Old 12th January 2015, 19:19   #1001  |  Link
JohnAStebbins
Originally Posted by bmcelvan View Post
Thanks so much for the info...so if converting audio to FLAC16 or FLAC24 (or any other audio like AC3_5.1_640) from any DTSHDMA source...it will actually be converting from the DTS core, not the HD codec. Thus making all conversions rather pointless?
Pointless from the perspective of preserving the dtshdma stream. But there are other use cases where core dts to flac might be useful. For example, someone wishing to convert to a fully freetard format would have to ditch the dts for something "free" and flac would be a good choise for that.
JohnAStebbins is offline   Reply With Quote
Old 12th January 2015, 22:42   #1002  |  Link
bmcelvan
Originally Posted by JohnAStebbins View Post
Truhd yes
dtshdma not yet. There is a decoder in progress. But progress is slow.
I have the arcsoft dts decoder that I use with eac3to...is there any way to incorporate that in vidcoder?
Thanks
bmcelvan is offline   Reply With Quote
Old 12th January 2015, 22:44   #1003  |  Link
bmcelvan
Yeah, that makes sense. I was thinking only of keeping the lossless high quality audio data, I really am amazed at how bad (compression) both DTS and Dolby are...compared to a free codec.
Old 13th January 2015, 04:29   #1004  |  Link
8ternity
8ternity's Avatar
Does we need to install both? VidCoder + Handbrake?
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 13th January 2015, 06:51   #1005  |  Link
therube
No. VidCoder is self contained (& includes the necessary Handbrake files, like hb.dll).
therube is offline   Reply With Quote
Old 13th January 2015, 14:15   #1006  |  Link
8ternity
8ternity's Avatar
OK Thanks.
Old 14th January 2015, 04:09   #1007  |  Link
bmcelvan
I've been converting my movie files with TrueHD to FLAC16 using vidcoder and want to verify the channel maps are correct. I've noticed when analyzing FLAC files with mediainfo, it simply says:
Channel(s) : 8 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Where the original files with TrueHD say:
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Is it safe to assume they are mapped properly and/or is there a way to check?
Old 5th February 2015, 07:10   #1008  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 2.0 Beta:
The Beta train continues! I've switched to a different versioning scheme: The major number increases for each stable HandBrake version and the minor number increases for each Beta release and bugfix release.
* Added pickers! Pickers let you automatically choose titles, audio, subtitles and destination, as well as automatically queue or start encodes when a source is loaded. While encoding presets customize how a file is encoded, pickers control what is included in the file and where it goes. Let me know if there's anything else you'd like to see added to the Picker window.
* Added a collapsible left panel to the Encoding Preset window, to switch presets quickly.
* Changed window placement to open new windows dynamically in open areas rather than in preset locations.
RandomEngy is offline   Reply With Quote
Old 5th February 2015, 07:22   #1009  |  Link
loninappleton
Add codec packs for h264 Yify small encodes
I lurk at the Vidcoder site and have it installed. Recently I saw some tips (2013 I guess) on the secrets of making small encodes to Handbrake.
The how-to includes some codecs to load via a Handbrake option. How is that handled in the Vidcoder releases?
Please explain how to open those installation options in Vidcoder.
Also if you could critique the article for accuracy, it would help this novice avoid useless techniques:
https://ericolon.wordpress.com/2013/...or-any-device/
loninappleton is offline   Reply With Quote
Old 6th February 2015, 03:10   #1010  |  Link
Honeyko
Honeyko's Avatar
Any chance you could raid the powerful filter set from the discontinued AutoMKV?
In particular I'm looking for MVDegrain3 and FRFun7 (those two are an awesome tag-team combo on grainbomb films, though I would of course not be adverse to anything newer).
Honeyko is offline   Reply With Quote
Old 6th February 2015, 04:24   #1011  |  Link
Asmodian
Those are both Avisynth filters so one can use them anywhere that supports Avisynth (they are not unique to AutoMKV).
FRFun7
MVTools
Old 7th February 2015, 00:23   #1012  |  Link
Honeyko
Honeyko's Avatar
Which currently-maintained GUIs do?
Old 17th February 2015, 07:10   #1013  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 2.1 Beta:
* Fixed handling of old NlMeans denoise, resolving a launch crash for some users.
Old 27th February 2015, 16:49   #1014  |  Link
bmcelvan
Question about 3D, does vidcoder by default convert 3D to 2D. I loaded up my Shrek 1 3D Bluray and converted it the way I always do using a constant quality of 16. The resulting video looks excellent and is in 2D. Well on a 2D monitor and TV looks like 2D and neither player is a 3D player. The mediainfo for the mkv file has only one video source and says all the normal stuff whereas the mediainfo for the 3D stream off the bluray is definitely different. multiple video sources with the word "stereo" in there. I'm assuming the first video source is a 2D video souce (the second stereo is what makes it 3D) and therefore vidcoder just copies the first source?
mkv file
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 30mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : H.264_CQ16_1080p
Bluray m2ts file
Video #1
Menu ID : 1 (0x1)
Format : AVC
Format settings, ReFrames : 3 frames
Codec ID : 27
Duration : 1s 1ms
Bit rate mode : Variable
Maximum bit rate : 40.0 Mbps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Color range : Limited
Video #2
Menu ID : 1 (0x1)
Format : AVC
Format profile : Stereo High@L4.1
MultiView_Count : 2
Codec ID : 32
Duration : 1s 1ms
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Old 3rd May 2015, 01:44   #1015  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 2.2 Beta:
Updated HandBrake SVN to 7149, which uses the new JSON API. This changes the way every encode setting is sent to the HandBrake core, so please kick the tires on this one!
Old 6th May 2015, 15:10   #1016  |  Link
Loomes
I'd like to use Vidcoder to burn subtitles to a MP4 by NOT converting the video and audio tracks. Ofc the video track needs to be modified but I dont want it to be more compressed or converted in any way because it is as good as it is.
Is this possible with Vidcoder? I did not find any option just to copy the video and audio tracks. Thanks.
Loomes is offline   Reply With Quote
Old 6th May 2015, 15:39   #1017  |  Link
detmek
You can not "burn" (hardsub) subtitles without recompressing video. You can mux subtitle (softsub) without recompressing video. But for that you will need mp4box, not VidCoder as VidCoder (or HandBrake) does not support video passthrough.
detmek is offline   Reply With Quote
Old 16th May 2015, 19:35   #1018  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 2.3 Beta:
* Scan progress now shows up on the taskbar icon.
* Added ability to hibernate when completing an encode.
* Preview encode progress bar now correctly reflects total progress and does not reset when doing a subtitle scan or a 2-pass encode.
* Updated HandBrake core to SVN 7170.
* Fixed a bunch of things broken in the JSON API conversion
** Fixed bitrate, quality and compression picking for audio tracks.
** Fixed automatic subtitle selection.
** Fixed reported crash on encode progress update.
** Fixed DXVA decoding.
** Fixed crash when batch-encoding with an audio picker.
** Fixed odd progress reporting for encodes with foreign audio search.
** Fixed the "fast decode" checkbox not getting persisted.
** Fixed the encoding preset for QSV not getting persisted.
* Fixed crash on stable -> beta upgrade when there are no sub-directories in the stable app folder.
Old 17th May 2015, 00:02   #1019  |  Link
soneca
Thank's!
soneca is offline   Reply With Quote
Old 18th May 2015, 00:11   #1020  |  Link
Honeyko
Honeyko's Avatar
A new feature suggestion: Add PAL<>NTSC (25fps<>23/976fps) retiming options with two checkboxes (for video and audio). This will re-encode audio to the new time and re-stream video (if also checked) to the desired frame-rate. (Including video-restreaming would save users an additional step with MKV Merge.)
