Old 26th January 2014, 22:34   #22001  |  Link
madshi
Originally Posted by TheShadowRunner View Post
I just tried and that's not it either.
It has to do with the openCL stuff again as 0.87.2 behaves exactly like 0.87 here, black screen while audio is playing then always player crash on exit..
Well, I can reproduce the problem if I uncheck the "prerender multiple frames" option off on my PC. That's definitely the reason why you got a black screen. Maybe there is an additional reason. But I can't see it in the log because the unchecked "prerender multiple frames" option already did all the damage. If you can create another log with the option checked, I can have another look. Maybe I can see what's going on.
OpenCL should not even be initialized at all, if you have those 3 options set like I said earlier. So I don't think this has anything to do with OpenCL.
Old 26th January 2014, 22:34   #22002  |  Link
djfred93
You probably just copied madVR.ax over? You need to replace all files, especially mvrSettings.dll.
I delete all the file except setting.bin and it's still the same issue.
djfred93 is offline   Reply With Quote
Old 26th January 2014, 22:42   #22003  |  Link
TheShadowRunner
TheShadowRunner's Avatar
Oh my bad, sure, here it is with "present multiple frames" enabled: madV_logTSR.zip
XP SP3 / Geforce 8500 / Zoom Player
TheShadowRunner is offline   Reply With Quote
Old 26th January 2014, 22:49   #22004  |  Link
Stereodude
I'm a little confused... I have these profile auto select rules, but it always picks the progressive profile even when the source is definitely interlaced (madVR reports deinterlacing is on and shows a time for it).
if (srcInterlaced = true) "interlaced"
else if (srcInterlaced = false) "progressive"
I'm using .87.2 if that matters.
Edit: False alarm. I didn't realize it doesn't re-evaluate the source (like when playing a DVD going from the previews to the menu to the movie), nor did I realize that the madVR settings window doesn't stay in sync with madVR as it's running.
Stereodude is offline   Reply With Quote
Old 26th January 2014, 22:55   #22005  |  Link
noee
try this:
if (srcInterlaced = true) "interlaced" else "progressive"
noee is offline   Reply With Quote
Old 26th January 2014, 22:56   #22006  |  Link
iSunrise
You need to use "==" and not "=", since this is a boolean check.
You can also use if (srcInterlaced) "interlaced" or (!srcInterlaced) to make it even simpler.
iSunrise is offline   Reply With Quote
Old 26th January 2014, 23:01   #22007  |  Link
Stereodude
No you don't. link
However, I've edited my post as I believe I understand why I wasn't seeing the correct information.
Old 26th January 2014, 23:02   #22008  |  Link
madshi
Originally Posted by djfred93 View Post
MadVR don't load with the latest version, it is stuck at opening the file and it crash on the setting window. The debug don't work either.
Log
My system : Intel Core i7@920, Ati Radeon HD 5770, Windows 8.1, MPC-HC 1.7.2
The log seems to suggest that the decoder is never sending any video frames to madVR. But I'm not fully sure. It could also be a different problem just looking like that. Try different video files and maybe a different decoder. Does playback work with v0.86.11?
Hmmmm... The log suggests that "present several frames in advance" is still disabled.
I've tried your exact setup and it works correctly here. The profiles switch exactly as intended. BTW, you could shorten your script to "if (srcInterlaced) "interlaced" else "progressive"". But it won't make any difference. Your script is alright.
Old 26th January 2014, 23:08   #22009  |  Link
iSunrise
No you don't. link
You´re right, that one was a major oversight by me, didn´t think that madVR would consider == and = as being an equal operation. But at least my second advice is valid.
Old 26th January 2014, 23:09   #22010  |  Link
TheShadowRunner
Hmmmm... The log suggests that "prerender multiple frames in advance" is still disabled.
... hmm indeed?
We're talking about "exclusive mode settings" > "present several frames in advance" ENABLED, right?
I made another log after 2x checking.. here it is: madVR_logTSR_2.zip
Old 26th January 2014, 23:12   #22011  |  Link
madshi
... hmm indeed?
