Old 12th April 2009, 20:31   #181  |  Link
TinTime
* depending on source resolution "SD.3dlut" or "HD.3dlut" is loaded now
How does madVR decide what's SD and what's HD? What are the resolution cut-offs?
The crtl+J info is reporting the refresh rate correctly for me at 24Hz, 50Hz and 60Hz (I only use a primary display). Average GPU rendering time hovers around 14ms for 24Hz playback. I've tried a blu-ray AVC source (muxed to mkv with eac3to) and that works for me with CoreAVC CUDA decoding too, on a 512MB 8600GT.
I tried turning off CUDA decoding in CoreAVC and found that I got some tearing during playback of HD AVC files. It looks like tearing for me is a symptom of my PC not quite decoding fast enough. It's an Athlon X2 5600+, which I think is a bit borderline for HD decoding. It's not a problem with madVR itself, unless madVR should absolutely never tear under any circumstances.
HD VC1 is similar. I get occasional tearing which seems to coincide with a dropping in the number of frames in the frame queue reported by madVR. I can't get totally smooth playback with other renderers either though for HD VC1, except for VMR9 with DXVA.
TinTime is offline   Reply With Quote
Old 12th April 2009, 20:38   #182  |  Link
Xorp
Strange! How does the pin connection info look like?
Not sure why you only get 18fps. Might be due to madVR consuming too much CPU so that your decoder chokes (the frame queue is only at 3/16, usually it should be 16/16, having it at so low value means that the decoder is not delivering frames fast enough). But your gpu rendering times are also quite heavy.
Do you happen to have another filter running (e.g. ffdshow) which upscales the video to double resolution? That would explain the strange movie resolution report and also the high gpu rendering times.
Only CoreAVC was decoding, nothing else.
I had the same low fps problem in MPC custom build with madVR, but when I went back to the Beliyaal-build setting madVR as a preferred external renderer, everything runs smoothly now. Getting 16/16 frame queues.
Xorp is offline   Reply With Quote
Old 12th April 2009, 20:46   #183  |  Link
madshi
Originally Posted by Thunderbolt8 View Post
the display I used here has 1680*1050 res, so its not 1:1 (the other screen on my own system has 1280*1024). so you still want me to try zoom?
No, scaling was probably already activated because it's not 1:1.
hm so your advise would be to change it to 24 (or exactly 23.976?)Hz? how can I do that, in my graphic card options when I rightclick on windows screen and then properties (only have the option to choose either 59 or 60Hz there)? or do I need to change that in ffdshow?
That would be graphics card properties or PowerStrip (if all else fails). But that makes sense only if your display can handle that!
HD = wider than 1024 or higher than 576
Sounds good to me.
Strange. Could you please post the pin connection info? (right click -> filters -> madVR -> Pin Info). If possible for both the situation where madVR reports the funny resolution. And also for the situation where madVR runs fluidly. There must be a difference somewhere. I'd really like to know why madVR reports such a high resolution for you!
Old 12th April 2009, 20:48   #184  |  Link
madshi
Two questions for those of you who have such ultra high CPU consumption:
(1) Is that with the OSD turned on? Or also with OSD turned off? FWIW, with OSD turned off CPU consumption should be a bit lower than with it turned on.
(2) Are you running madVR on your primary monitor? Or on secondary? I'm asking because running on secondary has problems right now...
Old 12th April 2009, 21:10   #185  |  Link
STaRGaZeR
4:2:0 hater
Check out this page:
Thanks for the info.
madVR stores 16 decoded frames in RAM.
Wouldn't it be better to store them in the GPU RAM? EVRCP does this, maybe it'd solve latency problems and/or CPU consumption.
Oh and the levels are good now, thanks!
Does madVR have any kind of deinterlacer? Interlaced material looks deinterlaced, with ghosting though. Of course no other deinterlacer is in the chain.
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline   Reply With Quote
Old 12th April 2009, 21:10   #186  |  Link
yesgrey
Here are my stats while playing a Blu-ray movie remuxed to a mkv file. My card is a GF 8600GT 256MB.
