Old 12th March 2010, 22:03   #7121  |  Link
hoju3508
I remuxed your sample in tsmuxer and it works in 1.15.1 without problems!
If you don't mind me asking, what version of ffdshow are you using?
I'm currently on this rev: r3301 2010-03-03 (March 03, 2010).
hoju3508 is offline   Reply With Quote
Old 12th March 2010, 22:10   #7122  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
r3305 but 3301 was also ok
Old 12th March 2010, 22:19   #7123  |  Link
laserfan
Aging Video Hobbyist
AC3 320kbps is very very very rare. That's why I didn't include proper algo for that weird bitrate.
NP next time I know to make it 256 instead.
p.s. Here is a list of "legal" AC3 bitrates that I go to when choosing an audio bitrate, taken from some DD doc:
‘000000’ (0) 32 kbps 60 42 40
‘000001’ (0) 32 kbps 60 43 40
‘000010’ (1) 40 kbps 75 53 50
‘000011’ (1) 40 kbps 75 55 50
‘000100’ (2) 48 kbps 90 65 60
‘000101’ (2) 48 kbps 90 65 60
‘000110’ (3) 56 kbps 105 75 70
‘000111’ (3) 56 kbps 105 76 70
‘001000’ (4) 64 kbps 120 86 80
‘001001’ (4) 64 kbps 120 87 80
‘001010’ (5) 80 kbps 150 108 100
‘001011’ (5) 80 kbps 150 108 100
‘001100’ (6) 96 kbps 180 130 120
‘001101’ (6) 96 kbps 180 130 120
‘001110’ (7) 112 kbps 210 151 140
‘001111’ (7) 112 kbps 210 152 140
‘010000’ (8) 128 kbps 240 173 160
‘010001’ (8) 128 kbps 240 173 160
‘010010’ (9) 160 kbps 300 217 200
‘010011’ (9) 160 kbps 300 217 200
‘010100’ (10) 192 kbps 360 260 240
‘010101’ (10) 192 kbps 360 261 240
‘010110’ (11) 224 kbps 420 303 280
‘010111’ (11) 224 kbps 420 305 280
‘011000’ (12) 256 kbps 480 347 320
‘011001’ (12) 256 kbps 480 348 320
‘011010’ (13) 320 kbps 600 435 400
‘011011’ (13) 320 kbps 600 435 400
‘011100’ (14) 384 kbps 720 521 480
‘011101’ (14) 384 kbps 720 522 480
‘011110’ (15) 448 kbps 840 608 560
‘011111’ (15) 448 kbps 840 610 560
‘100000’ (16) 512 kbps 960 696 640
‘100001’ (16) 512 kbps 960 696 640
‘100010’ (17) 576 kbps 1080 782 720
‘100011’ (17) 576 kbps 1080 783 720
‘100100’ (18) 640 kbps 1200 870 800
‘100101’ (18) 640 kbps 1200 871 800
laserfan is offline   Reply With Quote
Old 12th March 2010, 22:44   #7124  |  Link
soneca
Here is my sample. >>> Link
soneca is offline   Reply With Quote
Old 12th March 2010, 23:29   #7125  |  Link
MKVCrazy
HD-Fan
One question, is MKV demuxing suppose to be a lot slower than demux an AVI file on RipBot264 or it'll being tried to improve? Right now, demuxing a small MKV file size is slower than a large AVI. I am guessing it's because of the x264 codec used in that MKV but I still want to hear why, from you. Thx.
MKVCrazy is offline   Reply With Quote
Old 13th March 2010, 02:10   #7126  |  Link
Atak_Snajpera
corrupted rar
Old 13th March 2010, 02:14   #7127  |  Link
Atak_Snajpera
100 mb mkv with dts 1,5mbps was demuxed in 3s on my old 250gb samsung
Old 13th March 2010, 06:12   #7128  |  Link
soneca
The mediafire seems to be corrupting the files lately ....
You can download it through sendspace? >>> Link
Old 13th March 2010, 22:43   #7129  |  Link
Atak_Snajpera
Again it works on my win7 x64 without problems...
Old 13th March 2010, 22:53   #7130  |  Link
soneca
So I have no idea what might be ...
When I go back to version 1.15.0 works without problems.
I'm using ffdshow r3301.
Old 13th March 2010, 23:02   #7131  |  Link
Atak_Snajpera
I have no idea either. It does not matter if I use 1.15.0 , 1.15.1 , older ffdshow ,newer ffdshow ... works as usual
Besides both versions use DirectShowSource
Old 14th March 2010, 00:32   #7132  |  Link
soneca
I installed the r3316 and now is working!
Old 14th March 2010, 08:09   #7133  |  Link
hoju3508
Originally Posted by hoju3508 View Post
^Nothing has change on my system except for version 1.15.1 of RipBot264. I'm not seeing this problem when rolling back to 1.15.0.
This is not quite true. I had installed AVCHDCoder before trying out version 1.15.1. I went ahead and uninstalled AVCHDCoder, ffdshow, Avisynth & Haali Media Splitter, and re-installed ffdshow, Avisynth & Haali Media Splitter. Now, version 1.15.1 is working perfectly for me .
Old 14th March 2010, 18:41   #7134  |  Link
god_md5
only one thing is not good in this software,RipBot264.ini is not save all the setup,open open movie is need to edit one time
like denosie and color ,deinterlace is not save .maybe lock size is same cannot save,but not test..
and indexing file use many time to wait..
god_md5 is offline   Reply With Quote
Old 14th March 2010, 18:48   #7135  |  Link
god_md5
ffdshow ver problems can open the use in "ffdshow Video decoder configuration "???
http://dl.dropbox.com/u/3668343/Scre...15%2001.44.jpg
Old 14th March 2010, 21:46   #7136  |  Link
Atak_Snajpera
what?
Old 14th March 2010, 23:26   #7137  |  Link
DVDfever.co.uk
I really like Ripbot, but it has one major niggle for me since I started using it (I'm using v.1.15.0, BTW).
For every video I want to turn into an mp4 file, I want to use the same custom resolution (1024x576) and to set 25fps interlacing, but I have to manually tell it this *every* single time for *every* single video file and it's annoying *every* time.
Please can you add something which allows me to save a set of custom settings? Other than that, Ripbot is perfect. I used to use Super, but while it worked under version 35 (for some reason version 37 doesn't work on my Vista PC and when I tried to uninstall that and go back to 35, even doing a system restore), it's just killed it on this PC for me, the one really annoying thing it did was kill any Outlook processes for me while processing, meaning I couldn't use that while converting files and having to run it again afterwards.
Thanks in advance.
DVDfever.co.uk is offline   Reply With Quote
Old 15th March 2010, 00:13   #7138  |  Link
Atak_Snajpera
did you try custom resolution with locked aspect ratio
Old 15th March 2010, 00:27   #7139  |  Link
DVDfever.co.uk
How do I lock it, please? I just get "Custom [x,xx:1]" in that box. Ta.
Old 15th March 2010, 00:34   #7140  |  Link
soneca
Unfortunately RipBot264 not process directly DTS tracks as in previous versions.
I agree when you say that the Dolby Digital is better, but do not want to convert a font that contains only track in DTS to DD. The ideal is to keep this soundtrack without conversion.
So, eac3to together ...
