5th March 2012, 00:27 | #12501 | Link | |
Best I can do is supply you with a log FWIW.. I guess ideally I would have MPC build to test that completely reverses the change in 3619. http://www.mediafire.com/?lp2c3xlu9uaqc2u |
5th March 2012, 00:58 | #12502 | Link | ||
And thanks for adding the screenmode switch on fullscreen options. MadVR is (functionally) nearly perfect for me now. |
5th March 2012, 01:27 | #12503 | Link | |
I'm rather convenient with the idea that the renderer only deinterlaces when the content is clearly flagged as interlaced by the decoder. I agree with nev, why should it be a problem to madVR if it isn't to EVR? |
5th March 2012, 03:09 | #12504 | Link | |
Can you recommend any of the default options to change with "Present Several Frames in Advance" checked so more to mimic the behavior of that option unchecked for troubleshooting purposes? Last edited by andybkma; 5th March 2012 at 03:21. |
5th March 2012, 05:22 | #12505 | Link | |
Broadband Junkie
I can also confirm that the issue still exists in that MPC-HC test build.
One thing I've noticed about that build is that there seem to be longer delays when switching to the next file, and a couple times I've seen the madVR OSD report 'Exclusive Mode Failed' upon the next file loading. All very random, so I'm unsure how easy it would be to catch it in a log. Edit: Even though I reproduce the freeze on my first attempt with that MPC-HC test build, I'm having trouble reproducing it a second time at the moment. The exact same problem is definitely still there, but maybe it's less frequent, maybe not. Unfortunately this freeze issue always had some randomness to it, with good and bad stretches. Edit2: It seem the 'Exclusive Mode Failed' is the result of the mouse cursor resting at the bottom of the screen when loading a new file, and that MPC-HC build popping-up the MPC fullscreen controls during this transition when the screen is still black. This kicks madVR out of Exclusive Mode before the next files loads, and since that MPC-HC build keeps the MPC controls up until the next file fully loads, madVR fails to re-enter Exclusive Mode. Last edited by cyberbeing; 5th March 2012 at 07:08. |
5th March 2012, 05:34 | #12506 | Link |
Not sure if this is a question for this thread but just in case, I noticed that I can set my speakers to 7.1 then do a test in x-fi and all are working but when I play the movies only the rear speakers work, not the side ones.
5th March 2012, 06:04 | #12507 | Link | |
Suptitle, MediaPlayer.NET
You're asking questions about audio in a video renderer thread??? |
5th March 2012, 06:07 | #12509 | Link |
Ideally you want to do a whole lot of testing. But first and foremost try your player with another renderer, EVR for example and see if it still happens. If it does still occur then start changing your drivers, changing file content, changing your media player etc. Once you find what's causing it post in the appropriate forum of the developer for that software/hardware.
5th March 2012, 06:24 | #12510 | Link | |
http://forum.doom9.org/showthread.php?t=161590 You didn't get an answer you're satisfied with over there, and you're now posting it here. |
5th March 2012, 06:38 | #12511 | Link | |
I often wonder what kind of satisfaction people like you get from acting like this...is something missing in your personal life that you somehow make up for by doing this? madshi, sorry for the post, I will take this question to a different area. |
5th March 2012, 07:09 | #12513 | Link |
You'll understand if you're a developer, having to take childish insults from noobs who haven't a clue what they're doing. But somehow it's your fault anyway for releasing a free of charge software that is well loved by majority.
5th March 2012, 07:20 | #12514 | Link | |
I really don't rate my chances doing a report, I've deliberately made it crash many times without success in generating one. |
5th March 2012, 15:33 | #12516 | Link | ||||||||||||
http://madshi.net/madTraceProcess.zip It will allow you to select which process to create a report for. Choose MPC-HC. If MPC-HC insists on being in front of the madTraceProcess tool so you can't see the madTraceProcess GUI, just manually switch to it and press return. That should be enough to invoke the freeze report creation. You can start madTraceProcess by using the "New Task" button on the first page of the task manager. Quote:
Anyway, the next madVR version will explicitly detect the MS DVD Navigator and ignore what it has to say. That fixes the primaries misdetection. Great! The "Strike" samples are somewhat similar to the Broken Blossoms samples. Can I have 2 samples more from "Strike"? Thanks a lot!! |
5th March 2012, 18:28 | #12517 | Link |
I would like to talk a little about system freezes as I have had trouble with this over the last few weeks again. Firstly when I say system freeze I am talking about a complete system lockup with the only solution being a reset. This is not madVR related so much but I hope madshi does not mind me posting this here as it may help some of you.
I want to go back all the way to reclock v1860. This release of reclock used a new audio resampler and for what ever reason it was just not stable on my system as sometimes it would cause a system freeze a few seconds into playback, sometimes after an hour and sometimes not at all. Given I could go back to the previous version of reclock and the problem was gone I perstered james about this issue after every reclock released until I just gave up in the end. I went though everything I could think of, from memory tests to hours of prime95 but everything was stable. To cut a long story short this issue was never fixed and in the end I used a complied Resampler.dll that used the old sampler to solve the issue with newer reclock releases or use bit streaming. At some point I tried the newer resampler again and everything was fine.. Basically I never found what the cause of the freeze was.... Now about three weeks ago I did a few system software upgrades, Mobo bios and GFX driver, madVR and LAV... I thought everything went fine but guess what..... BAM the freezing during movie playback had returned.... A few minutes later I remember my passed issue and tried the old reclock resampler.dll and guess what freeze was gone instantly. I though to myself let me undo all the upgrades to see if I can finally find the cause. I put back the old bios with its previous settings (that were saved), no joy. Put back the older gfx driver but no joy, old madVR, no joy. Finally old LAV, no joy. So again I ran through all the stress tests I could think of but nothing turned up a problem.... So now my system is back where it was with this issue. I personally feel its an issue between the onboard audio of my nvidia gfx card and one of the onboard LAN adapters on my mobo. It seems that the freeze only happens when either intensive audio is playing or doing something lan related... Initialting the TOR client for example can cause the freeze. My point here being that it could have been very easy for me to point the finger at madVR given a new version was running when the freezes started to occur again during video playback. It was only my past experiance on my system that stopped me reporting to this thread. My advise to anyone now getting system freezing (esp if you updated to the new 295.xx nvidia drivers) is to try the following tests; 1) Disable any onboard LAN adapters and see if the freeze stops. 2) Take reclock out of the loop and see if system freezes stop. 3) Play a video while not using an audio device onboard a gfx card and see if the freezing stops. Only after you have ruled out the above can you start thinking about it being an issue with madVR. |
5th March 2012, 20:41 | #12518 | Link | |
Antichrist too I think (but I don't own that one). Not saying there are many of those though |
5th March 2012, 21:17 | #12519 | Link |
The Blu-Ray spec doesn't allow 25p, it only allows 50i, as far as I know. Ok, I guess you can encode 25p with telecine flags. Anyway, topic closed, I bowed to the majority vote. So no need to discuss this any further.
5th March 2012, 22:18 | #12520 | Link |