The frame rendering is ~14ms. For playing in my monitor at 72Hz (13.9ms) is not enough, but should be fine to use with my projector at 48Hz (20ms). If I use Lanczos or Spline resampling the rendering time jumps to ~20ms, so I should not be able to use those resamplers with smooth playing...
madshi, would it be possible for us to set the number of frames buffered (maybe in the settings.ini)? I could try reduce the number to see if it works better with cuda enabled...
Old 12th April 2009, 21:18   #187  |  Link
yesgrey
In my source code I've added the following comments. They might help here, too:
It might be a good idea to include those comments in the readme...
Old 12th April 2009, 21:20   #188  |  Link
madshi
You would be right if madVR needed to draw a *new* Blu-Ray frame every VSync. But if it did that, you'd get 3x respectively 2x as fast movie playback as you should get. madVR has to skip lots of VSyncs with your refresh rates. Because of that the most important reference time is not the "vsync interval" but the "frame interval". So I think you should be able to use Lanczos4 just fine, sooner or later...
The frame queue is stored in RAM, not in GPU. So how could it possibly conflict with CUDA?
I hope that sooner or later I can reduce the number of scaling options. I was hoping to start a vote after a while for which scaling options to keep and which to remove.
Old 12th April 2009, 21:21   #189  |  Link
leeperry
Kid for Today
I think the AVS peeps advise spline36 as the "best" choice...so that's 3 taps then
Old 12th April 2009, 21:24   #190  |  Link
Xorp
madVR selected in Output
Filter : madVR - CLSID : {E1A8B82A-32CE-4B0D-BE0D-AA68C772E423}
- Connected to:
CLSID: {9852A670-F845-491B-9BE6-EBD841B8A613}
Filter: DirectVobSub (auto-loading version)
Pin: Output
- Connection media type:
Video: YV12 3840x2160 24.00fps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: MEDIASUBTYPE_YV12 {32315659-0000-0010-8000-00AA00389B71}
formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 1
cbFormat: 112
VIDEOINFOHEADER:
rcSource: (0,0)-(0,0)
rcTarget: (0,0)-(0,0)
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 416666
VIDEOINFOHEADER2:
dwInterlaceFlags: 0x00000000
dwCopyProtectFlags: 0x00000000
dwPictAspectRatioX: 3200
dwPictAspectRatioY: 1800
dwControlFlags: 0x00000000
dwReserved2: 0x00000000
BITMAPINFOHEADER:
biSize: 40
biWidth: 3840
biHeight: 2160
biPlanes: 3
biBitCount: 12
biCompression: YV12
biSizeImage: 12441600
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0020: 00 00 00 00 00 00 00 00 9a 5b 06 00 00 00 00 00 ........š[......
0030: 00 00 00 00 00 00 00 00 80 0c 00 00 08 07 00 00 ........€.......
0040: 00 00 00 00 00 00 00 00 28 00 00 00 00 0f 00 00 ........(.......
0050: 70 08 00 00 03 00 0c 00 59 56 31 32 00 d8 bd 00 p.......YV12.ؽ.
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
madVR set as preferred in external filters
- Connected to:
CLSID: {09571A4B-F1FE-4C60-9760-DE6D310C7C31}
Filter: CoreAVC Video Decoder
Pin: Output
Video: YV12 1920x1080 24.00fps
AM_MEDIA_TYPE:
lSampleSize: 1
cbFormat: 112
VIDEOINFOHEADER:
dwBitRate: 0
dwBitErrorRate: 0
VIDEOINFOHEADER2:
dwPictAspectRatioX: 1920
dwPictAspectRatioY: 1080
BITMAPINFOHEADER:
biSize: 40
biWidth: 1920
biHeight: 1080
biPlanes: 3
biBitCount: 12
biCompression: YV12
biSizeImage: 3110400
biXPelsPerMeter: 1
biYPelsPerMeter: 1
biClrUsed: 0
biClrImportant: 0
pbFormat:
0030: 00 00 00 00 00 00 00 00 80 07 00 00 38 04 00 00 ........€...8...
0040: 00 00 00 00 00 00 00 00 28 00 00 00 80 07 00 00 ........(...€...
0050: 38 04 00 00 03 00 0c 00 59 56 31 32 00 76 2f 00 8.......YV12.v/.
0060: 01 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................
So DirectVobSub was interfering.
Old 12th April 2009, 21:31   #191  |  Link
Brazil2
madVR v0.3 released *again*
I can't get any OSD, Ctrl+J has no effect at all.
