22nd January 2008, 23:22 | #2841 | Link | |
Thanks for all of your hard work, and as someone else mentioned, provide a way for us to financially support your efforts and I will be happy to do so. |
22nd January 2008, 23:24 | #2842 | Link |
1. Thanks for new version.
2. I have Lives of others Blu-ray (24 fps) but video is avc, not vc-1. I guess you don't need a sample of this. 3. Re-ripping of Million Dollar Baby isn't an option for me (). Should i try again with 2.17, or the improved gap/overlap detection doesn't make any difference in this? 4. eac3to -test with 2.16 & 2.17 works fine. 5. In which cases should i use the option to remove the pulldown flags? What is the difference (i know i should have asked a few versions ago, when this feature was introduced)? 6. Can you answer us whether nero and libav truehd decoders can output more than 5.1 (6ch)? Last edited by nautilus7; 22nd January 2008 at 23:31. |
23rd January 2008, 00:00 | #2843 | Link |
have only demuxed blu-ray files with xport so far. thats why im wondering, why this remapping message not always appeared in every case. so do you think there could be the problem, if this message didnt appear, that my channels have been remapped in the wrong way?
23rd January 2008, 00:19 | #2845 | Link |
Uploading samples of Sum of all fears and Born on the 4th of July tonight (no time for this yesterday).
One thing that would be great is to have fps info stored in some way. Media Control 4.7 is close to have automatic refresh rate change for all us Vista Media Center users. It reads the refresh rate from ffdshow. And titles created with 2.15 and later are reported as 25fps. So the automatic refresh rate change/match functions does not work properly. |
23rd January 2008, 00:45 | #2846 | Link | |
million dollar baby also doesnt work with 217 for me, it reports a gap of 9 frames at 0:00:01 playtime, but same problem as with the other movies. heres the 24fps sample from infernal affairs, cut it with a hex editor so i hope its fine. http://www.sendspace.com/file/g8ua0f Last edited by Thunderbolt8; 23rd January 2008 at 01:46. |
23rd January 2008, 03:28 | #2847 | Link |
1080ps3
I get this error after 30-40 min of processing:
C:\eac3to>eac3to.exe EVOB002.EVO ddda.mkv EVO, 1 video track, 2 audio tracks, 2:03:53 1: VC-1, 1280x1080 24p /1.001 2: AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB 3: AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB Extracting primary video track... Extracting audio track number 2... Extracting audio track number 3... Muxing video to Matroska... Removing dialog normalization... Removing dialog normalization... Creating/writing file "audiotrack 1.ac3"... Creating/writing file "audiotrack 2.ac3"... This track is not clean. Processing aborted. Please clean the track with delaycut and then retry eac3to. Waiting for DirectShow decoder thread to finish. Please wait... edit: I extracted the first 150mb of the vc1 video from the evo and it looks amazing in powerdvd! now if i could just get the audio portion... edit2: Track 3 is the problem. I re-ripped and still exists... something about the source. Just need to know how to skip unwanted audio tracks. Track 2 is the one I want. Code:
c:\eac3to>eac3to.exe c:\temp\EVOB002.EVO 3:ddda3.ac3 EVO, 1 video track, 2 audio tracks, 2:03:53 1: VC-1, 1280x1080 24p /1.001 2: AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB 3: AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB Extracting audio track number 3... Removing dialog normalization... Creating/writing file "ddda3.ac3"... This track is not clean. Processing aborted. Please clean the track with delaycut and then retry eac3to. Last edited by darkbeats; 23rd January 2008 at 08:04. Reason: new info |
23rd January 2008, 04:19 | #2848 | Link |
With no fps stored in the mkv header, could someone possibly give me a heads up as to how to open my resulting MKV in MeGUI. It's telling me that there's no fps information in my file and to manually add the fps to my avisynth script. I tried but cant get it to work. Im using the avisynth script creator in the app itself. My goal is to re-encode down to 720 to play on my 360 - which until this latest version Ive been able to do using MeGUI.
