Old 25th July 2018, 23:56   #27541  |  Link
Lathe
Lathe's Avatar
Originally Posted by gonca View Post
Now he has to go upstairs from the basement and ask mom and dad "who is Abbott and Costello?"
He might be "googling it" as I type
Ho ho ho... the nerve...
Lathe is offline   Reply With Quote
Old 26th July 2018, 00:04   #27542  |  Link
gonca
Hey, I was nice to you
I said you could google, just like every other semi developed mommies basement dweller
gonca is offline   Reply With Quote
Old 26th July 2018, 00:59   #27543  |  Link
Lathe
Lathe's Avatar
"semi developed mommies basement dweller..." WOW! I must say, that snowed in deep in Canuk country with only the occasional slow elk for company, you DO have time to come up with some imaginative stuff...
Old 26th July 2018, 01:10   #27544  |  Link
MrVideo
MrVideo's Avatar
MIN_M2TS_SIZE will do it, but only if there is other M2TS's as well. When you set it, it won't show on the list -- but will be copied intact.
Aaaah! I thought it wasn't working when I saw the file missing from the list. I'll give it a go. Thanks.
Old 26th July 2018, 03:56   #27545  |  Link
AmigaFuture
AmigaFuture's Avatar
When you become even cooler, you don't say, "Google whatever.." you say "Use DuckDuckGo to find something." A basement dweller.. Basements are cooler since they're underground, don't go dissin' the Hobbits.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 26th July 2018, 14:02   #27546  |  Link
worknstiff
@ Ch3vr0n; RE: Then you should post a full processing log with any potential errors.
[07/26/18] BD Rebuilder v0.50.25
[08:42:51] Source: RAMPAGE
- Input BD size: 36.63 GB
- Approximate total content: [02:01:00.336]
- Target BD size: 24.27 GB
- Windows Version: 6.2 [9200]
- Quality: High Quality (Default), ABR
- MVC 3D Output Mode enabled
- Decoding/Frame serving: FRIMDecode
[08:42:53] PHASE ONE, Encoding
- [08:42:53] Blanking: VID_00003 (1 of 15)
- [08:42:53] Processing: VID_00004 (2 of 15)
- [08:42:53] Extracting A/V streams [VID_00004]
- [08:42:57] Reencoding video [VID_00004]
- Rate/Length: 23.976fps, 321 frames
- Bitrate: 9,101 Kbs
- [08:42:57] Reencoding: VID_00004, Pass 1 of 2
- [08:43:00] Reencoding: VID_00004, Pass 2 of 2
- [08:43:07] Video Encode complete
- [08:43:07] Processing audio tracks
- [08:43:07] Multiplexing M2TS
- [08:43:11] Blanking: VID_00005 (3 of 15)
- [08:43:11] Blanking: VID_00008 (4 of 15)
- [08:43:11] Blanking: VID_00009 (5 of 15)
- [08:43:11] Blanking: VID_00013 (6 of 15)
- [08:43:11] Blanking: VID_00015 (7 of 15)
- [08:43:11] Blanking: VID_00016 (8 of 15)
- [08:43:11] Blanking: VID_00017 (9 of 15)
- [08:43:11] Processing: VID_00050 (10 of 15)
- [08:43:11] Extracting A/V streams [VID_00050]
- [08:43:15] Reencoding video [VID_00050]
- Rate/Length: 23.976fps, 121 frames
- Bitrate: 7,787 Kbs
- Using FRIMEncoder for MVC encoding
- [08:43:15] Reencoding: VID_00050, Pass 1 of 1
- [08:43:19] Video Encode complete
- [08:43:19] Processing audio tracks
- [08:43:19] Multiplexing M2TS
- [08:43:23] Scanning for 3D CLPI info...
- [08:43:23] Processing: VID_00051 (11 of 15)
- [08:43:23] Extracting A/V streams [VID_00051]
- [08:43:26] Reencoding video [VID_00051]
- Bitrate: 5,241 Kbs
- [08:43:26] Reencoding: VID_00051, Pass 1 of 1
- [08:43:30] Video Encode complete
- [08:43:30] Processing audio tracks
- [08:43:30] Multiplexing M2TS
- [08:43:34] Scanning for 3D CLPI info...