Weird. Ok, let me think: The log indicates that madVR is using D3D9 instead of D3D9Ex. That usually means that "present several frames in advance" is disabled. However, now I think I misinterpreted that. Are you by any chance still using Windows XP? That would explain the problem, because the cause of the issue is the use of D3D9. And XP doesn't support D3D9Ex.
P.S: Just saw your signature. Yes, the problem is XP. My fault, I misinterpreted the log. The problem will be fixed in v0.87.3, sorry.
Old 26th January 2014, 23:13   #22012  |  Link
Stereodude
Thanks, I found my problem and edited my post, but you were too fast.
Old 26th January 2014, 23:15   #22013  |  Link
djfred93
It's the same with MPC-BE and his internal filter. It was working fine with MadVR 0.86.11 and with MadVR 0.87.1.
Old 26th January 2014, 23:16   #22014  |  Link
leeperry
Kid for Today
Ouh it seems that 87.2 has made DXVA2 fully usable on my rig, especially if I check "use OpenCL to process DXVA". At this stage, only a wattmeter will make me decide between CPU or GPU video decoding.
My only last problem is that I get tearing at the bottom of the picture in windowed mode, it instantly disappears when I go FSE or FSW...very strange and not a big deal anyway.
The performance issue I mentioned when going FS is apparently due to how W7 behaves when mVR simultaneously rolls the refresh rate and goes FS, XP did it all seamlessly but W7 hiccups quite a bit as the picture is vertically stretched for like a split second, then the AR is applied and playback finally starts.
I see that you've explained several times in this thread that NNEDI can do 2X vertical and/or horizontal upscale but:
1) why is there a "NNEDI3" processing option in the "chroma upscaling" tab, but not in "image upscaling"?
2) if I want to upscale a 4:3 360*288 video to 4:3 1440:1080, the default "image doubling" settings will upscale it to 1440*576 and then 576 will be upscaled to 1080 using the algorithm I chose in "image upscaling"?
Old 26th January 2014, 23:20   #22015  |  Link
TheShadowRunner
Ooh no worries, glad you found the issue ^^;
See you,
TSR
Old 26th January 2014, 23:24   #22016  |  Link
Stereodude
Okay, I'm pretty sure this one is real...
I have these rules for image and chroma scaling
if ((srcWidth <= 1300) and (deintFps < 31) and (srcInterlaced == true)) "<= 720i 24-30fps"
else if ((srcWidth <= 1300) and (deintFps < 31) and (srcInterlaced == false)) "<= 720p 24-30fps"
else if ((srcWidth <= 1300) and (deintFps > 31) and (srcInterlaced != true)) "<= 720p 50-60fps"
and this rule for image downscaling
if ((srcWidth >= 1600) and (deintFps < 31) and (srcInterlaced == false)) ">= 1600w 24-30fps"
Playing back a blu-ray on my 1600x1200 monitor I see this:
It's using the downscaling settings, but shouldn't none of the image scaling options be bold since none are active? FWIW, the downscaling option is bold when playing back content that's not being downscaled also.
Old 26th January 2014, 23:36   #22017  |  Link
madshi
I see. Have you tried going back to 0.86.11 or 0.87.1 after you ran into this problem? Sometimes the OS just gets into a screwed up state. Could you please double check if 0.86.11 or 0.87.1 still work if you go back to them now?
If they still do work then I've no idea what the problem could be...
Great!
NNEDI3 can only do exact 2.0x enlargements. Chroma upscaling happens to be exactly that. So NNEDI3 can serve as a full replacement for the other algorithms, when talking about chroma upscaling.
