15th April 2014, 21:25 | #25981 | Link |
AMD Interop Tests
Finally found some time to do a few quick tests. AMD Radeon R7 200 Series; passively cooled (SAPPHIRE Ultimate 100368USR Radeon R7 250 1GB 128-Bit GDDR5 PCI Express 3.0); Catalyst 14.2; Core i5-3470; 8 GB RAM
Display is an old Sharp Aquos LC-32GA5U running at native 1366x768 via DVI tl;dr v0.87.9 couldn't run without dropping frames; Test1 ran with Luma doubling forced at 16 neurons (32 was too much) and Jinc 3 AR; Test2 could only handle Lanczos 3 AR, so I vote for Test1. Hope this helps, and thanks for the test builds. Definitely a step in the right direction! I started with v0.87.9 trying to force NNEDI3 to double Luma resolution using 16 neurons. Plenty of dropped frames. Settings
With v0.87.9 I got the following: Queues
with Test1
NO dropped frames Source video (a VHS capture using an old Hauppauge card) Format : MPEG-PS File size : 8.90 GiB Duration : 1h 40mn Overall bit rate : 12.7 Mbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=15 Duration : 1h 40mn Bit rate : 12.0 Mbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 1.159 Time code of first frame : 00:00:00:00 Time code source : Group of pictures header Stream size : 8.46 GiB (95%) Audio ID : 192 (0xC0) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Duration : 1h 40mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : -111ms Stream size : 275 MiB (3%) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Been playing an NTSC DVD (Peter Gabriel Live in Athens 1987). Same resolution, interlaced, but dropped frames using Jinc 3 AR. OK switching to Lanczos 3 AR. Didn't check any other differences between the two sources. 2nd edit: I think the difference is that the DVD is really 16:9, while the VHS capture is 4:3. That's my guess, anyway. Last edited by ThurstonX; 16th April 2014 at 01:32. Reason: Additional Info |
15th April 2014, 21:56 | #25982 | Link |
ED is a large performance hit and ordered dither is quite good, if you have banding debanding + OD is better than no debanding + ED. debanding + no dither is not a reasonable option.
15th April 2014, 22:00 | #25983 | Link |
Kid for Today
I believe this was already mentioned but 48/96/192 neurons NNEDI would be pretty cool for when you can't quite run for 64/128x and still got potential cycles unused. I still kinda find NNEDI too sharp for chroma but sometimes I still don't have enough horse power to go for the next level and I can't run 256 neurons luma for SD@1080p, I would welcome the opportunity to try 192 if technically doable
It's even more true now that AMD boards have magically earned extra headroom. |
15th April 2014, 22:13 | #25984 | Link |
I'd love to test the new build but I keep getting "dxva processing failed" message from madVR. I don't have any of those options selected (for dxva) in the UI and I'm using Radeon 5850 on Windows 7 Pro. I would add that this is with ED 2 selected.
15th April 2014, 22:20 | #25985 | Link |
MPC-HC Developer
@Fullmetal Encoder: Make sure to disable all "enhancements" in gpu driver. Especially "dynamic contrast" there seem to be bug in drivers which breaks DXVA processing, for example deinterlacing will fail to initialize when opening, yet you can re-enable it later.
15th April 2014, 22:45 | #25986 | Link |
QB the Slayer
Time for my report on the test builds.
