Old 18th November 2019, 18:41   #1221  |  Link
Andy
Originally Posted by Atlantis View Post
Thanks for updating FFT3DFilter. I find it to be the fastest and best temporal noise reduction. It's more practical.
Yes, I also started using. It is faster than QTGMC and leaves slight noise like bluray.
I would like to ask which noise filter retains the bit depth of the 10bit source?
I ask because I have been working with Staxrip 2.0.0.0 and 2.0.2.4 for a long time, which had the wrong script template (colorspace = YV12) and so I have all the UHD rips basically 8bit ...
According to this table FFT3DFilter should suit if I understand it well:
http://avisynth.nl/index.php/Externa...oral_Denoisers
Andy is offline   Reply With Quote
Old 19th November 2019, 00:15   #1222  |  Link
Atlantis
I'm not 100% sure but I think FFT3DFilter is correctly handling 10bit source. I am currently using FFT3DFilter with 4K HDR sources and all seems correct.
I also use RemoveGrain
https://forum.doom9.org/showthread.php?t=174347
10-16 bits and 32 bit float colorspace support in AVS+
Atlantis is offline   Reply With Quote
Old 19th November 2019, 08:46   #1223  |  Link
t3nzin
A few updates since 2.0.6.0 and some that didn't make it:
- d2vsource v1.2 (https://github.com/dwbuiten/d2vsource/releases/tag/v1.2)
- AVSMeter v2.9.7 (http://www.iol.ie/~schubert/gas/gas.html) & (https://forum.doom9.org/showthread.p...97#post1889697)
- BDSup2Sub++ v1.0.3 (https://github.com/amichaeltm/BDSup2...sPlus/releases)
- chapterEditor v1.19 (https://forum.doom9.org/showthread.p...72#post1884972)
- AviSynth+ v3.4.0 (https://github.com/AviSynth/AviSynth...ses/tag/v3.4.0)
- Python 3.7.5 (https://www.python.org/downloads/release/python-375/)
- MKVToolNix v40.0.0 (https://forum.doom9.org/showthread.p...63#post1889963)
- SubtitleEdit v3.5.11 (https://github.com/SubtitleEdit/subt...ses/tag/3.5.11)
- rav1e v0.1.0 (https://github.com/xiph/rav1e/releases/tag/0.1.0)
- QSVEnc v3.25 (https://github.com/rigaya/QSVEnc/releases/tag/3.25)
- x265-stable v3.2.1+1 (http://msystem.waw.pl/x265/)
- x265-default v3.2+15 (http://msystem.waw.pl/x265/) & (https://www.mediafire.com/folder/vkt.../StaxRip_Tools)
- x264 r2988 (https://code.videolan.org/videolan/x264/commits/master) & (https://www.mediafire.com/folder/vkt.../StaxRip_Tools)
- MP4Box v0.8.0-rev107 (https://www.mediafire.com/folder/vkt.../StaxRip_Tools)
- FFmpeg Nightly (https://ffmpeg.zeranoe.com/builds/) & (https://www.mediafire.com/folder/vkt.../StaxRip_Tools)
- L-SMASH-Works 2019-11-16 (http://forum.doom9.org/showthread.ph...93#post1890493)
t3nzin is offline   Reply With Quote
Old 19th November 2019, 14:02   #1224  |  Link
stax76
stax76's Avatar
@t3nzin
That is very helpful, thank you. I might start to code something difficult so it might take some time until updating continues.
Old 20th November 2019, 01:47   #1225  |  Link
t3nzin
@stax76 I can send you a PR or file an issue on the github repo if you like, also have a personal Stax change to reimplement the batch system from pre-2.0.
Old 20th November 2019, 18:43   #1226  |  Link
AMED
AMED's Avatar
Hi Stax76,
There is an issue with v2.0.6.0 and the parentheses that are being used. staxrip is using ' for the file path for the vapoursynth source filter which is give an invalid syntax error in python when the file name contains a '.
This occurs with FFMS2 and LWLibavSource.
