14th July 2012, 10:45 | #121 | Link |
New Avisynth filter
mandelbrot 0.2 Jul 18, 2012 by jmac An Avisynth plugin to animate fractals. Usage: mandelbrot(clip clip, float cr_center, float ci_center, float zoom, float aspect, int startcolor, int endcolor, int maxiter) clip - video as template to plot on cr_center pans the image left/right (use -2.5 to +1.5, start at -1.5) ci_center pans the image up/down (use +-1, start at 0) zoom - initial zoom, where 1=the full mandelbrot set aspect - set the PAR. Use 1 for computer, 10/11 for NTSC. startcolor - the lowest color endcolor - the highest color, the colors vary between start and end based on iterations to reach bailout maxiter - maximum iterations, this has the largest effect on speed but needs to be increased for higher zooms The Mandelbrot set is moved/zoomed based on current frame. The colors are not animated, they are based on iterations reached. http://www.sendspace.com/file/qxxijz Version History 0.2 remove extra parameters and just use Avisynth's animate, fix parameters bug, change parameters, new demo. Jul 18 0.1a static build release 0.1 First release - buggy. There is a problem in passing any parameters, so they've been pre-programmed. Jul 14 Last edited by jmac698; 18th July 2012 at 11:39. |
16th July 2012, 05:32 | #122 | Link |
Old Avisynth filter
Decomet 0.4 Nov 10, 2011 by jmac Usage: decomet(clip1, clip2) clips - separate recordings of the same video. The videos must be edited to the same start point and stay in sync. Works by selecting the clean pixels from two separate recordings of the video. http://www.sendspace.com/file/ker4to Note: the original link died, so I'm posting in a more appropriate thread. |
18th July 2012, 15:26 | #123 | Link |
Can´t load Decomet in Avisynth 2.6
Hi!
I´m trying to use Decomet in Avisynth 2.6 but I get the error message: "LoadPlugin: unable to load "C:\Program Files\AviSynth 2.6\plugins\avisynth_c.dll", error=0x7 e" Does Decomet work with Avisynth 2.6? (in Win7 64, but using AviSynth 2.6 32 bits) Thanks in advance! Last edited by William.Lemos.BR; 18th July 2012 at 16:13. Reason: Typo mistake |
19th July 2012, 01:26 | #124 | Link |
Avisynth Developer
0x7E is ERROR_MOD_NOT_FOUND
Install all the modules (libraries) that "C:\Program Files\AviSynth 2.6\plugins\avisynth_c.dll" depends upon. Also not sure what still needs avisynth_c.dll these days, avisynth has included the C interface for a very long time. |
19th July 2012, 06:06 | #125 | Link |
Hello,
I've created a page to discuss such issues here: http://forum.doom9.org/showthread.php?t=165386 It appears to me that this thread was created mainly for announcements, so I'd like to keep it clean. |
23rd July 2012, 12:10 | #127 | Link |
Composite Artefacts Filter Package 0.1
A collection of dot crawl and rainbow filters, with a script illustrating their use. http://www.sendspace.com/file/ja3u2u |
24th July 2012, 20:35 | #128 | Link |
New set of compile-time/run-time functions RT_Stats.
Similar to eg AverageLuma but more programmable. http://forum.doom9.org/showthread.php?t=165479
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th August 2012 at 11:17. |
25th July 2012, 20:13 | #129 | Link |
New Avisynth plugin
findampbyline 0.1 Jul 25, 2012 by jmac A plugin to find the amplitude of a waveform on each line. Usage: findampbyline(clip clip, float scale, int mode) clip - the clip to measure. Should crop out all but waveform. scale - scale factor, for example sqrt(2) to find peak when measuring sinewaves mode - 0: result is luma value 1: result is normalized to luma255=(rms*scale)/110 2: 20*log10(norm)-20*log(1/110)=luma255 http://www.sendspace.com/file/tft7j5 Version History 0.1 First release. 0.2 Fix some scaling issues. Still not completely accurate. Last edited by jmac698; 25th July 2012 at 20:57. |
25th July 2012, 21:01 | #131 | Link |
It can measure the amplitude of a waveform. For example, let's say you draw a sinewave on each line, but a different frequency. The amplitude is 110 (the maximum possible). You can record this signal, and play it back. Now run the filter. The result is the amplitude on each line. Instead of the ideal luma=110 for each line, you start bright at the top and get darker on the way down. This means the sharpness is being reduced as you record higher frequencies.