System: R9 270X factory OC to 1120/1400 (GPU/memory) PCI-e 2.0 (GA-990FXA-UD7) Windows 8.1 Target resolution: 1024x768 (rectangular pixels) Source: 1280x720p24 Settings: Chroma Upscaling - NNEDI3 x32 Image Upscaling - Jinc 3 AR Luma Doubling - NNEDI3 x64 Chroma Doubling - NNEDI3 x32 Image Downscaling - Catmull-Rom AR LL Debanding - med/med With previous release I could only do Ordered Dithering (Error Diffusion just pushed over the limit of GPU) Testbuild1 - Still dropped frames with ED Testbuild2 - NO dropped frames with ED So my vote goes to Testbuild2... It allows for me to go even further than any build to date QB
16th April 2014, 00:06 | #25987 | Link |
Scaling from 720x480 to 1920x1200 with ED2 and NNEDI doubling at 32 neurons on luma using a Radeon 5850 I am getting:
- 52 frame drops/refresh with 87.9 - 40 frame drops/refresh with test 1 - 31 frame drops/refresh with test 2 I don't know why others with the 5850 are getting so much better performance though. Last edited by Fullmetal Encoder; 16th April 2014 at 00:14. |
16th April 2014, 00:50 | #25989 | Link |
Win7 x64, HD 7750 PCI-E 2.0x16
720x404@25fps with 64 neurons tested Test build 1 uses slightly less (55% vs 57%) GPU and less graphics memory (~40 MB or 10%) than test build 2. 0.87.9 used ~60% GPU and similar amount of memory as test build 1. Neither improved performance enough to allow more neurons but a 10% overall improvement is certainly welcome! |
16th April 2014, 01:23 | #25990 | Link |
This test came a bit as a shock because I do remember being unable to use NNEDI3 even with 16 neurons when first release and didn't bothered to try again.
AMD 5730M 650Mhz core /800Mhz GDDR3 mem H264 clip 720x304 -> 1366x768 87.9 - 16 Neurons ~86.7% / 32 Neurons - slideshow Test 1 - 16 Neurons ~57.6% / 32 Neurons ~86.5% Test 2 - 16 Neurons ~60% / 32 Neurons ~89.7% Queues the same in test 1 and 2. So again beyond words on the improvement and as much, amazed being able to do 32 neurons. |
16th April 2014, 06:40 | #25992 | Link |
Considering the previous responses, and the less meaningful low render times, I changed the survey defaults to double luma, and added a default video of tears of steel. Remember that any data is good data, and this survey/spreadsheet will not only help madshi, but those interested in what the optimal media GPU for them might be.
To Madshi in particular, I think it will be interesting to see across the various hardware configurations, how the improvements appear between versions. I will probably try the AMD builds at some point. |
16th April 2014, 07:00 | #25993 | Link | |||
Yes, but only with SLI on. SLI is much better with the test builds though still not as fast as without SLI.
madVR 87.9: Quote:
SLI on GPU0 73% @ 1097 MHz, 11% PCI-E, 7% memory controller GPU1 09% @ 836 MHz, 7% PCI-E, 0% memory controller SLI off GPU0 67% @ 1097 MHz, 5% PCI-E, 7% memory controller GPU1 00% @ 324 MHz, 0% PCI-E, 0% memory controller I can also run my "720p24" profile with SLI on which used to drop a lot frames. Jinc3 chroma, Jinc3 Image, NNEDI3 128 luma doubling, ED2, no debanding, no smooth motion. I did recheck 87.9 immediately after these tests and it does perform as it did before so this isn't an accidental setting or system change. Nvidia Driver 337.50 Quote:
16th April 2014, 08:45 | #25996 | Link | ||
Ohhhhhh.... I see.
There should be a comma there. Like so: Quote:
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. |
16th April 2014, 11:54 | #25998 | Link |
Alright, after testing the new test builds, I can confirm that, on my HD6770 I go from
Old: Many drops, render times ~46ms on 720p->1080p source, using luma 32 doubling New interop 1: ~0.2 drops per second New interop 2: ~ 1 drop per second. The problem now, is that I'm no longer seeing render times in the debug window (with the new builds). I can conclude however, that I am at least getting the fastest render times from test build 1, and the improvements are at least enough to prevent noticeable framedrops on a particular source now. Last edited by Procrastinating; 16th April 2014 at 13:45. |
16th April 2014, 11:57 | #25999 | Link | ||
16th April 2014, 12:06 | #26000 | Link |
My bad, but the conclusion stands at least.
That said, I wonder where the difference in results for the two builds lie, with some people reporting better results in either. It doesn't appear to be related to overall architecture, so possibly clocks? Last edited by Procrastinating; 16th April 2014 at 12:12. |