Python exception: invalid syntax (Batman- The Animated Series - S01E06 - It's Never Too Late_source.vpy, line 6)
Traceback (most recent call last):
  File "src\cython\vapoursynth.pyx", line 1943, in vapoursynth.vpy_evaluateScript
  File "C:\TMP\Batman- The Animated Series - S01E06 - It's Never Too Late_temp\Batman- The Animated Series - S01E06 - It's Never Too Late_source.vpy", line 6
    clip = core.lsmas.LWLibavSource(r'Z:\Bluray\Queue\10\Batman- The Animated Series\Season 1\Batman- The Animated Series - S01E06 - It's Never Too Late.mkv', cachefile=r'C:\TMP\Batman- The Animated Series - S01E06 - It's Never Too Late_temp\Batman- The Animated Series - S01E06 - It's Never Too Late.lwi')
SyntaxError: invalid syntax
import os, sys
import vapoursynth as vs
core = vs.get_core()
sys.path.append(r'Z:\Bluray\Staxrip\Apps\Plugins\VS\Scripts')
import importlib.machinery
resamplehq = importlib.machinery.SourceFileLoader('resamplehq', r"Z:\Bluray\Staxrip\Apps\Plugins\VS\Scripts\resamplehq.py").load_module()
mvsfunc = importlib.machinery.SourceFileLoader('mvsfunc', r"Z:\Bluray\Staxrip\Apps\Plugins\VS\Scripts\mvsfunc.py").load_module()
adjust = importlib.machinery.SourceFileLoader('adjust', r"Z:\Bluray\Staxrip\Apps\Plugins\VS\Scripts\adjust.py").load_module()
havsfunc = importlib.machinery.SourceFileLoader('havsfunc', r"Z:\Bluray\Staxrip\Apps\Plugins\VS\Scripts\havsfunc.py").load_module()
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\fmtconv\fmtconv.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\AWarpSharp2\libawarpsharp2.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\CTMF\CTMF.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\VS\DCTFilter\DCTFilter.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\VS\Deblock\Deblock.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\DFTTest\DFTTest.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\EEDI2\EEDI2.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\EEDI3m\EEDI3m.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\FFT3DFilter\fft3dfilter.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\FluxSmooth\libfluxsmooth.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\HQDN3D\libhqdn3d.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\both\KNLMeansCL\KNLMeansCL.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\BM3D\BM3D.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\mvtools\libmvtools.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\VS\nnedi3\libnnedi3.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\VS\nnedi3\NNEDI3CL.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\Sangnom\libsangnom.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\scenechange\scenechange.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\VS\SVPFlow\svpflow1_vs64.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\VS\SVPFlow\svpflow2_vs64.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\vs\TTempSmooth\TTempSmooth.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\VS\nnedi3\vsznedi3.dll")
core.std.LoadPlugin(r"Z:\Bluray\Staxrip\Apps\Plugins\both\L-SMASH-Works\LSMASHSource.dll")
#clip = core.std.AssumeFPS(clip, None, 25, 1)
clip = core.fmtc.bitdepth(clip, bits=16)
clip = core.std.Crop(clip, 0, 0, 0, 0)
clip = resamplehq.resamplehq(clip, 960, 540, kernel='Spline36')
clip = havsfunc.SMDegrain(clip, tr=4, RefineMotion=True, thSAD=500)
clip.set_output()
A Man Eating Duck
AMED is offline   Reply With Quote
Old 20th November 2019, 20:40   #1227  |  Link
mcjordan
x265 3.2+15 -> New options:
Add options "--scenecut-aware-qp", "--scenecut-window" and "--max-qp-delta" to
enable boundary aware frame quantization, to set window size (optional) and to
set offset (optional).
mcjordan is offline   Reply With Quote
Old 21st November 2019, 15:33   #1228  |  Link
Andy
Thank you, I thought so.
But I'm not sure about RemoveGrain, the table shows only coloformat YV12 and YUY2.
(sorry for bad english, not my native language, I use google translator)
Old 21st November 2019, 17:10   #1229  |  Link
Patman
Patman's Avatar
Originally Posted by AMED View Post
Hi Stax76,
Hi AMED,
i've got these error only with LibavSMASHSource. FFMS2 and LWLibavSource works great.