- [08:43:34] Blanking: VID_00103 (12 of 15)
- [08:43:34] Blanking: VID_00242 (13 of 15)
- [08:43:34] Processing: VID_00252 (14 of 15)
- [08:43:34] Extracting A/V streams [VID_00252]
- [08:47:11] Reencoding video [VID_00252]
- Rate/Length: 23.976fps, 154,312 frames
- Bitrate: 25,644 Kbs
- [08:47:11] Reencoding: VID_00252, Pass 1 of 1
[08:48:16] - Failed video encode, aborted
[07/26/18] Checking System Settings
- BD-Rebuilder v0.50.25
- Working Path Free Space: 174.38GB
- AVISYNTH Version: 2.6.0.6, Ok
- HAALI Splitter: 1.9.42.1, Ok
- FFDSHOW: 4504, Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[07/26/18] Systems Settings Check complete
---Also MVCENCODE.bat
"C:\BD-RBV05025\BD_Rebuilder\tools\FRIMDecode.exe" -ts -i::mvc "H:\BDMV\STREAM\00252.m2ts" "H:\BDMV\STREAM\00253.m2ts" -o \\.\pipe\bdrb.yuv -sw | "C:\BD-RBV05025\BD_Rebuilder\tools\FRIMEncode.exe" mvc -i \\.\pipe\bdrb_L.yuv -i \\.\pipe\bdrb_R.yuv -viewoutput -o "D:\WORKING\WORKFILES\VID_00252.AVS.264" -o "D:\WORKING\WORKFILES\VID_00252.AVS.mvc" -sw -w 1920 -h 1080 -f 23.976 -u 4 -cpbsize 3750 -l 6 -profile high -level 4.1 -vbr 25644 45000 -gop 24 4 0 S -maxdpb 4
worknstiff is offline   Reply With Quote
Old 26th July 2018, 14:12   #27547  |  Link
Ch3vr0n
I'm no expert. Jdobbs is. But at least now he has something to work with
Ch3vr0n is offline   Reply With Quote
Old 26th July 2018, 17:29   #27548  |  Link
AmigaFuture
Update: BD-RB might have a bug with some TS files. But I've discovered that if I open the edited TS file I removed the commercials from into VideoReDo (5.3.86.763) and save it as MKV or MP4 then BD Rebuilder imports them and also converts them in sync. I don't recall encountering this before this update of VideoReDo. Anyway..if you still want to check the TS file I could provide a link.
Old 27th July 2018, 09:51   #27549  |  Link
MrVideo
MrVideo's Avatar
I always have VRD output MKV files, as that allows me to add chapter marks.
Old 27th July 2018, 18:02   #27550  |  Link
AmigaFuture
I use TS because it retains the Closed Captions that CCExtractor is able to get as SRT, and it remains a "pure" source after commercials are removed. JD and you got that clear a bit ago since rerendering already poor HD TV quality to 23.976 FPS loses even more. I wish higher qualuty was used since Coaxil is being used rather than OTA. I also agree about chapter marks, so it's often a multiple saves to get all the wanted stuff.
Edit: TS is importing fine...after examining import Temp more. It's the process to do with MP4Box that causing it. Ah, well, I left Apple and so MKVs are used everywhere else, except online. For now, glad to own VRD.
Old 30th July 2018, 14:59   #27551  |  Link
Rich86
Rich86's Avatar
I'v e asked for help before, but nothing has come forward. I cannot seem to successfully complete a conversion from BD to DVD in BD-RB if I include a subtitle. This used to work fine, but now always seems to fail. It completes the "convert 1 subtitle to dvd format step", then goes into "starting mplex" and runs all the way to 100%, but then throws the "error in attempt to mux" & "failed to rebuild" messages and stops. Is this a bug? Is there something different about english subtitles in today's BD releases that the program gags on? Am I doing something wrong?
[07/30/18] BD Rebuilder v0.50.25
[06:48:32] Source: READY_PLAYER_ONE_00100
- Input BD size: 31.46 GB
- Approximate total content: [02:19:58.264]
- Windows Version: 6.1 [7601]
- MOVIE-ONLY/ALTERNATE OUTPUT mode enabled
- Mode: DVD-5, 720x480/576, AC3 Audio
- Quality: Highest (Very Slow)
- SHUTDOWN at completion enabled
- Decoding/Frame serving: DirectShow
- Audio [1] set to default.
- Resuming from previously started job.
[06:48:35] PHASE ONE, Encoding
[06:48:35]PHASE ONE complete
[06:48:35]PHASE TWO - Rebuild Started
- [06:48:35] Building ALTERNATE OUTPUT Structure
- [06:48:35] Converting 1 subtitles to DVD format.
- [06:49:33] Starting MPLEX.
- ERROR in attempt to mux (MPLEX)
[06:51:32] - Failed to REBUILD
[07/30/18] Checking System Settings
- Working Path Free Space: 674.90GB
- LAVFILTERS: Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[07/30/18] Systems Settings Check complete
Rich86 is offline   Reply With Quote
Old 30th July 2018, 19:53   #27552  |  Link
jdobbs
@Rich86
I'll do some tests and see what's going on.