However, the image upscaling factor is very rarely exactly 2.0x. So NNEDI3 is almost never a full replacement algorithm for the other algorithms like Lanczos or Jinc, when talking about image upscaling. Let's imagine I made the image upscaling settings page the same as the chroma upscaling settings page is now. And let's imagine you selected NNEDI3 for image upscaling. Let's further imagine in your specific situation you'd need a 3.0x scaling factor. What should madVR do in that case? It could use NNEDI3 to upscale 2.0x or 4.0x, but not 3.0x. So what should it do? It's not clear. Because of that I cannot offer NNEDI3 as a full replacement algorithm in the image upscaling settings page.
No. The default "image doubling" settings disable image doubling / NNEDI3.
You can tell madVR to double your image size, or to quadruple it with NNEDI3. If you tell madVR to only double it, you get 720*576. If you tell madVR to quadruple it, you get 1440*1152. But whether madVR actually doubles or quadruples depends on which exact settings you're using in the "image doubling" section. There are several radio boxes in there you can check which controls all this. In any case, if the output of "image doubling" is smaller than the target resolution, madVR will use the algorithm from the "image upscaling" settings page to upscale the "image doubling" output to the needed target resolution. If the output of "image doubling" is larger than the target res, madVR will usw the image downscaling algorithm to achieve the target res.
The "bold" state just shows which profile is active. One profile is always active in every profile group. If your script doesn't select a profile, the first profile in the list will be active. A profile being active doesn't mean that the settings page is actually used. It just says which profile would be used if the settings are needed by madVR.
Old 26th January 2014, 23:36   #22018  |  Link
madshi
madVR v0.87.3 released
http://madshi.net/madVR.zip
* fixed: blacked out video in Windows XP
* fixed: blacked out video when disabling "present several frames in advance"
Old 26th January 2014, 23:40   #22019  |  Link
6233638
Chroma upscaling is often not very important. I don't really recommend using NNEDI3 for chroma upscaling - unless your GPU doesn't have anything else to do, maybe.
I agree, it's far less important than luma scaling - but I appreciate that madVR does have high quality chroma scaling options available.
Generally I would suggest:
  1. Mitchell-Netravali
  2. Bicubic 75 with the anti-ringing filter enabled
  3. Jinc 3 with the anti-ringing filter enabled
in order of performance impact and quality. (low to high)
Anything above Bilinear is good though, as that can introduce noticeable artifacts, and with the optimized scaling algorithms I'd like to think that few systems would have to compromise and use Bilinear.
Mitchell-Netravali is a good choice if you don't have the performance to enable the anti-ringing filter, as it has very little ringing itself.
You could use Bicubic 75 instead as that's sharper and has the same performance requirements, but it can suffer from ringing.
Bicubic 75+AR gets you 90% of the way there as far as chroma quality is concerned. For the vast majority of sources, this will be indistinguishable from anything more advanced.
And when you have performance to spare, Jinc 3+AR is the best option, though few sources actually require it.
I am looking forward to doing some testing once NNEDI3 is working though.
Unless you're using a really low power system, the difference is probably going to be negligible between DXVA or software decoding on modern hardware - at least up to 1080p.
Error handling is definitely better with software decoding.
Someone posted a really good sample video here (probably years ago at this point) which shows errors with the hardware decoders that do not exist with LAV's software decoding:
(the sample appeared to be a broadcast recording with fast movement and a lot of flashing lights)
That being said, it is extremely rare to find this with commercially produced content.
So far I've only seen this occur with a single blu-ray (out of hundreds) and have had one other report of it happening on another disc.
Because it's so rare in the content I watch, I do use DXVA-CB decoding, as it means that high CPU usage in other programs is a lot less likely to affect video playback.
If you see blocking like that happen in the content that you watch though, you should check and see if switching to software decoding will fix it.
Chroma upscaling is only ever going to be 2x.
If you're scaling luma with NNEDI3 you are likely to use NNEDI3 to scale 2x and use an additional scaler (up or down) to scale that image to your display resolution.
Edit: Nevermind - Madshi has already managed to answer your question and put out a new build in the time it took for me to type up that reply.
Old 26th January 2014, 23:42   #22020  |  Link
TheShadowRunner
Ahah that was lightning fast, thank you!
Testing..
