Old 14th May 2018, 14:26   #15821  |  Link
MerolaC
I would check CPU and memory stability.
I tried encoding directly with x264.exe and it worked using the same profile I used with Ripbot.
No problems with the PC.
Any suggestion?
MerolaC is offline   Reply With Quote
Old 14th May 2018, 14:29   #15822  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
nope.
Old 14th May 2018, 16:39   #15823  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by JudgeDredd View Post
no idea why would I need that, I dont have any problems with cooling of my cpu nor pc lagging while encoding. at times when I encode stuff cpu is always at 100% peek.
my issue is about drastic fps drop due to low priority level of encoding processes.
I haven't used it in a while, I thought you could raise priority as well as lower it.
Could try: Prio (Process Priority Saver)
https://www.raymond.cc/blog/permanen...ger-with-prio/
Seems to be what you're looking for.
Old 15th May 2018, 03:15   #15824  |  Link
MerolaC
Ok, I found the problem I think.
I've been trying to convert decrypted blurays to MKV.
So, I choose the m2ts file from the Stream folder and let it demux.
When converting it fails.
Now, if I rip the bluray to MKV and select that MKV in Ripbot v1.23, the conversion is successful.
This didn't happen with v1.22.0. I could just select the m2ts.
So, I went back to that version just to check and indeed, it works fine.
Edit:
No, It wasn't that!
It's the VSFilter crashing!
Previous tests were done with subtitles, the later I didn't use.
When previewing the script with MPC, it crashes with a faulty module, it being VSFilter.
Old 15th May 2018, 13:02   #15825  |  Link
Atak_Snajpera
No, It wasn't that!
To be honest that was my first suspect but then you said that it stops encoding with and without subtitles... so I ran out of ideas.
Old 15th May 2018, 15:37   #15826  |  Link
MerolaC
Yeah, because I'm stupid. I left the subs enabled all the time.
I was tired
Edit:
I have replaced the plugin with xy-VSFilter and it's working great.
Edit 2:
Neh, still crashes.
Old 17th May 2018, 14:13   #15827  |  Link
JudgeDredd
JudgeDredd is offline   Reply With Quote
Old 17th May 2018, 14:41   #15828  |  Link
Atak_Snajpera
Send me content of JOB1 folder (do not include heavy files like video.mkv,audio or subtitles)
Old 17th May 2018, 15:01   #15829  |  Link
JudgeDredd
https://ufile.io/a6gic
Old 17th May 2018, 16:13   #15830  |  Link
Atak_Snajpera
Temporary solution: Move ripbot to other folder than C:\temp
Old 18th May 2018, 02:43   #15831  |  Link
JudgeDredd
how to proceed?
yeah, thx for not getting actual support. whole DE sucks anyway - to much bugs that are not getting any fix since v17
Old 20th May 2018, 01:10   #15832  |  Link
burt123
burt123's Avatar
Here's a couple of suggestions :-
Firstly, DE doesn't suck, and Atak does have very good support for his program !!!
OK, so are you sure you have everything that Ripbot needs, installed ? especially avisynth (in the Tools folder).
Does Ripbot work ok without DE ??
Have you got the Temp folder on a separate drive to the "C" drive, and even separate to where your movie files are kept ??
And do these drives have enough free space...running low on space can cause a lot of weird problems !!!
Have you got your IP address's setup properly for DE to work with, have you shared any other pc's to work with DE ??
burt123 is offline   Reply With Quote
Old 20th May 2018, 10:50   #15833  |  Link
DG74
Demuxing Error E-AC3
I'm getting a "Demuxing Error" from eac3to with a E-AC3 audio stream by selecting the "Wave" option.
Shouldn't it be possible to select the "Core" option as well, to extract the AC3 stream from the E-AC3 only?
Using the latest Update of RipBot.
DG74 is offline   Reply With Quote
Old 20th May 2018, 11:01   #15834  |  Link
MAX9
MAX9's Avatar
I have problem to open DebugMode FrameServer file from Vegas?
DirectShowSource: couldn't open file D:\****.avi:
An invalid media type was specified.