Website: www.jdobbs.net
Old 30th July 2018, 21:16   #27553  |  Link
Rich86
Rich86's Avatar
Thanks - anything I can do to help (provide more info - testing, etc.) just let me know.
Old 30th July 2018, 22:56   #27554  |  Link
jdobbs
I just did a test and it worked fine for me. Can you post your settings so I can try again using the same configuration as you?
[Edit] I just did another conversion... no problem for that one either.
Old 31st July 2018, 17:01   #27555  |  Link
Rich86
Rich86's Avatar
This is a Win7Pro64 SYSTEM.
When the program throws the error, the TMPSUBS folder is sitting under Workfiles full of subtitles.
The following is after I used the program to make a movie only BD, but I don't mess with the config file between runs.
I will try running the same BD on my laptop and see if it does the same thing.
Thanks for helping me figure out what is wrong.
VERSION=0.50.0.24
Enable_test=1
MODE=3
ENCODE_QUALITY=3
ONEPASS_ENCODING=0
AUTO_QUALITY=0
MOVIE_ONLY_LOOP=0
ALTCRF=20
ALT_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
Target_Size=23500
Custom_Target_Size=25000
Min_Playlist_Mins=1
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=1
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=1
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=1
DGDECNV=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
PRIORITY_CLASS=0
ENABLE_BLANKING=1
RESIZE_1440=0
OUTPUT_3D=0
RESIZE_720=0
NEROAAC=0
IMPORT_THRESHOLD=0
QUICK_PLAY_THRESHOLD=0
MENU_AUTO_BACKGROUND=0
MENU_PLAY_SEQUENTIAL=1
MENU_START_WITH_MENU=0
ENCODER=0
IGNORE_3D=0
DECODER=0
FRIMSOURCE=0
OUTPUT_SBS=0
SUPTITLE=0
MENU_AUTO_DVDAUDIO=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=1
IMPORT_PAL_TO_FILM=0
MENU_AUDIO=C:\Utilities\BD_Rebuilder\tools\blankclip\blank.ac3
MOVIEONLY_TYPE=0
AUDIO_DRC=0
ALT_CRF_TARGET=1024
STATUS_LOG=0
PGSTOSRT=1
[Paths]
SOURCE_PATH=
WORKING_PATH=
Update: the exact same thing happened on my laptop.
Could it be something in the rip? I use DVDFab creating folders/files.
I do not have any problems creating BDs with subtitles - only DVDs (movie only with 1 english subtitle).
multiAVCHD creates a dvd from the rips just fine.
Update #2: there is a file called "cvt.bat" in the tmpsubs folder.
The contents of that file include:
pushd "C:\VIDEOSTRANSCODED\PACIFICRIMUPRISING-DVD\WORKFILES\TMPSUBS"
"C:\Utilities\BD_Rebuilder\tools\dvdauthor\bmp2png.exe" -E 4608*.bmp
popd
all the subtitle files start with 4608 . . and . . they are all .png files. in case that has anything to do with this?
Update #3:
I ran my "Ready Player One" BD through BD-RB for DVD output including english subtitles. It failed the same as previously described.
However, then I ran the "Midnight Sun" BD through BD-RB for DVD output including the english subtitles. It ran to conclusion and the output is fine. So, whatever the problem is doesn't seem to happen with all titles.
Old 1st August 2018, 04:18   #27556  |  Link
AmigaFuture
Keep processing BD's that way. I've run a few so far, and 0 problems. I plan to get "Ready Player One"..soon. Meanwhile, I'm checking with my other recent BDs. I haven't used alternative that way..much.
Old 1st August 2018, 19:59   #27557  |  Link
jdobbs
@Rich86
I've wanted a copy of "Ready Player One" anyway -- so I'll pick it up and run that job using your settings.
Old 2nd August 2018, 22:58   #27558  |  Link
AmigaFuture
I've processed a few BDs to DVD9 and only problem I've noticed is undersized DVD-9 when AC-3s are involved. If DTS is the only one used, and converted by the process then projected size is fine.
@Lathe
Are you going to attempt to make something from the "size" comment, Lathe?
Old 2nd August 2018, 23:06   #27559  |  Link
Lathe
Lathe's Avatar
Originally Posted by AmigaFuture View Post
@Lathe
Of course not... I'm not that kind of person...
Old 3rd August 2018, 01:28   #27560  |  Link
Rich86
Rich86's Avatar
BD to DVD5 with Subtitles failure:
I just ran the "Death Wish" BD through BD-RB to a DVD5 with english audio and the english subtitles. It worked fine and the created dvd looks fine. So whatever problem is happening is not universal and is definitely restricted to certain titles.