In other words, this is a precise test of frequency response of a VCR. The official tvlines number is where it reaches half the amplitude, or -6dB. You can use this to test the difference between normal and edit mode, or how a TBC reduces sharpness. Eventually I can create a script to precisely measure any recording/playback/passthrough system, and give a report on various things like noise, linearity, jitter, resolution, bandwidth, frequency response, differential gain and phase, brightness, contrast, tint, saturation, and so on, like an expensive test instrument does. Last edited by jmac698; 25th July 2012 at 21:04. |
26th July 2012, 18:58 | #132 | Link |
x264 fan
Thanks for the explanations but it looks quite complicated. In other words, I think your filter is intended to measure some specifical frequencies as you did to measure those refering to dot crawl but I guess it won't delete anything in practice, just underscore a category of frequencies. If I am correct, It's still unclear why somebody would be required to resort to it. In my opinion, somebody who wants to delete some video artifact will try to use a dedicated filter. Or do you plan to mix your new functions in future scripts ?
26th July 2012, 20:22 | #133 | Link |
Sirt,
It has no relation to general video filtering. It is only for interest of experts and for learning. However, based on the learning, in the future I think I can make better quality of video captures, because I can precisely calibrate the VCR and remove it's distortion effects. Also distortion effects from TBC or other pass-through devices. |
26th July 2012, 21:14 | #134 | Link |
To Sirt: What jmac is opening up here is a whole new dimension to working with AviSynth.
Traditionally, what we do is work with an existing digitised video file, captured either by ourselves or somebody else. We look at it, analyse it, try to figure out what's gone wrong with it (or at least not gone wonderfully), and thus how best to clean it up and/or enhance it... And then we develop the AviSynth scripts (and sometimes whole new plug-ins) to do that. In that approach, we're very often working "blind". We don't *know* what errors were introduced into the video, or how or when or why, so we have to try to figure all that out from looking at the end results of the capture process. Or sometimes, we *do* know what happened, and we wish it hadn't happened and that we'd been able to get involved in the process of analog to digital transfer sooner to stop it happening... But it's too late, so we just have to clean up the mess that we find, as best we can. But in some cases... *We* have the analog source. We ourselves are doing the transfer from analog to digital. Thus, we have access to the hardware that's involved in that transfer, and we thus we have a chance to figure out what it's doing "wrong" (or at least, sub-optimally), that might be spoiling our results and need correcting (or at least reducing) via AviSynth. With tools like the ones jmac is offering/hinting at here, and direct access to the hardware involved in our transfers, we can discover more about what our hardware is doing to the analog sources it gets. That in turn can help us to devise the best kind of filtering to apply after a video has been captured, to correct whatever the hardware is doing "wrong"/sub-optimally. To jmac698: I salute you, sir. More power to your elbow, as we say around here. Last edited by pbristow; 26th July 2012 at 21:22. |
6th August 2012, 05:31 | #136 | Link |
RepairSSE2.dll or RepairSSE3.dll error on Windows Server 2008 R2
I am trying to make a script with Megui for Staxrip so I have scripts in avisynth_plugin folder but when i click Preview or Save button then i received error about 'RepairSSE2.dll' or 'RepairSSE3.dll' but it is work on home pc with 4 GB RAM memory but i prefer to do it on my kimisufi box with 24 GB RAM memory. maybe dll need is outdated or something. it happened to all kind of box with Windows 2008 R2 but work at home pc which is Windows 7 work as well as older like Vista or XP.
Answer replies would be nice. Last edited by theluckyman; 6th August 2012 at 05:36. |
6th August 2012, 06:50 | #137 | Link |
Avisynth Developer
The RepairSSE2.dll or RepairSSE3.dll error sounds like missing runtime support. Install the MSVC runtimes appropriate for the plugins you have.
Can a Mod please strip out to a new thread(s) all of the the recent posts that are not actually announcing a new plugin or utility. E.g #123 to #126, #130 to #135, #136+#137(this post) |
30th August 2012, 20:19 | #138 | Link |
Formerly davidh*****
preroll.zip
This plugin attempts to solve issues caused with certain audio sources (such as nicac3source), that being that if a video frame's worth of audio is requested when the previous video frame's audio has not been decoded, then the decoder may not produce the expected audio (it may fade in from silence for example, which could become an audible glitch if a video is trimmed and re-spliced). All the filter does is fetch the previous frame's audio if it wasn't the last frame requested, before then fetching the current frame's audio and returning it. Usage is just: Code:
clip=clip.preroll David |
30th August 2012, 22:01 | #139 | Link | |
31st August 2012, 09:09 | #140 | Link | |
David |