My Builds
Patman is offline   Reply With Quote
Old 21st November 2019, 18:08   #1230  |  Link
AMED
AMED's Avatar
Originally Posted by Patman View Post
Hi AMED,
When i change the source filter in the Vapoursynth profile i see this
clip = core.avisource.AVISource(r'%source_file%')
clip = core.d2v.Source(r'%source_file%')
clip = core.dgdecodenv.DGSource(r'%source_file%')
clip = core.ffms2.Source(r'%source_file%', cachefile=r'%source_temp_file%.ffindex')
clip = core.lsmas.LibavSMASHSource(r'%source_file%')
clip = core.lsmas.LWLibavSource(r'%source_file%', cachefile=r'%source_temp_file%.lwi')
when it should be
clip = core.avisource.AVISource(r"%source_file%")
clip = core.d2v.Source(r"%source_file%")
clip = core.dgdecodenv.DGSource(r"%source_file%")
clip = core.ffms2.Source(r"%source_file%", cachefile=r"%source_temp_file%.ffindex")
clip = core.lsmas.LibavSMASHSource(r"%source_file%")
clip = core.lsmas.LWLibavSource(r"%source_file%", cachefile=r"%source_temp_file%.lwi")
The workaround is to change the source from automatic to the source filter you want to use and then edit the source filter manually.
A Man Eating Duck
Old 21st November 2019, 18:40   #1231  |  Link
Patman
Patman's Avatar
When i change the source filter in the Vapoursynth profile i see this ...
When i set vapoursynth filters, right-click in filter window and select profiles, these code is shown:
[Source]
Automatic = # can be configured at: Tools > Settings > Source Filters
AVISource = clip = core.avisource.AVISource(r"%source_file%")
d2vsource = clip = core.d2v.Source(r"%source_file%")
DGSource = clip = core.avs.DGSource(r"%source_file%")
ffms2 = clip = core.ffms2.Source(r"%source_file%", cachefile = r"%source_temp_file%.ffindex")
LibavSMASHSource = clip = core.lsmas.LibavSMASHSource(r"%source_file%")
LWLibavSource = clip = core.lsmas.LWLibavSource(r"%source_file%")
Manual = # shows filter selection dialog
Seems to be correct.
My Builds
Old 21st November 2019, 18:54   #1232  |  Link
stax76
stax76's Avatar
If you edit the filter profiles you have to change it only once.
Old 21st November 2019, 19:10   #1233  |  Link
Andy
I'm trying to shrink and convert uhd movie to fhd sdr 10bit while maintaining bit depth according to dghdrtosdr and it seems to work.
Old 21st November 2019, 21:24   #1234  |  Link
AMED
AMED's Avatar
I've deleted the settings folder and reopened Staxrip, chose a new setting folder. Said no to the daily update message then clicked on avs filters > filter setup > vapoursynth. right clicked source and selected Source > ffms.
I have tested this on 3 computers, server 2012R2 and W10 1909
EDIT: I just found this in package.vb
.VSFiltersFunc = Function() {New VideoFilter("Source", "ffms2", "clip = core.ffms2.Source(r'%source_file%', cachefile=r'%source_temp_file%.ffindex')" + BR + "#clip = core.std.AssumeFPS(clip, None, 25, 1)")}})
https://github.com/staxrip/staxrip/b...ackage.vb#L486
Which i assume should be changed to this
.VSFiltersFunc = Function() {New VideoFilter("Source", "ffms2", "clip = core.ffms2.Source(r""%source_file%"", cachefile=r""%source_temp_file%.ffindex"")" + BR + "#clip = core.std.AssumeFPS(clip, None, 25, 1)")}})
d2vsource = https://github.com/staxrip/staxrip/b...ckage.vb#L1602
DGSource = https://github.com/staxrip/staxrip/b...ackage.vb#L453
LibavSMASHSource = https://github.com/staxrip/staxrip/b...ackage.vb#L589
LWLibavSource = https://github.com/staxrip/staxrip/b...ackage.vb#L590
A Man Eating Duck
Old 21st November 2019, 23:28   #1235  |  Link
Salem874
Originally Posted by Salem874 View Post
I've found StaxRip after trying to find a way to rip HDR content to a smaller size, but KEEPING the HDR metadata.