Thanks! |
23rd January 2008, 04:40 | #2849 | Link |
2.17 no luck
D:\EAC3>eac3to -test
Nero Audio Decoder (Nero 7 or older) doesn't seem to be installed Sonic Audio Decoder (2.17.0.0) doesn't seem to be installed Haali Media Splitter doesn't seem to be installed Surcode DTS Encoder (1.0.21.0) is installed MkvToolnix (v2.1.0) is installed Same as 2.16, damn. Let me see if reinstalling will help. |
23rd January 2008, 04:48 | #2850 | Link |
2.17 handles Born on the 4th of July without problems...
Sample of Sum of all fears: http://www.earselect.se/sum.evo Last edited by rickardk; 23rd January 2008 at 07:21. |
23rd January 2008, 08:38 | #2851 | Link | |
C:\eac3to>eac3to.exe EVOB002.EVO 1: ddda.mkv 2: audio.ac3 Code:
C:\eac3to>eac3to.exe EVOB002.EVO 1: ddda.mkv -[options for 1:] 2: audio.ac3 -[options for 2:] |
23rd January 2008, 09:09 | #2852 | Link | |||
Currently there's not a single TrueHD track with more than 5.1 channels available on any disk (that I know). So there's no way to test. I guess that Nero will probably be limited to 5.1. The libav decoder might currently also be limited to 5.1, but as soon as a sample with more than 5.1 is available, the libav decoder will surely be updated to support that. |
23rd January 2008, 09:18 | #2853 | Link | ||||
23rd January 2008, 09:21 | #2854 | Link | ||
If all else fails, you can still rewrite the timestamps with mkvtoolnix. Rewriting the timestamps will also write the fps value to the header. I don't really like the idea to rewrite timestamps which should already be perfect just to have a single number added to the header, but I don't know any other way to realize that right now... That's very nice... Have you had a chance to check if it plays fluidly without any stuttering? Also a quick comparison to a v2.14 remux would be lovely, if you have time and fun to do that. Quote:
23rd January 2008, 09:23 | #2855 | Link | |
23rd January 2008, 09:23 | #2856 | Link | |
23rd January 2008, 10:42 | #2857 | Link |
i've got a .ts file(untouched remuxing of a bluray disk).i'd like to convert the lpcm 5.1 audio track to 6 wav mono tracks,apllying a pal speedup.first of all i've got to say that i'm not able to extract the track from .ts file neither using tsremux(doesn't recognise it at all) or xport(a discontinuity messege keep flashing while processing the stream).i worked 2 ways to do that: muxing it in mkv with gdsmux and extract the audio with mkvextract(i get a wav 5.1, channels not remapped) or demuxing audio using elecard xmuxer(i get a mpa 5.1,channels not remapped).
converting the mkvextract obtained wav file with eac3to2.16, it recognisethe track as wav 5.1,24bits,it doesn't remap the channels(i could do it later renaming the wavs) but it works fine even with pal speedup applied. if i try to convert the xmuxer obtained mpa file (renamed .raw or .pcm), eac3to recognise it as pcm 5.1,24bits,big endian,bluray track.it changes correctly the channels mapping, but it works just with no pal speedup applied(using speedup command it stops right at the end of process showing a "the resampler thread seems to hang" message). the questions are: is the "mkv muxing and extracting" procedure correct? anybody knows why with the raw file(i suppose it's better recognised by eac3to) the conversion fails with speedup? |
23rd January 2008, 10:55 | #2858 | Link | ||
23rd January 2008, 11:07 | #2859 | Link | |
23rd January 2008, 11:08 | #2860 | Link |
No, I generally need samples in the original format, that is EVO. If I really wanted the raw AVC stream, I could demux it myself from the EVO. So uploading an EVO sample does not harm. I want the EVO because I also want to check the EVO timestamps and the audio tracks and how it all works together with 24.000 etc... Thanks!
eac3to |
