Old 12th June 2018, 08:44   #51301  |  Link
madjock
Originally Posted by Magik Mark View Post
Hi!
Does anyone here keeping record of which Nvidia driver is best for all types of custom refresh rates?
390.77 works for me.
Old 12th June 2018, 09:02   #51302  |  Link
madjock
Originally Posted by giulianoprs View Post
How can I post a picture? which url is shared? others I have seen that they have posted other url.
Once you upload the image you share the link from it, the link you shared shares nothing, try the link you create before posting it to see if it works. If you click on the one you have shared already it does not show anything at all.
Old 12th June 2018, 09:28   #51303  |  Link
LigH
LigH's Avatar
I don't have an account on ImageShack, I don't know how their site looks; but I would assume that they provide URL's for each specific image, possibly pre-formatted to paste as HTML snippet or bbCode (this would be the format for a web forum like this).
An easier to use image hoster may be: https://frupic.frubar.net (they don't provide pre-formatted URL's, but their page URL per image is short, and you may as well copy the image address by right-clicking the uploaded image).
New German Gleitz board
Old 12th June 2018, 10:14   #51304  |  Link
sat4all
Hi guys,
Custom resolution is not working anymore with window fullscreen mode. i've tried to create custom resolution with both nvidia cp or madvr, the result will always produce 1 repeated frame in 4.xx min. switching back to FSE fix the problem. i've noticed also that windowed mode provide better rendering time 15ms vs FSE 21ms.
I'm on last windows 10 update and nvidia driver, any body else?
ZOTAC MAGNUS EN1060K: Win 10 x64 + Kodi DSPlayer x64
LG OLED65C8 / Denon AVR-X3200W / KEF E305+ONKYO SKH-410 / Synology DS2415+ / Logitech Harmony 950
sat4all is offline   Reply With Quote
Old 12th June 2018, 10:39   #51305  |  Link
gfxnow
This might be a silly question but should I force enable my onboard Intel GPU (HD Graphics 630) in BIOS to use it as a D3D11 CB device in LAV? The logic being that it might free up resources on my GTX 1070 allowing me to further crank up MadVR settings.
gfxnow is offline   Reply With Quote
Old 12th June 2018, 10:48   #51306  |  Link
fixed function hardware decoder doesn't cost notable performance you are wasting your time.
Old 12th June 2018, 11:10   #51307  |  Link
gfxnow
Thanks, not gonna bother then!
Old 12th June 2018, 13:48   #51308  |  Link
giulianoprs
Osd
https://frupic.frubar.net/fullsize/36926
in this way is it visible?
giulianoprs is offline   Reply With Quote
Old 12th June 2018, 13:52   #51309  |  Link
ryrynz
ryrynz's Avatar
It is, but geez it's kinda small. You resized it a bit much and if I click on it the tab just closes =/
Old 12th June 2018, 14:03   #51310  |  Link
giulianoprs
Osd
https://frupic.frubar.net/36927
I hope it's better now, and sorry if I'm bothering you, but I do not understand much the OSD data and I would like an opinion from some madvr expert, thanks and bye.
Old 12th June 2018, 15:44   #51311  |  Link
Warner306
postimage is easy to use and free.
Old 12th June 2018, 15:45   #51312  |  Link
Warner306
Originally Posted by sat4all View Post
Hi guys,
The lower rendering times are known to be artificial.
Old 12th June 2018, 15:48   #51313  |  Link
Warner306
It looks fine, to me. You could consider disabling scaling for upscales that small under zoom control.
Old 12th June 2018, 16:38   #51314  |  Link
giulianoprs
Thanks Warner, you say go to the "zoom control" section and disable the first "voice" '"disable scaling if image size changes by only"? What does this function do? I do not know what does zoom control and I left in default.
Anyway, everything else is ok? my vision of film and tv series is without shots, all smooth, the only problem are the high temperatures of my gpu, around 65 ° !!!
My gpu is an Asus strix rx 560 o.c. 4gb
Old 12th June 2018, 16:40   #51315  |  Link
madjock
Can someone explain why madVR + KODI and Dsplayer seems to stabilise frame rates compared to MPC-HC and madVR?
When a Movie starts in KODI, it must do a Reset to clear dropped frames on start and seems to stabilise instantly to days then back down to hours for Frame repeats.
Old 12th June 2018, 16:46   #51316  |  Link
even 80° is not a number to think about they are made for such temps.
the threshold is at about 90° don't quote me on that number modern GPU can take very very high temps without any issues.
Old 12th June 2018, 17:31   #51317  |  Link
Warner306
No idea. The players will behave slightly differently because they are coded differently. DSPlayer is a lot more complicated. If it doesn't bother you, I wouldn't worry about it.
Old 12th June 2018, 17:31   #51318  |  Link
Warner306
Disable scaling won't upscale anything if it fits the criteria you set. It will just display the image with a black border. This can save a little performance.
Old 12th June 2018, 23:36   #51319  |  Link
ryrynz
ryrynz's Avatar
@Giulianoprs, it's a waste of resources scaling up like only 8 pixels or so, and the difference is minor.
Also IMO change your chroma scaler to NGU AA, unless of course you prefer the sharper chroma.
Old 12th June 2018, 23:38   #51320  |  Link
mkohman
What's the difference between AA and Sharp please? Thanks
Sent from my moto g(6) using Tapatalk
mkohman is offline   Reply With Quote
