19th May 2009, 03:08 | #101 | Link |
Didée Fan
Arshad07,
I tried a few encodes. First I demuxed the audio from video using tsmuxer. I only used the video in the encoding. I had to switch where the filters went. After I used tsmuxer I used dgsplit to rip 100MB and used the extension on the tsmuxed video file on the dgsplit file. Loadplugins setmtmode(5) DirectShowSource MT(" LimitedSharpenFaster ",2) spline64resize # this wasn't using mt and it worked fine Setmtmode(2) mvtools code I could see the part of the video I cliped using dgsplit was not entirely in the encoded version. i was missing around 30 seconds of the minute I prepared for encoding tests. I could not get the whole 60 seconds regardless of how i tried various scripts. I don't encode blu ray but I think maybe directshowsource can't handle the .mpv I was using with it. So what I'm saying is you may encode and eith er see a ugly picture because the filters were not stacked right, or you may not see the whole movie only half of it. mdegrain is in mvtools2, mvdegrain is in mvtools.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. |
19th May 2009, 20:45 | #104 | Link |
Actually in reserve
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. |
20th May 2009, 07:15 | #105 | Link |
ZZZzzzz...
Whether MT or SetMTMode is better depends greatly on what the script is trying to do. Try using one, then the other, and finally use what works best. SetMTMode is probably safer, but a little slower in some cases. Like BigDid said, read the info and experiment.
21st May 2009, 19:28 | #107 | Link |
Actually in reserve
Hi Merlin,
http://forum.doom9.org/showthread.ph...53#post1286353 I did not had the opportunity to thank you for mirroring the MT 2.58 files, also to Jeremy for starting the thread and to SET for his alternate dll It seems more and more people are using the MT 2.58 without always reading the doc first Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. Last edited by BigDid; 31st May 2009 at 18:54. Reason: link added |
30th May 2009, 03:23 | #109 | Link | |
Jeremy Duncan Fan
@ Jeremy Duncan
Is there any way to increase the speed of this script, cos its not using my cores that much; only like 40% [ with XviD ] Quote:
31st May 2009, 11:11 | #111 | Link | |
You should find a demanding moving scene when testing CPU usage. After a lot of testing best is SetMTMode(2). Then focus on setting up the actual filters parameters. |
31st May 2009, 11:18 | #112 | Link |
Jeremy Duncan Fan
Anyone could check the sample, the video is messed up using SetMtMode and MT
http://www.sendspace.com/file/s1q5m1 |
31st May 2009, 12:50 | #113 | Link | ||
Carlos Martinez
Something like this would work? Quote:
31st May 2009, 20:40 | #116 | Link |
Hmmm... Weird, because here the problem with 2 threads using a dual-core CPU is that AviSynth (with a MVTools script) can't load the CPU entirely (i.e.: not 100%), slowing down videos with large resolution. With 3 threads I can get a full load and better performance. Maybe we need another opinion here, ahn?
31st May 2009, 21:05 | #117 | Link | |
Actually in reserve
3 threads for - the setmtmode() like (1,3) - for the xvid encoder - for boths? I have 2 cores also, use defaut (0) or 2 cores and I am willing to try Did
31st May 2009, 22:22 | #118 | Link |
Fighting spam with a fish
You can use LSFmod in the same way. LSFmod is a little newer in comparison to LimitedSharpenFaster. It has a couple of bug fixes, and more features. Just replace the LimitedSharpenFaster line with your own LSFmod line and you should be fine.
1st June 2009, 02:46 | #120 | Link | |
If I'm using only the following in a script, do I get any benefit out of using any sort of multithreading in Avisynth itself? How would I do it? Since DGMPGDecNV runs on the GPU, I assume that it can't be multithreaded using MT or SetMTMode (unless anyone knows to the contrary). Suggestions? Thanks!
