15th March 2010, 00:40 | #7141 | Link | |
15th March 2010, 01:06 | #7142 | Link | |
DTSMA -> .wav/.flac -> AC3 640kbps = DTS 1,5Mbps DTS -> .dts (not .wav/.flac!!!) - audio is untouched
15th March 2010, 01:40 | #7144 | Link | |
hey Atak, quick question...successfully converted two movies yesterday, and have not done anything different since...and today im getting this error:
15th March 2010, 08:54 | #7146 | Link |
What exactly do you NOT understand? I think Atak has made it pretty clear. If the movie you are trying to convert has a DTS (NOT DTS-HD MA), then you can tell RipBot to use that without converting. RipBot only converts DTS if you tell it to. If the movie has DTS-HD MA audio then RipBot will either strip out the DTS core or convert to FLAC. I don't know how to make this any simpler.
15th March 2010, 13:36 | #7148 | Link | |
The RipBot does not extract the core of a source DTS-HD (not MA), just gives me the option to convert using aften. Edit. I used eac3to for so long that do not pay attention to these parameters. In some movies with DTS-HD tracks have that option and others this option does not exist. Last edited by soneca; 15th March 2010 at 15:09. Reason: correction |
15th March 2010, 14:47 | #7149 | Link |
HD-Fan
Another question,
Is it possible that RipBot264 will have "auto-appending" feature? For example, you load in an small clip of AVI file then it will do all the necessary things first (like demux, extract frame, gather info) etc. Then there is another button for "auto-append" whatever but not the regular "open" button and it will do the same thing like demux, extract frame etc BUT RipBot264 will combine the first converted file and the 2nd converted file at the end of 2nd file's conversion. It doesn't have to be only 2 files, can be 3 or more files combined after conversions. I think this feature will be very useful. Just an idea. MKVCrazy |
15th March 2010, 17:48 | #7150 | Link | |
15th March 2010, 19:13 | #7151 | Link |
Maximum Performance with Ripbot
First off, I love RipBot! Thank you so much for developing RipBot and providing the great support that you do! I always use RipBot for all x264 and VC-1 to convert to MKV.
I have a 4 processor quad core Opteron 8356 2.3GHz server board for 16 total CPUs running Server 2003 R2 Enterprise I'm using ffdshow 3316 ICL10 with 64 bit on top. I have noticed in ffdshow the max threads I can set is 8 - wonder why that is? Are there any other things I can change to take advantage of the 16 CPUs? ffmpeg-mt is running 100% CPU converting M2TS to MKV. When I convert VC-1 using WMV9 to MKV, it varies between as low as 20 and as high as 100%. Is that due to WMV9? Is the Haali disk buffer just for playback? RipBot has the vbv buffer size set at 25000. What does that do? There does not appear to be a 64 bit build of avisynth. Basically, the 4p machine is about 80% faster than a quad Phenom at 3.4GHz. I'm thinking about switching to Linux for Folding at Home. Any advice how Ripbot will do in Wine or some other Windows emulator? I could always do a dual boot. One thing I have noticed with Windows is that I have 6 Gb of RAM doing nothing while Windows pages even though I have told it not to page. I can't figure that one out. The same age old mystery of paging strikes again. Just looking for any more tweaks. Thanks |
15th March 2010, 19:57 | #7152 | Link | |
HD-Fan
For ex. Treat the segments separately (like 2 different jobs) with same settings then combine the outputs afterwards. |
15th March 2010, 20:08 | #7153 | Link |
What are you doing exactly??
16th March 2010, 02:19 | #7154 | Link | |
16th March 2010, 03:21 | #7159 | Link |
Yes, the DTS Decoder that comes with Arcsoft TMT will help you to achieve what you are trying to do. If you look in the tools/ax directory of your RipBot installation you will find further instructions as to how to setup the decoder.
