7th March 2007, 02:02 | #861 | Link | |
Based on my own test and other people's feedback at here, I must say sonic decoder pack 4.2 is quite unstable. Sometimes it works, sometimes don't. No idea why. Could you check whether this fiter graph can be created? EVO->Sonic HD Demux->Sonic Audio decoder 4.2 -> Default DirectSound ? |
7th March 2007, 02:08 | #862 | Link | |
Pelican9, if you got this "Advanced shows nothing (I mean all '-' and '0')", there is definitely no sound.
Are you sure you are using DD+ audio track? And, please give me a sample of your audio track, I'll try to reproduce this and find out the reason. Quote:
7th March 2007, 02:11 | #863 | Link | |
With the graph you suggested i got connection error 80040217 with both VC1 to the video decoder and DD+ to the audio decoder both 4.2 version. I have also just reformatted my pc incase there were trouble in registry land , i have installed directx latest and your modded dtsac3 filter but still no go Can it be something to do with the DS filters for my audigy2 zs card conflict ? Regards The1n |
7th March 2007, 02:18 | #864 | Link |
i just did a encode of Posidon which seemed to work just fine for sync a/v.
now what is weird is that the video runs a total time of 1:38:13 , but the audio came out at 1:38:15 so a 2 sec difference but when i muxed them together in mp4box i got a perfect sync result?? i am not a master at any of this stuff but does that make sense? heh.. anyways it worked.. i use intervideo audio decoder to process the ddp+ audio in a graph file, and feed it to behappy using a simple avs script. |
7th March 2007, 04:13 | #865 | Link | |
7th March 2007, 06:51 | #867 | Link | |
It can demux every stream from a m2ts file, except for PCM soundtracks which it can demux only in stereo (for now). Last edited by Darth Pinous; 7th March 2007 at 07:10. |
7th March 2007, 06:53 | #868 | Link |
I was finally able to extract the full 5.1 audio. EVO -> Sonic HD Demux -> Sonic Audio Decoder 4.2 -> WAV Dest -> Dump. The trick is, you have to view the properties for the HD demuxer and select the right stream. Probably best to demux and join first so you don't have to deal with picking the right stream in the second file.
7th March 2007, 09:01 | #869 | Link |
ok i think "i have" a repeatable way now for all my HD DVD needs.
i cant use a vc1 or mpv demuxed video stream as it seems to just jump around randomly throughout the film, as if the frames dont have a 0 1 2 3 type stream. it starts off ok then it can jump to say 25mins in and then back to 10 mins into the film etc.. anyways i solve this by just using the rebuilt EVO file directly, which then works perfect for me. here is my script for Posidon: Code:
DirectShowSource("G:\5\PEVOB_1_PEVOB_2.rebuilt.EVO",framecount=141292,fps=23.976,audio=false) crop(8,144,-8,-144) Lanczos4Resize(1280,528) Nicefps() ConvertToYv12() now the audio which i just figured out what i did from the night prior so there is some sync work to do. i used graphedit and connected the ddp+ file i demuxed out of the joined EVO file to the "Intervideo Audio Decoder" which on my comp here is setup only for 2ch audio, but i dont see why 6ch cant be done if you have 5.1 seup. PEVOB_1_PEVOB_2.DD+.6ch.stream.00.English 5.1.ddp ---> Intervideo Audio Decoder i saved that graph out and added it to a simple avs script: Code:
SetMemoryMax(64) DirectShowSource("G:\5\SOUND.GRF", video=false) i used behappy to process the script and used the timestretch plugin to change the audio from the "counted frames amount" to the "calculated frames amount" in Posidon this was 141350 to 141292 now the bit i dont understand, this gives a time of 01:38:15 which is 2 secs slower that the video, but throw these 2 resulting files into mp4box and mux them together and you end up with a mp4 with a runtime of 01:38:15 and synced. i have watched the result on my computer and over my mce2005 media server onto my plasma and it runs perfect on both. so there you have it really, long winded but it works ... for me anyway heh.. Last edited by woah!; 7th March 2007 at 09:05. |
7th March 2007, 13:28 | #872 | Link |
I'm trying the way with last samurai:
mpa ->Sonic HD Demux->Sonic Audio decoder 4.2 -> dump and then I use sox on the dumped file and I obtain a 5.1 wav, but when wavewizard opens the 5.1 wav the time lenght is 51 min too short for last samurai, and when I play each of the 6 mono wavs I get they are all accelerated. I think it could depend on thw 1st step because the total dumped file is 2.6 Gb, too small for more than 2 hours movie. Which are the settings I have to use in graphedit with the blocks? I open the .mpa audio track with graphedit and the chain mpa->Sonic HD Demux->Sonic Audio decoder 4.2 -> default audio device should I try to do it on the evo and not on the mpa file? but I have 2 evo files for the movie while only one mpa demuxed track. Thank you |
7th March 2007, 13:29 | #873 | Link | ||
mine goes Quote:
7th March 2007, 13:33 | #874 | Link | |
Oki, sorry
and using the unilogo.evo file Last edited by MiniMinimal; 7th March 2007 at 13:36. |
7th March 2007, 14:15 | #878 | Link | |
common sense might make you think the ones who made the format should have the best decoder, but common sense doesn't always apply to the company in question. Btw, is there any new decoder coming along for dd+? I'm having a hard time making it work and I rather have something that actually works in a regular player like MPC or similar. |
7th March 2007, 14:32 | #879 | Link | ||
Ok,I had it, but vdubmod used the old ver. that i did forgot to uninstall but now it is another problem: Quote:
