Old 1st October 2018, 01:33   #52881  |  Link
SamuriHL
SamuriHL's Avatar
Not true.
Well....that's why I said (I believe). LOL
SDR is supposed to have peak white at around 100-200nits. Which is easy for OLED.
Ok, fair enough. That is definitely true for SDR.
Old 1st October 2018, 01:45   #52882  |  Link
ryrynz
ryrynz's Avatar
Madshi, that OS API could be buggy or poorly optimized, have you inquired with MS about it? I wonder if 1809 has improved it.
Is there any proper test content one could use to roughly determine optimal peak nits for tone mapping?
Old 1st October 2018, 04:29   #52883  |  Link
Klaus1189
Originally Posted by alps006 View Post
Well, AMD may be a piece junk for you but in my set up I have perfect 4K and 3D playback with RX-460 on Windows 10.I am using 18.5.1 driver and have not updated to new drivers as I am not having any issues. May I ask what issues you are having or had with AMD? If you are having issues, then I am 100% sure it's your own setup related, and AMD has got nothing to do with it. I am a proud user of AMD for years and it definitely isn't a piece of junk.
Same here
Old 1st October 2018, 04:39   #52884  |  Link
ryrynz
ryrynz's Avatar
Please don't quote entire posts for two word replies. We know most AMD users are satisfied with their setups.
Old 1st October 2018, 05:27   #52885  |  Link
mkohman
Hi Guys,
Please forgive me if this has already been covered in a previous post but I need advice in some of MadVR features involving those who have a 2.39:1 scope screen with a projector.
I have recently changed my 16.9 setup to a 2.39:1 setup and built a new screen. Most of my movies (99%) that I watch on this setup are wide screen format and I use my JVC projector to zoom the top and bottom black bars away and fill the screen with the movie.
I notice that madVR has functions that may assistance with this setup under screen config and zoom control... Can someone with a similar setup who are using these features or someone who knows about these features and believe this may be helpful please assist me and give me some tips...
Also there is apparently a way to overcome the multi format movies (ie Nolan movies) what is the setting for that please?
Thanks I advance for all your help..
Sent from my moto g(6) using Tapatalk
mkohman is offline   Reply With Quote
Old 1st October 2018, 08:02   #52886  |  Link
sat4all
Maybe you're using madVR in FSE mode, and madTPG in windowed mode?
i'm using windowed mode with both. Another strange thing with nvidia 4xx.xx drivers, HDR passthrough work fine with mpc-be but not with kodi dsplayer and yet both in windowed mode.
Anyway back to 39x.xx and everything is working as it should.
ZOTAC MAGNUS EN1060K: Win 10 x64 + Kodi DSPlayer x64
LG OLED65C8 / Denon AVR-X3200W / KEF E305+ONKYO SKH-410 / Synology DS2415+ / Logitech Harmony 950
sat4all is offline   Reply With Quote
Old 1st October 2018, 08:36   #52887  |  Link
jerryleungwh
I don't really understand what you're saying. The measurement functionality doesn't report anything to the TV, if that's what you're asking. It just changes madVR's tone mapping curves.
Oh sorry for not being very clear about it. I was just wondering, because the mapping curves are changed each frame accordingly, would it work like some HDR formats with dynamic metadata like Dolby Vision or HDR+?
Also, I just tested with passthrough and tone mapping with target peak nit at 800 in HDR mode and I noticed some of the bright lines could result in haloing while in passthrough, while tone mapping doesn't and seems to produce a more detailed image, but is also slightly dimmer than passthrough. I personally prefer tone mapping but I'll read more comments here to see what everyone else thinks before I settle down on the settings.
Correct me if I'm wrong but highlight recovery seems to be quite GPU intensive and more so on higher levels? I want to try the "are you nuts" setting because some other users here suggest it might work well in HDR tone mapping mode but with NGU sharp chroma upscaling and tone mapping together it's a bit too much for my gtx 1060 even when overclocked at +170 MHz core clock and +179 MHz memory clock
jerryleungwh is offline   Reply With Quote
Old 1st October 2018, 09:28   #52888  |  Link
ryrynz
ryrynz's Avatar
Sacrifice the chroma, it doesn't make that big a difference most times anyway, go to medium or low, doubt you'll notice the difference.. Personally I'd go NGU AA over sharp for chroma but your choice.
Old 1st October 2018, 10:06   #52889  |  Link
mclingo
If you are having issues, ...
