31st July 2019, 02:38 | #3481 | Link |
Why is that even a concern?
Encoders typically encode the video in a percentage of that 4000 fps speed. If you are talking about difference between avs/vs to the actual encoding, it is becoming a basis point.
For a 1 hour encode you save not more than 10 seconds. It might be the way avs/vs fetching and caching the data. It might be the advantage that avs is C++ compiled while vs is dependent on Python, which in turn depends on the explainator. It might be ... wait I'm wasting too much time than that 10 seconds. VapourSynth is powerful for many reasons, but raw speed on absolutely simplest script doesn't fall into the list. Last edited by littlepox; 31st July 2019 at 02:45. |
31st July 2019, 21:33 | #3482 | Link |
Professional Code Monkey
R47 RC1
Test it so it's stable. Especially the makediff/mergediff/merge/maskedmerge filters since they were converted to intrinsics from asm. 64bits 32bits Changes: Code:
fixed a crash in vdecimate when both dryrun and clip2 is set (no1d) updated zimg to 2.9.2 to fix a crash that would happen on certain invalid input combinations improved message handler api and core info api removed dependency on nasm various installer improvements including a warning if the vs2019 runtimes aren't installed
4th August 2019, 22:20 | #3483 | Link |
R47 has been released. The usual blog post here.
7th August 2019, 15:48 | #3484 | Link | |
Pig on the wing
7th August 2019, 20:52 | #3485 | Link |
Use vsrepo to install things. Then it's always in the right place.
8th August 2019, 04:38 | #3486 | Link | |
With new Python version installed , you move those files as well. So organize it well, always gather them in one directory, like site-packages/vapoursynth/. I do not know where vsrepo puts those .py files, maybe somewhere else, into AppData. Last edited by _Al_; 8th August 2019 at 04:40. |
8th August 2019, 07:34 | #3487 | Link | |
Pig on the wing
Using VSRepo is fine, but my own custom .py files need to be taken care of as well and the problem lies there.
8th August 2019, 23:25 | #3488 | Link |
For example put just that line into your script:
import os That would mean you can import standard library modules but not yours? Seems odd. Or it still pulls from somewhere else than you think. Maybe domain conflict? For example you cannot name your module as subprocess.py, because there is already standard library modul named subprocess, I did it once and error message was not particularly clear about that. |
12th August 2019, 02:25 | #3489 | Link | |
Short version - I reinstalled python for all users now, but it's in a different location now; so that's where you have to copy over the scripts to the new site-packages location . When you install for "all users" it's Program Files => Python37 => Lib => site-packages (at least on Windows , for x64) |
12th August 2019, 04:49 | #3490 | Link |
Pig on the wing
The only easy way to make it work was to use the folder which VSRepo uses (%appdata%\Roaming\Python\Python37\site-packages). I've had Python installed in that mentioned directory under Program Files for a long time now but I don't know why it stopped working now.
12th August 2019, 05:13 | #3491 | Link |
At least you have a workaround . The site-packages in the Program Files seems works for me, but my old Vapoursynth Plugins64 directory changed to the AppData\Roaming\VapourSynth\plugins64 directory . Not sure why all the changes.
12th August 2019, 15:06 | #3492 | Link | |
2. Unprivileged installs. Try reading the changelog. Program files isn't writable for everyone.
13th August 2019, 15:59 | #3493 | Link |
Sorry to ask this here, I haven't seen it anywhere else. So ... HELP!
Where can I get Vapoursynth packages? Ubuntu PPAs is not active any more and doesn't seem to be any viable alternative... I already tried to compile it myself, but after compiling from sources zimg and vapoursynth R47.1, after solving the Python environmental variable (In Ubuntu Python 3.7 is not in the same place), now I can't load the ffsm2 plug-in. I tried to download and compile it myself, but I don't know where to copy the plug-in, or which file it is ... ffmsindex is working from that sources after "make install", but don't know where the plug-in is or goes. Something as simple as: import vapoursynth as vs core = vs.get_core() video = core.ffms2.Source(source="Lol.mp4") video.set_output() returns me using vspipe: "AttributeError: No attribute with the name ffms2 exists. Did you mistype a plugin namespace?" Something I forget in the vapoursynth compilation? |
13th August 2019, 18:16 | #3495 | Link |
Yep! That solved it!
So, Ubuntu is installing everything in the wrong places or Vapoursynth is looking always where it shouldn't. Grrrr! And what about having a working Ubuntu PPA? That will had been so much easy, as it was before! Now I don't have a working vsedit ... |
13th August 2019, 20:43 | #3496 | Link | |
14th August 2019, 07:05 | #3497 | Link | |||
Cannot Install R47
Downloaded
Uninstalled Python and Python Launcher and reinstalled it. Tried reinstall for Quote:
Running Windows10 with newest updates. Last edited by george84; 14th August 2019 at 07:10. |
14th August 2019, 17:52 | #3498 | Link | ||
Where did you get Python ? MS STORE ? According to this Quote:
14th August 2019, 19:20 | #3499 | Link | |
Software Developer
Then, skip over the "Optional Features" page that comes next (you can keep defaults here) and, on the "Advanced Options" page, be sure to enable the "Install for all users" option. If you installed Python before and missed to do this, then you'll have to uninstall first and then install again. (Also be sure to download and use the "Windows x86-64 executable installer" of Python, if you intend to use VapourSynth64. The Python website tries to trick you into downloading the "x86" version)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 14th August 2019 at 19:29. |
speed, vaporware, vapoursynth |
