Link
Ver Greeneyes
Do you have Power Management set to Adaptive or Prefer Maximum Performance? See the previous page.
Old 26th October 2016, 11:23   #39844  |  Link
Mistery 73
setting madvr
hello everyone I am a new member of the forum,
excuse my English.
I'm using madVR and seguento many guides my settings are useless, so I ask you experts to help me on how to set madVR in the best way,
my HTPC consists i5 6600k, 16 gb ram and 1070 GTX.
Use watching bluray 1: 1 then 1080p24> 1080p24.
last advice is better to eliminate the RADIANCE between HTPC and projector?
Thank you
Mistery 73 is offline   Reply With Quote
Old 26th October 2016, 12:07   #39845  |  Link
ashlar42
No, just super-xbr AR for chroma. Bang for buck it can't be beat. Bicubic, Jinc and NNEDI3 are good alternatives though depending on your preferences.
Sorry, missed you were talking about chroma upscaling. My bad.
Old 26th October 2016, 18:30   #39846  |  Link
Warner306
excuse my English.
Thank you
If the RADIANCE is an image scaler, it shouldn't be needed. madVR is also an image upscaler.
Old 26th October 2016, 20:49   #39847  |  Link
Asmodian
I am not sure what there is for a Lumagen Radiance to do when your source is an HTPC running madVR, unless you are using it as source selector switch. madVR should be sending the correct resolution and handling any calibrations (madVR uses a 256x256x256 LUT). I suppose it may offer better deinterlacing than current video cards do.
madVR options explained
Old 26th October 2016, 20:55   #39848  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
Performance all the time ^_^
I got angry and reinstalled windows, and did discover a broken thing ;_;
I get a few frame drops every time I change seek position or when I go from windowed to full screen and vice versa. Is this normal?
Old 26th October 2016, 21:16   #39849  |  Link
aufkrawall
Yes, it is.
Old 26th October 2016, 21:17   #39850  |  Link
ryrynz
ryrynz's Avatar
Perfectly normal.
Old 26th October 2016, 22:20   #39851  |  Link
age
Is it possible to use bicubic chroma upscaling with custom parameters?I have not a high end hardware and I would set b=0.31,c=0.69 that makes a good job in my opinion and it's fast.
age is offline   Reply With Quote
Old 26th October 2016, 22:52   #39852  |  Link
ryrynz
ryrynz's Avatar
Not with madVR.
Old 27th October 2016, 00:17   #39853  |  Link
you can't send an interlanced image anyway.
madVR is outputting RGB so you need to scale the chroma scaling chroma before deintelrancing is destroy the chroma channel.
Old 27th October 2016, 04:25   #39854  |  Link
Asmodian
Ah right, of course. I even knew that.
There really is nothing for a Lumagen to do after madVR.
Old 27th October 2016, 05:32   #39855  |  Link
TheDarkTemplar
So about a month ago, MPC-HC started crashing when I tried to play a video. It was shortly after I updated my Radeon GPU drivers, so I fixed it by downgrading to the previous version.
A similar issue is now happening, but I'm pretty sure nothing has changed this time. Whenever I attempt to enter fullscreen, the whole computer locks up for a while and moves slowly for a while after that, several unrelated applications will all simultaneously crash, and this then culminates in a BSOD. I'm not sure what could be causing this (MPC, MadVR, Radeon) but in any case it's pretty much the worst possible bug that anything could result in.
I tried updating my Radeon drivers to the latest version now (16.10.2) and the problem did not change. Other video players are all playing videos in fullscreen fine.
I am using MPC-HC x64 1.7.10 and madVR v0.90.24. Can someone help me get to the bottom of this?
TheDarkTemplar is offline   Reply With Quote
Old 27th October 2016, 06:07   #39856  |  Link
TheDarkTemplar
I guess the issue was that the GPU drivers had automatically updated to a more recent version (though not the latest one) without notifying me, as I just downgraded back to 16.7.3 and everything is working perfectly again.
It is a shame that newer drivers are totally messing things up though. I hope it can be resolved somehow soon. Is there any way I can help by providing crash logs or something?
Old 27th October 2016, 08:05   #39857  |  Link
you can work around it: http://bugs.madshi.net/view.php?id=431
Old 27th October 2016, 12:54   #39858  |  Link
Mistery 73
madVR prejudice exists an algorithm similar to Darbee, I want to remove the radiance between HTPC and projector though the effect of Darbee I like as much as I do?
Old 27th October 2016, 15:29   #39859  |  Link
billqs
Hey! I bought a GTX1070 Founders Edition to up my ability to use Madvr settings. I don't currently game, though at some point I plan to use VR. Mostly, though the HTPC powers my Media Room and hooks to a JVC RS500 projector with a 133" screen. My system:
Windows 7 x64
ASUS Z170 motherboard
i5 6600 CPU
16 GB memory
GTX 1070 video card (replacing a GTX 960)
Using MPC HC right now for Lav filters and Madvr
By overclocking the 1070 to right around 2000 clock, upping fan speed to full and increasing memory speed by 600 I was finally able to use NNEDI 3 for Image Doubling for 1080P and Image Quadrupling for 720p (All signals go to projector at 3820 x 2160. I had to compromise on several other settings to get this to work without many dropping frames, and I'm still not certain it will remain stable especially with the POS Founders Edition stock cooler. I downgraded Chroma Upscaling to BiCubic and Image Downscaling to Lancoz get under 40ms. I've turned the card for maximum performance (turned off power settings). At standard stock speed I can do one factor NNEDI 3 everything else is compromise.
My question is if I need to change cards to better enable the Madvr results?
I have 3 choices I believe:
1. Get an aftermarket 1070 with a better cooler so that the overclock will be more stable (though I'm running a pretty stout overclock right now)
2. Get a GTX1080 and hopefully it will allow me to run with optimized settings at stock speed.
3. Keep the card I have now and continue to come up with a compromise that works well for it (though the cooler is weak so I have high temps.
I noticed the discussion about TFLOPS having a correlation to performance for Madvr. The 1070 has 4.5 TFLOPS while the 1080 has 9TFLOPS.
Thanks for your help.
billqs is offline   Reply With Quote
Old 27th October 2016, 16:23   #39860  |  Link
Betroz
Is this for real?
Betroz's Avatar
The GTX 1070 is a 6.46 TFLOPS card. An aftermarket 1080 or wait for the 1080Ti if you can afford it.
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