I currently use Handbrake due to the excellent quality of it's exports, plus it's super easy to use (but still flexible), but as we know it's not yet fully HDR/10-bit compatible.
However, i'm extremely confused as to how to re-encode/rip HDR content using StaxRip. Are there any guides/tutorials out there?
I've finally managed to convert an video file but colour mapping it down to SDR-ready video for non-HDR players/screens.
Now, is there any special I need to select/set in the Plethora of options available within Staxrip (Currently running 2.0.6.0)?
I'm liking Staxrip, and it seems to be very flexible, but what it does need is a good set of tutorials (maybe there are already, but i havent found any)
Salem874 is offline   Reply With Quote
Old 21st November 2019, 23:38   #1236  |  Link
stax76
stax76's Avatar
@AMED
https://postimg.cc/94xZNGH0
I'll fix it when development continues, this might take some weeks or even months, I want to replace the interface for avisynth and vapoursynth as well as the rendering.
Old 23rd November 2019, 21:44   #1237  |  Link
Bahamuth
I have several video files with the following codec:
Video
ID in the original source medium         : 4113 (0x1011)
Format                                   : VC-1
Format profile                           : Advanced@L2
Codec ID                                 : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint                            : Microsoft
Duration                                 : 1 min 20 s
Bit rate                                 : 2 216 kb/s
Width                                    : 720 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 3:2
Original display aspect ratio            : 16:9
Frame rate mode                          : Variable
Frame rate                               : 23.976 (24000/1001) FPS
Bit depth                                : 8 bits
Scan type                                : Progressive
Scan order                               : 2:3 Pulldown
Bits/(Pixel*Frame)                       : 0.267
Stream size                              : 21.2 MiB (74%)
Language                                 : English
Default                                  : No
Forced                                   : No
Original source medium                   : Blu-ray
Upon opening them with Staxrip, the automatic crop goes to 358x338 and when I open the crop window, I only get a message on the top saying "Resize error: Resize error 3074: invalid colorspace definition (5/2/6 => 0/2/6). May need to specify additional colorspace parameters"
This comes when I use VapourSynth. When I use AviSynth the crop window works as usual.
So I would guess, this is an error in the crop plugin for VS then? Are the crop plugins this different for VS and AS?
Bahamuth is offline   Reply With Quote
Old 24th November 2019, 14:01   #1238  |  Link
IbrahimKh
Did you both got full CPU usage when converting from HDR to SDR?
I could only get about 20% CPU usage with avisynth and DGHable script. But when DGHable was stripped, I am able to get about 98% CPU usage.
I had to encode 3 videos at once, none of them could get more than 30% CPU with DGHable applied.
IbrahimKh is offline   Reply With Quote
Old 24th November 2019, 21:26   #1239  |  Link
Bahamuth
Another problem I hope I can find some insights here.
File properties:
Format : AVC
Format profile : High@L4
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1 min 5 s
Bit rate mode : Variable
Bit rate : 3 838 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Original display aspect ratio : 4:3
Frame rate : 59.940 (60000/1001) FPS
Original frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Bottom Field First
Bits/(Pixel*Frame) : 0.185
Stream size : 29.8 MiB (95%)
Language : English
Default : No
Forced : No
No matter which deinterlacing I choose, no matter if I don't set any deinterlacer at all, no matter if I set x264 options to Interlaced, Bottom Field First, the output file ALWAYS plays the video only in half speed. What could cause this? As this example is just an advertisement, I could upload it.
Old 25th November 2019, 19:18   #1240  |  Link
JKyle
NVEnc 4.56 is released today.
- Allow one of the value (either width or height) in --output-res to be negative, which will automatically calculate the width or height to keep the aspect ratio.
- Fix issue that VC-1 hw decode was failing in some input files.
- Update option list of weightp, removing "H.264 only".
- Now warning for HEVC + weightp encoding will be shown on Pascal/Volta Gen GPUs.
- Limit HEVC multirefs to make it complaiant to HEVC spec.
- Add option which adds delay to audio stream. (avaliable for avsw/avhw reader)
JKyle is offline   Reply With Quote
aac, hdr, hevc, staxrip, x265