(D:\Temp\RipBot264temp\job1\getinfo.avs, line 2)
DirectShowSource("D:\******.avi",audio=false).ConvertToYV12(matrix="rec709")
WriteFile("D:\Temp\RipBot264temp\job1\info.txt","Framecount")
WriteFile("D:\Temp\RipBot264temp\job1\info.txt","Framerate")
WriteFile("D:\Temp\RipBot264temp\job1\info.txt","AudioRate")
WriteFile("D:\Temp\RipBot264temp\job1\info.txt","AudioChannels")
WriteFile("D:\Temp\RipBot264temp\job1\info.txt","AudioLength")
WriteFile("D:\Temp\RipBot264temp\job1\info.txt","Width")
WriteFile("D:\Temp\RipBot264temp\job1\info.txt","Height")
WriteFile("D:\Temp\RipBot264temp\job1\info.txt","PixelType")
Trim(0,-1)
MAX9 is offline   Reply With Quote
Old 20th May 2018, 11:26   #15835  |  Link
Atak_Snajpera
According to this https://forum.videohelp.com/threads/...de-FrameServer
you need windows 7.
Old 21st May 2018, 19:49   #15836  |  Link
MAX9
MAX9's Avatar
I'm using Windows 7 64bit It's not this I think and I do some test with RipBot264v1.19.0 and v1.20.0 (with this version some flickering occur) there is no problem. From v1.21.0 and up errors happens (could't open the file).
Old 25th May 2018, 16:52   #15837  |  Link
byteshare
ByteShare
byteshare's Avatar
Thank you for updating the HEVC to 2.8+1:
https://x265.readthedocs.io/en/defau...easenotes.html
I'm having two separate issues:
1.
The first issue is with the Ninja Hattori files (6 of them). I'm failing to load them into RipBot via batch with a ffmsindex.exe error:
Problem signature:
Problem Event Name: APPCRASH
Application Name: ffmsindex.exe
Application Version: 0.0.0.0
Application Timestamp: 53a44d55
Fault Module Name: ffms2.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 53a45415
Exception Code: c0000005
Exception Offset: 000000000095bd6c
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 25a7
Additional Information 2: 25a7f46192bfb3e4ba089bed8fa522d6
Additional Information 3: f064
Additional Information 4: f064755d0d8accef36fd1e1bc483cc70
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
From the JobsRejected File:
----------[2018-05-24 20:44:38]----------
File: C:\!0ReEncode\Ninja.Hattori-kun.(1981).-.OP3.mkv
System exception - Access Violation
(C:\Temp\RipBot264temp\job801\getinfo.avs, line 2)
----------[2018-05-24 20:44:36]----------
File: C:\!0ReEncode\Ninja.Hattori-kun.(1981).-.OP2.mkv
----------[2018-05-24 20:43:56]----------
File: C:\!0ReEncode\Ninja.Hattori-kun.(1981).-.OP1.mkv
----------[2018-05-24 20:43:54]----------
File: C:\!0ReEncode\Ninja.Hattori-kun.(1981).-.ED3.mkv
----------[2018-05-24 20:43:53]----------
File: C:\!0ReEncode\Ninja.Hattori-kun.(1981).-.ED2.mkv
----------[2018-05-24 20:43:52]----------
File: C:\!0ReEncode\Ninja.Hattori-kun.(1981).-.ED1.mkv
2.
The second issue is with the 3 Golden Girls Interactive Game Files.
I think the issue is that the video is just one frame stretched to play over the duration of the audio but not sure.
The video files do load into RipBot but the encoding servers continually crash and never start to encode and I'm not getting any helpful logs.
Link for files to both of the issues: https://mega.nz/#F!90whXRTS!ln91-dyGJRNtMu9MHfytCQ
Old 25th May 2018, 18:33   #15838  |  Link
Atak_Snajpera
1) Fixed
2) Unfixable. No idea why you try to re-encode video clip with just 1 frame?
Old 25th May 2018, 22:32   #15839  |  Link
byteshare
ByteShare
byteshare's Avatar
1) Fixed
1. Awesome [Update: confirmed working for me after update]
2. Format support/uniformity. Mostly so everything is in the same format as other files. I'll just have to figure something out, thank you.
Old 26th May 2018, 12:35   #15840  |  Link
MerolaC
I can suggest you this.
Remux the original file but don't add the original audio.
Convert it and then remux back the audio.
It should work.
Otherwise, you can re-do the video in Vegas or any other NLE and extend it to the audio duration.
Vegas is the easiest because you can just drag any video/image in the timeline and it will repeat.
