4th February 2010, 11:33 | #1181 | Link |
Acid fr0g
Well, picture that almost anytime BD has SAR 1:1 and PAL DVD 64:45
P.S: If you play a video before encoding, FFDShow gives you the correct PAR/SAR in the info.
@turment on Telegram Last edited by tormento; 4th February 2010 at 12:08. |
4th February 2010, 15:11 | #1182 | Link |
@Turtleggjp
Thanks for bringing that stream to light. It exposed a subtle problem in my indexing for AVC streams. It affects this case only: BFF field pictures with IDR/I in the first field and P/B in the second field of anchor frames. I have it fixed locally but need to do some regression testing. It will be in build 2006. Last edited by Guest; 4th February 2010 at 15:17. |
5th February 2010, 03:38 | #1186 | Link |
Build 2006
* Improve GOP back near EOF.
* Delete the navigation trackbar and subsume its functionality into the selection bar. I find the action more logical for navigation and parsimony demands the deletion. There is still an issue with flashing of the bar that I am addressing. Isn't Win32 GDI wonderful? * Improve handling of this error case: open a transport stream for which the video PID specified in the first program in the PAT/PMT has no data. * The cropping dialog now shows the resulting mod values and adds a static note about fine movements. * Cropping can now be specified via CLI. For example, dgindexnv -i "phasecoherence.vc1" -c 8 8 8 8 * For opening program streams, increase the depth of initial scanning of the source file when looking for audio channels. This avoids missing some audio streams that do not begin immediately. * Fix an indexing bug for some AVC BFF field-structured streams. http://neuron2.net/dgdecnv/dgdecnv.html |
5th February 2010, 04:02 | #1187 | Link |
@neuron2
great support like always thank you very much my recent backups just got higher on my todo list
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
5th February 2010, 10:36 | #1191 | Link |
Acid fr0g
Unfortunately the bugs I reported you have not been solved:
I think for today it is enough!
@turment on Telegram Last edited by tormento; 5th February 2010 at 10:38. |
5th February 2010, 15:09 | #1192 | Link | |||
5th February 2010, 15:49 | #1194 | Link |
Acid fr0g
Indeed.
If you try to cut the initial 15 seconds from the VOB, the audio tracks are ok. Probably when the reauthor editor has added the distribution logo (the 1st 15 seconds you see in the video), he committed some wrong editing or so. I'll leave the conclusion to he who knows much more than me.
@turment on Telegram |
5th February 2010, 20:58 | #1197 | Link | |
I can't give you so many files either but two days ago I've started working on a small command-line utility for duplicating single files (don't ask me why I need it). May be it would help when ready? |
5th February 2010, 21:38 | #1198 | Link | ||
5th February 2010, 23:08 | #1199 | Link |
http://www.mediafire.com/?wjwmdn5gtzt
Glitch at ~27" I get no glitch with ffdshow or coreavc Don't navigate there, let the video play |