Maybe because I've manually installed MadVR.ax (using regsvr32) rather than using InstallFilter.exe ?
I'm still having aspect ratio problems with the sample I've posted here:
http://forum.doom9.org/showthread.ph...13#post1272713
And also with this one:
http://mirror05.x264.nl/public/force...baff.sample.ts
Both files are playing fine with the correct aspect ratio with other renderers.
And I have problems with MPEG2 NTSC interlaced when the built-in MPC-HC decoder is set to BOB. It's hard for me to describe what is happening but the image is 'shaking' a lot.
It seems to be OK with PAL MPEG2 interlaced though.
Brazil2 is offline   Reply With Quote
Old 12th April 2009, 21:32   #192  |  Link
madshi
Yep. I've never used DirectVobSub myself yet, but it seems that it doubled resolution somehow for you, probably with the intention of being able to render smoother looking subtitles. Of course having 4x as many pixels brings madVR (or rather your graphics card) to its knees. Your gpu rendering times should be a lot lower without DirectVobSub doubling resolution, I guess about 4x lower. And that makes a lot more sense because your 8800 should be quite powerful and should have no problems with processing 1080p24.
Old 12th April 2009, 21:35   #193  |  Link
madshi
Originally Posted by Brazil2 View Post
I can't get any OSD, Ctrl+J has no effect at all. Maybe because I've manually installed MadVR.ax (using regsvr32) rather than using InstallFilter.exe ?
Strange, seems to work for everyone else? Manually installing makes no difference.
I'm still having aspect ratio problems with the sample I've posted [...] and also with this one
Thanks, will have a look at that later...
If that fine with other renderers? If so, can I have just another sample?
Old 12th April 2009, 21:52   #194  |  Link
Brazil2
Yes, it's fine with other renderers.
Well, any MPEG2 NTSC interlaced DVD compliant file I've tried is doing the same. I've tried with a VOB from a ripped and decrypted DVD (because I couldn't play the DVD itself in MPC-HC with MadVR, MPC-HC just hangs and nothing happens) and also with a MPG file created with MEncoder which is DVD NTSC film compliant. Maybe the 3:2 pulldown is the problem ?
I live in PAL land so I don't have much MPEG2 NTSC material but the ones I have are not working fine when MPC-HC decoder is forced to BOB.
Old 12th April 2009, 21:56   #195  |  Link
yesgrey
So the frames are stored in RAM instead of GPU memory?
No. I'm uploading every frame to GPU memory before processing it, of course.
From the previous answer I thought the frame queue was stored in GPU memory... now I realize that I've not understood completelly your reply. They are stored in RAM but are copyed to GPU memory (one at a time) before starting any processing. Got it.
Great! so it seems I could keep my 8600gt a little longer...
I plan to do my scaler test and will post here the results...
Have you uninstalled the previous? madVideoRenderer.ax?
Old 12th April 2009, 21:59   #196  |  Link
Brazil2
Yes, of course I did
regsvr32 -u madVideoRenderer.ax
regsvr32 madVR.ax
I haven't rebooted since then. Should I ?
Old 12th April 2009, 22:10   #197  |  Link
yesgrey
Shouldn't be needed, but it will not hurt... maybe you should use the uninstall and install, instead of manually doing it...
Old 12th April 2009, 22:18   #198  |  Link
leeperry
Kid for Today
I've just realized that you can press CTRL+J twice and get even more stats...great for boring movies I guess
it's good that it's like HR(and unlike EVR/VMR9), as long as you can catch the VSYNC properly it will remain so and *NOT* drop video frames
PS: that'd be fun if you could put 3 or 4 digits after the coma for the VSYNC interval.
Old 12th April 2009, 22:53   #199  |  Link
buletti
Could that be the cause of the high CPU load? The copy operation from RAM into VRAM is done by the CPU and is a rather slow operation AFAIR. However, after a short google search, it seems that this is no big issue anymore with PCI-E and asynchronous memcpy via CUDA...
buletti is offline   Reply With Quote
Old 13th April 2009, 00:08   #200  |  Link
Snowknight26
Can anything be done about an error that says "graphics card only supports power of 2 textures?" Happens with my GM45.
Snowknight26 is offline   Reply With Quote
