Old 10th July 2010, 13:22   #1  |  Link
nnezz
Encoding H.264 while preserving RGB colorspace / 4:4:4
I have pure RGB video, mostly CGI type footage, that I wish to encode in H.264 while preserving the full 4:4:4 chroma.
From what I can read, the specification supports it via the H.264/AVC High 4:4:4 Intra/Predictive profiles.
But, I can't find any information on how to use this or which applications/encoders support it.
x264 won't take anything but yv12, so where do I go to encode in the full RGB colorspace?
I realize that RGB encoding currently is (much) less efficient than YV12, but I can live with that, as long as I'm able to do it
Please, any help on the subject is greatly appreciated.
Reference: High-Fidelity RGB Video Coding Using Adaptive Inter-Plane Weighted Prediction
(if I confused any terms, excuse me. I'm still learning)
nnezz is offline   Reply With Quote
Old 10th July 2010, 13:44   #2  |  Link
roozhou
seperate RGB to 3 channels and encode to 3 AVC streams
for each stream:
assume R/G/B to be Y, and set each pixel in U & V to 128
roozhou is offline   Reply With Quote
Old 10th July 2010, 17:04   #3  |  Link
nnezz
If I understand right, the idea is to separate each color channel (via avisynth?) treating each R/G/B as luminance while neutralizing the chroma. Then feed each luminance plane into x264 at the same time to produce a final encode?
Although it sounds more like you're saying I have to encode each stream separately, but if I do that then how do I combine the three channels afterwards to make a watchable final file?
I'm a little confused. Please be kind and elaborate a tiny bit on which app I should use for each step.
Old 10th July 2010, 17:23   #4  |  Link
J_Darnley
J_Darnley's Avatar
Avisynth will do both processing steps for you.
For splitting use: ShowRed("yv12"), ShowGreen("yv12") and ShowBlue("yv12")
Re-combining: MergeRGB(red_clip, green_clip, blue_clip)
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 10th July 2010, 18:49   #5  |  Link
nnezz
I encoded each stream and got 3 very large files. The same 355MB 10 second file which ordinarily compresses neatly to 24MB, turned into 3 large streams each about 70MB, each encoded much slower than usual as well, using the same compression profile. Does this seem right?
Now that it's done, I can feed the files back into avisynth using the MergeRGB command, but how do I get the resulting output into a watchable file without re-encoding?
Old 10th July 2010, 18:51   #6  |  Link
J_Darnley
J_Darnley's Avatar
play the avs file
Old 10th July 2010, 20:16   #7  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Dirac supports YCgCo, which can be losslessly converted back to RGB.
Old 11th July 2010, 10:14   #8  |  Link
nnezz
I've found a few other forum posts both here and other places on the web, and it seems that encoding in h.264 without chroma subsampling isn't possible atm. Maybe some day
Thanks for all your answers.
Old 13th July 2010, 20:37   #9  |  Link
kolak
Use Cineform.
Andrew
Old 13th July 2010, 20:44   #10  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Yes, that's an excellent idea
CineForm is a badass codec, and can preserve 4:4:4 nicely.
Old 14th July 2010, 00:31   #11  |  Link
kolak
at 12bit
Old 29th August 2017, 05:34   #12  |  Link
egr
I'm guessing this is no longer the case? Just wanna confirm...
Originally Posted by kolak View Post
Use Cineform.
Andrew
at 12bit
Well it looks like they've closed up shop...
egr is offline   Reply With Quote
Old 29th August 2017, 07:49   #13  |  Link
nevcairiel
Cineform has been standardized as SMPTE VC-5, so even if GoPro shuts down their support, the standardized codec lives on.
Old 29th August 2017, 19:33   #14  |  Link
kolak
codecs is still very alive and now it's actually free.
Adobe, Resolve, Scratch all have native support now.
If you want o build own encoder for example you can drop line here and get your own SDK license key (if they decide it's worth it):
https://gopro.com/connect#cineform
Old 4th September 2017, 20:47   #15  |  Link
Blue_MiSfit
Cineform lives on It's still quite good and flexible.
x264 can do 4:4:4 encoding now, and 10 bit as well, but I'm not aware of any hardware decoder support whatsoever.
h.264, rgb