Hi, out of interest, have you moved to 1803 yet, i've been putting this off for fear of problems, there has been much said about AMD card and 1803 on here with MADVR.
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions
Old 1st October 2018, 11:24   #52890  |  Link
Magik Mark
Do we have any update on which Nvidia driver works best for custom resolution in Windows 10?
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR
Magik Mark is offline   Reply With Quote
Old 1st October 2018, 11:40   #52891  |  Link
mrmojo666
totally agree and reading all the issues around with nvidia drivers....not sure which one is better. Sometimes i had to struggles with specific driver, but generally speaking all is more than good with amd
(win10 1803)
AMD Ry 1500x - 8GB - RX460 4GB
TV Philips 55pus6501+ Marantz 1608 avr
WIN10(1903) 4K/444RGB
Mediaportal - Mpc-hc
MADVR-D3D11/10bit
mrmojo666 is offline   Reply With Quote
Old 1st October 2018, 15:26   #52892  |  Link
Warner306
I would set target nits to 480 nits and increase the backlight of your display until the image looks balanced. 480 nits is considered a neutral value for BT.2390 when it comes to compression. I've been using different backlight settings for SDR and HDR content, just adjusting this by remote before and after playback.
There is some more information on target nits in the link in my signature if you're interested.
Old 1st October 2018, 15:29   #52893  |  Link
Warner306
All of the driver versions should work more or less the same. If one driver version doesn't work, try a different driver version. Also, some driver versions work for some but not others.
Old 1st October 2018, 15:38   #52894  |  Link
khanmein
Well, NVIDIA also don't have issues, so it might be your own personal issue. We all know that NVIDIA is always performed better when using madVR + MPC.
So far the issue that I always complained is related to FSE mode. I don't even want to use AMD #poorpeople. No offense, but I really don't want to argue with you.
In this world nothing is perfect. I don't know which dictionary you're using. Furthermore, I don't use HDR or any AMD cards, but I dare to confirm that AMD had more issues than NVIDIA when come with into this topic.
khanmein is offline   Reply With Quote
Old 1st October 2018, 15:44   #52895  |  Link
mclingo
I have to say the driver situation is becoming very messy for NVIDIA users at the moment, constant requesrts on here for which version to use. Someone should setup a thread specifically to monitor drivers changes and how it affects MADVR / HTPC playback, we could then just refer people to that. You could then maybe work out which driver works for most people and have that listed as the fallback, goto most stable driver.
if this ever becomes necessary for AMD cards i'd do that.
Old 1st October 2018, 16:58   #52896  |  Link
aufkrawall
Windows 10 surely doesn't help to stabilize drivers.
That said, I neither experienced any driver related madVR issue with my RX 560 nor with my 1070 Ti this year. "Good" ol' 8 bit DVI output...
Old 1st October 2018, 17:11   #52897  |  Link
mclingo
We can all agree on that I think, all this AMD vs NVIDIA is a bit pointless, especially the power vs poverty argument as that is the most irrelevant one as everyone has different needs, stability over power every time for me, I oculd have bought a more expensive NVIDIA card when I got me RX580 but I cant live without native 23,976 support and the stability AMD provide with 3D playback as I am a 3D superfan.
Old 1st October 2018, 17:35   #52898  |  Link
SamuriHL
SamuriHL's Avatar
I'm seriously looking into the possibility of rolling back to Win 8.1 on my HTPC. I didn't think I'd be able to originally but the more I look into it and the things I use, I think it's more possible than I thought. I already backed up my Win 10 with fall update installation so I just need a couple hours to pull the trigger and see how stable it is compared to what I have now. The fact that we have to continue to play these driver games is annoying. That's on MS not AMD or nVidia.
Old 1st October 2018, 17:43   #52899  |  Link
mclingo
If the AMD situation ever gets like that I think i'll drop back as well, have you not thought about switching to RED just to see what life on the other side of the tracks?
Old 1st October 2018, 18:01   #52900  |  Link
SamuriHL
SamuriHL's Avatar
Many years ago I was a huge AMD fan but nVidia surpassed them a long time ago. I've no real desire to go back. AMD has their own headaches. I know you've no issue with them and that's excellent. I'm not discounting that at all. I just have zero desire to switch away from nVidia at this point. I suspect that if I get back to 8.1 this week things will probably be a lot better HTPC wise with madvr.
